Question about Logitech LX 710 Keyboard/Mouse
Keyboard period repeats
When pressing the period key once at the end of a sentence it repeats 3 additional period dots....
  • 2 more comments
  • moke11 Jan 10, 2008
    I have thesame problem... i just wish someone could help me fix it.
  • Anonymous Jan 18, 2008
    period repeats for me as well, like this: ..........
  • Anonymous May 13, 2008
    same problem but with the E key (it sometimes repeats and sometims dosn't work at all)
    Replacd th kyboard once with no hlp :(
  • Anonymous Nov 24, 2008
    Same problem but with the "2" key. Sometimes 8 repeats, replaced the keyboard with a new one, same problem after some time.
  • 4 Answers
I have had the same problem for ever. I have found that unplugging the USB dongle, waiting 10+ seconds and than plugging it back in tends to fix it right away.
After a few weeks you might have to do it again. Annoying problem but a simple fix
Posted on Jan 24, 2008
Thanks for this i have had the problem before and they even replaced the keyboard and then same problem 6 months later, removing the dongle worked.
cheers
Posted on May 12, 2008
SOURCE:
Resync polo key 2000 how do ido it i have spare key
Remote Control Programming (1997 ON)
Procedure
1. Switch Ignition ON and leave the key in the ignition.
2. Mechanically lock the vehicle using the Drivers door using a second
key.
3. Using the remote control press the Unlock button once, and the horn
will sound once.
4. Wait 6 seconds and press the unlock button once to activate the coding
procedure. The remote control will now be programmed.
NOTE : When performing programming on additional remotes the procedure
is the same, except you press the unlock button 2, 3 or 4 times for the
different remote.
For example : If programming 2 remotes press the unlock button twice with
a 1 second interval between each press, repeat for 3 and 4 remotes.
5. Switch Ignition OFF.
6. Remove key from ignition and check for operation.
7. The coding procedure can be repeated up to 4 times for additional remotes.
8. The ignition must be switched OFF between programming each remote
control.
Mar 18, 2017 | Volkswagen Polo Cars & Trucks
Keyboard typing multiple letters/ numbers when pressing certain keys.
Keyboards on Windows computers can repeat letters when key press sensitivity is too high. This problem can be rectified by adjusting your keyboard's repeat frequency. Once this is lowered, key presses will occur slower and you will not have the letters repeated instantly.
Click"Start," then "Control Panel." Click "Hardware and Sound," followed by "Keyboard." Move the "Repeat delay" slider further to the left below the "Character repeat" option. The further left the slider moves, the longer the delay will be before a character repeats.
Feb 03, 2013 | Computers & Internet
How do I make is so it shows the sentence before it types is on the paper
There is a key on the R. end of the keyboard labeled PRINT MODE press this button until the display says delay print.
DickyO
Jan 02, 2013 | Lexmark Wheelwriter 3500 Typewriter
In MS Outlook (2003), when attempting to reply to an email, I mistakenly hit some keys and now all my replies shows the marks at the end of each sentence or line (looks like a "p" with additional vertical...
I believe you've enabled display of non-printing characters. Press "CTRL-SHIFT-8" once you've open new mail (could also mean Ctrl+Asterisk).
Good Luck!
Aug 10, 2010 | Computers & Internet
Can u use all caps when texting with this phone
yes. depending on where u are in the sentence u will either press the shift/star button about 1 or 2 times. u should be able to see when it changes somewhere near the text input box. it should go from (1)Abc to (2)ABC (if you are at the beginning of a sentence press the shift key once) (3)abc
Feb 16, 2009 | Motorola Mobility W375 Cellular Phone
Period button keeps pressing itself on keyboard
pull out the key some junk underneath my be blocking it
Jan 16, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Arbitrary periods and capitolization
When you press the spacebar twice at the end of a word, your blackberry thinks you ar finishing a sentence. Also, we you hold a key down too long it will capitalize.
Oct 08, 2008 | AT&T BlackBerry Curve 8310 Cell Phone -...
Door locks dont operate with remote key fob
Touch Key metal to lock cylinder metal then unlock
Jul 29, 2008 | 2001 BMW 325
Keys won't repeat
You may be tripping over an accessibility option. Try this:
1. Click the Start->Control Panel menu item.
2. Click Ease of Access.
3. Under Ease of Access Center, click Change How Your Keyboard Works.
4. If Turn On FilterKeys is checked, UNcheck it.
5. Click Apply or Save.
Dec 11, 2007 | ViewSonic ViewMate Keyboard
Logitech LX 710 Keyboard/Mouse Logo
340 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
