Question about Brother HL-2040 Laser Printer
Paper jams the first page of a print job prints but then the paper jams before the next page can print. It jams before going through the ink cartridge. I've tried reinstalling the cartridge numerous times to no avail. Any help is greatly appreciated.
    Problem Solver:
  • 10 Answers
The Pickup roller of the printer is not properly aligned, send the printer to repair and see the jam
Posted on Sep 29, 2007
  • NDDIAS Oct 29, 2010
    Based on the above suggestion, I tried the following which seems to (at least temporarily) have resolved the issue of consistently jamming on the second sheet of paper.
    1. Removed the paper tray.
    2. Turned printer upside down. Removed metal panel covering the pickup
SOURCE:
Both ink and paper jam lights flashing
The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.Go To Below official Epson Printer Page For Your problem and solve your paper jam problem https://files.support.epson.com/htmldocs/cx11nf/cx11nfug/trb_e_1.htmHope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Epson Printer Support
Mar 24, 2014 | Epson Office Equipment & Supplies
Print job disappearing and not printing
1. Check for a paper jam. Paper jams occur when one or more sheets of paper become stuck in the feeding or printing mechanism. Gently remove any jammed paper and reset the printer.
2. Check ink levels. Those ink cartridges run out fast. If your printer looks like it is printing but nothing comes out on the page, you might be out of ink. Try replacing the cartridge and printing again.
3. Check for a clogged print head. If you know you have ink, the print head might be clogged. Navigate to "Control Panel > Printer > Right Click > Properties > Maintenance > Clean Cartridges" to attempt to clean the print head.
4. Reinstall printer drivers and software. If none of the above helps, try uninstalling and reinstalling the printer and software to correct possible software bugs, errors or conflicts.
Canon-Specific Issues
5. Check printer drivers. Navigate to "Control Panel > Printers > Right Click > Properties > Update Driver" to check for a new driver for your printer. You can also find drivers and software on the Canon Support site (see Resources).
6. Resolve the Waste Ink Error. Press menu on the printer and press scan/copy to enter service more. Press the right arrow to access "NVRAM." Set ABS-M level to 0. Set ABS-P level to 0. Press "Stop" to exit.
7. Resolve Wrong Cartridge Message. Turn off the printer and unplug the power cord. Remove the cartridges and the print head. Clean the print head in lukewarm water. Set it aside to dry. Clean the contacts gently with an eraser and wipe with a tissue. Reinstall the print head and reinsert the cartridges. Run a cartridge alignment.
8. Resolve E0D02 error. Clean the cartridges and the sender strip. The sender strip is behind the rubber drive belt behind the main hatch. It runs horizontally across the machine. Wipe it gently with a lint free cloth.
Aug 19, 2012 | Canon Pixma Mp250 Printer
Printing blank pages
Hi Wendy,
This is known issue with Canon printers. Try the steps below.
Instructions
    • 1
      Remove all of the paper from the paper tray and slide the paper guides all the way to the side. Examine the paper for any crumpled or torn pieces, then reload the tray. Make sure the guides fit snugly against the sides of the paper. If the guides are too loose, the paper can feed into the iP1600 skewed and cause a paper jam. If the guides are too tight it can cause the printer to grab more than one piece of paper.
    • 2
      Open the front of the printer and wait for the print cartridges to move to the center. Do not move the cartridges by hand--this could damage the printer and void your warranty.
      • 3
        Pull the cartridges slightly toward you and lift them free of the printer. Set the cartridges aside.
      • 4
        Wipe the interior of the printer with a soft cloth to remove any ink residue and paper dust. The Pixma iP1600 has a tendency to accumulate a lot of paper dust, especially during periods of heavy use. Cleaning the printer periodically is the best way to avoid problems.
      • 5
        Dip a cotton swab in warm water and carefully clean the bottom of each print cartridge. The print cartridges in the iP1600 printer also tend to accumulate paper dust. In addition the print nozzles can become clogged with ink residue, resulting in poor print quality and shortening the life of the cartridges. Continue wiping the cartridges until all ink residue and paper dust have been removed.
    Regards,
    Suhail
    May 20, 2012 | Canon PIXMA iP1600 Printer
    I have a brand new ink cartridge in my printer. It printed the test page ok. When I try to print envelopes, it always says paper jam (there is no paper jam) the envelopes just wont feed. It's a Lexmark...
    Make sure to set the correct paper setting on the printer or the Lexmark software before sending the print job. Adjust the printer's paper guide to the correct envelope dimension.
    Dec 12, 2011 | Lexmark X6170 All-In-One InkJet Printer
    Epson Stylus PHOTO R220 red lights keep flashing
    I hope this will help you :)
    * Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
    * RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
    * RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
    * RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
    * RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
    * RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
    * Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
    Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
    Reading no paper paper tray is full
    Instructions
    1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
    2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
    3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
    4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
    5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
    6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
    7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
    Jan 08, 2011 | HP LaserJet 4600 Printer
    Red light stays on and printer won't print
    My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
    Jan 16, 2010 | Epson Stylus C60 InkJet Printer
    Middle of print job - stops to CLEAN - then starts from pg1 AGAIN
    This is a simple 3 step fix
    a) Get rid of printer
    b) Get rid of husband
    c) Get new printer
    Hope this works!! :-)
    Jul 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
    A designjet 700 with a black cartridge test on every print job
    open the front door then pull the ink cartridge then cleat it from dust and ink then refix them.then try.
    aslo check there is not any paper jam.
    Jan 07, 2009 | Lexmark X1240 All-In-One InkJet Printer
    Brother HL-2040 Laser Printer Logo
    249 people viewed this question
    James Cagle
    James Cagle
    Jim Keysor
    ctnozil
