Question about Sony Grand WEGA KF60WE610 60" Rear Projection Television
TV will sometimes make a funny sound and not turn on and red light blinks, but some times it does turn on-
The tv will some times not turn on and make a buzzing sound, also when this happens the red light goes green and blinks many times then goes to red blinking several times. After trying this for a few times it will come on. It never shuts off once it is on and this only happens from time to time. Any ideas. The TV was made in december of 03 and is the KF-60we610.
  • Anonymous Apr 08, 2008
    does anyone have instructions on how to change the lamp?
Old lamp, replace the lamp
Posted on Nov 29, 2007
SOURCE:
What would cause the power light to blink red and the tv will not turn on
three times red light blink mean DC Alert which is related to system in internally & some time sound ic problum
Jul 12, 2014 | Sony KDL Televison & Video
My magnavox tv model num 50mf231d137 will not turn on it turns on then turns off with red light blinking
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information google.com/+GopakumarGopalan
Nov 19, 2013 | Philips Magnavox 27MS343S 27" TV
Sony Trinitron won't turn on red light blinks 9 times
Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not re-solder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
Apr 29, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My tv wont turn on and it makes a funny sound in the tv then the red light will turn on
When was the last time you have replaced the lamp? That is the first thing I would check. What is the sequence of the red light? What does it blink?
Mar 09, 2010 | Panasonic PT-60LCX64 Television
I have a Toshiba 46hm94P. Just replaced the lamp. Now I get the TV trying to start. It will reboot 8 times, with the green light blinking 8 or 9 times while the red light is on. The TV will then turn off...
make sure the lamp cover is on because sometimes they have switches on them that turns the on when the cover is on but if its off tv might not come on. If thats not the problem then you might have a bad ballast. Call a local tv repair shop.
Jan 20, 2010 | Televison & Video
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
Try to remove the vertical IC sometimes it become Shorted causing the B+ to drop. after removing try to switch on back check the B+ if ok and the LED not blinking then change the vertical IC.
Jun 01, 2009 | Sony KV-27S42 27" TV
On older Sony, sometimes a power surge causes the set to be in shut down mode. Try unplugging for 5 minutes and then plug in and try. This many times will fix.
May 31, 2009 | Sony KV-27S42 27" TV
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Please Help
Is the red light flashing a code ? exaple 4 blinks pause 4 blinks ?
Apr 07, 2007 | Sony KV-27FV16 TV
Sony Grand WEGA KF60WE610 60" Rear Projection Television Logo
293 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
