Question about West Bend 56860 10-Cup Coffee Maker
Time to clean -
Our coffee pot has a "time to clean" indicator light that is currently on. is this the reason it wont make coffee? and if so how do i turn it off? please help. sean
The link does NOT work.
Posted on Dec 25, 2007
    Problem Solver:
  • 19 Answers
You need to clean you coffee pot as stated in the operator manual. Follow the link below it will take you to your coffee pot manual online. Its just like a car and has to maintained regualry.
http://www.westbend.com/catalog.cfm?dest=itempg&itemid=2883&secid=13&linkon=subsection&linkid=35
Posted on Nov 09, 2007
SOURCE:
Mr coffee problems
You didn't indicate a specific model. So, I'm going to assume yours is relatively the same as my JWX27.
Let me start by clarifying what the red light indicates.
A solid red light indicates the cleaning cycle is in progress. A blinking red light indicates the coffeemaker is off, but due to be cleaned. When the coffeemaker is due to be cleaned, the red light will continue to blink while the coffeemaker is off until the cleaning cycle has been completed fully. The entire cleaning process takes about an hour and a half. And, it is not intuitive. So, here are my instructions.
With the coffeemaker off (with the red light blinking), pour four cups of pure white vinegar (no water added) into the reservoir. Don't short the amount. You'll need four cups to complete the cycle. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
After the cleaning cycle has completed, get rid of the vinegar. Rinse out the strainer basket and the coffee pot. Run a full pot of clean water thru a regular brew cycle (with the pot and basket in place, of course). Then, dump the water, rinse the pot and basket again, and run another full pot of clean water thru a regular brew cycle. Dump that water too. And, you're done!
Jul 20, 2014 | Mr. Coffee Coffee Makers & Espresso...
Clean instructions
First, let me clarify what the red light indicates.
Feb 04, 2014 | Mr. Coffee JWX27 12-Cup Coffee Maker
Clean instructions
I presume you are requesting instructions for cleaning this coffeemaker...
With the coffeemaker off (either a red blinking light or no light on), pour four cups of pure white vinegar (no water added) into the reservoir. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
Sep 30, 2013 | Mr. Coffee JWX27 12-Cup Coffee Maker
Model # jwx23 mr coffee cleaning instructions
I couldn't find any model JWX23. So, since your question (as much as it is) is categorized under model JWX27, I'm going to presume you need the cleaning instructions for model JWX27.
With the coffeemaker off (with no lights on or with the red light blinking), pour four cups of pure white vinegar (no water added) into the reservoir. Don't short the amount. You'll need four cups to complete the cycle. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
Jan 01, 2012 | Mr. Coffee JWX27 12-Cup Coffee Maker
We ran the clean cycle on the coffee maker and the clean cycle will not turn off.
First, let me clarify what the red light indicates. A solid red light indicates the cleaning cycle is in progress. A blinking red light indicates the coffeemaker is off, but is due to be cleaned.
The red light will continue to blink while the coffeemaker is off until the cleaning cycle has been completed fully. The process takes about an hour and a half and is not intuitive. So, here are my instructions.
May 15, 2011 | Mr. Coffee JWX27 12-Cup Coffee Maker
What does it mean when the brew light flashes?
Pot needs cleaning. Fill reservoir with 4 cups of vinegar. Press the SELECT button until the red CLEAN indicator light turns on. Let it perk through. It will take 45-60 minutes. It brews a few cups, stops and then should brew the remainder of the vinegar. When the cycle is complete the light will burn off and the coffeemaker will turn off. Discard vinegar solution and run a couple of pots of clear water through. Hope this helps.
Mar 25, 2010 | Cuisinart Cup-O-Matic SS-1 Coffee Maker
Cleaning light came on and now, coffee pot will not work
Automatic clean function
The coffee maker is equipped with an automatic clean function. After 60 brewing cycles, the clean indicator/button (22) lights up. This indicates coffee maker should be cleaned by using the automatic clean function and the charcoal filter (17) should be replaced.
NOTE: The coffee maker can continue to be used, when clean indicator/button (22) is on.
• To begin the cleaning cycle, remove the charcoal filter (17) from the water tank (10). Fill the tank with a vinegar and water mixture (1/2 vinegar and 1/2 water) or a descaling product. Press clean (22) button for three seconds. The clean indicator/button (22) flashes and the cleaning process begins.
Cleaning process:
• 24 cycles of 7 seconds brewing and 21 seconds off
• 30 minutes rest
• Brewing the remaining descaling solution
• After cleaning process is complete the clean indicator/button (22) goes off. Fill water tank (10) with clean water and run one brewing cycle to rinse the coffee maker.
• Change the charcoal filter (17) (ill. k). Reinsert the charcoal filter to the coffee maker (ill. l).
NOTE: You can use the cleaning function before reaching 60 cycles (especially if the water hardness is above normal). Press and hold clean indicator/button (22) for 3 seconds.
NOTE: The Cleaning Process takes 60 minutes to complete. You cannot cancel the cleaning process before it is complete. Unplugging the machine only delays the cleaning process.
Jan 26, 2009 | GE 106591 Coffee Maker
Cleaning light will not quit blinking after cleaning
The same thing happened to our Mr. Coffee this week! I followed the instructions about running vinegar through, then rinsing several times with water. However, the light would not stop blinking. We did by-pass the light by setting the timer for delayed brewing and it worked. However, that blinking light came on again. Then, my husband tired the vinegar wash again but instead of doing it one time, he ran the same vinegar through 6 times until the light went out! Then he proceeded with the water rinse. Our Mr. Coffee is working again!
Nov 16, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
3-Pot coffee Maker instructions
The first time you use the machine you need to make sure it is full of water - before you plug it in and turn it on. Put an empty coffee pot under the brew basket and fill another empty pot with clean cold water.
Pour the water into the coffee maker. If water comes out then you can plug it in and turn it on. The water heating tank holds about 2-1/2 pots of water so if your machine is empty you will need to keep adding water before you turn it on otherwise you may burn up the heating element.
After the green light comes on - indicating that the tank is hot you can brew a pot of coffee. This machine is meant to be left on all of the time so it is always ready to brew. If you choose to turn it off when not in use, you will need to give it about 10 minutes to fully heat up the water before you brew.
Jan 25, 2008 | Bloomfield 8571 Coffee Maker
West Bend 56860 10-Cup Coffee Maker Logo
162 people viewed this question
Top West Bend Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Ray Murphy
Pierre Laplante
Are you a West Bend Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
