Question about Refrigerators
Amana side by side ice dispenser leaking water
My amana ice dispenser is leaking water from the top right hand corner of the ice maker, then the water freezes as it runs down and causes a big glob of ice to form, what could be the problem? thanks!
  • Anonymous Mar 27, 2014
    ice in freezer side
  • Anonymous Mar 31, 2014
    can dispense water but am unable to make ice. have tried water supply line, on off switch no ice jams?
  • 473 Answers
Take the ice maker out and look at the mold. If the coating is flaking off then that is where it is leaking. Will need to replace the ice maker.
Posted on Oct 06, 2007
SOURCE:
Water and ice dispenser does not work---the switch clicks when you press it but there is not response, also the ice maker just quit working
Three things could be wrong:
Solenoid switch where the water comes into the unit has gone, this control the flow of water into both the ice maker and the water dispenser.
If the switch is good and then you need to check your filters, sometimes inside the door top right. or on one of the corners on the bottom front.. You should be able to unscrew them with you hands.. make sure water is off behind unit or where ever your shut off is at.
One last thing.. check for kinks in the water line behind the unit if it was pulled out lately.
Aug 10, 2015 | LG LFX25960ST Stainless Steel French Door...
No ice instead water dripping down into freezer making icicles
If you have icicles, where are they forming at? If on the front of the ice bucket, then look at the dispenser shoot door is closing all the way. The way to check that is to look into the shoot while holding a flash light (or bright light) up into the dispenser from the front side of door. You should see no light.
Now if you have ice buildup around the inside of bucket, mainly from the ice maker to the bucket then you either have an ice maker that is leaking water or you have a water valve that is not shutting off all the way. Suspect water valve if you have ice buildup within water inlet tube on top of ice maker. Frozen water within tube is good indication that water valve is leaking.
Look inside refrig side of refrig, usually located on right top side of wall, you will find a tag with model number and serial number. Need both to get you the right part number for ice maker or water valve.
Oct 08, 2009 | GE Profile PSW26P Stainless Steel Side by...
Outside ice despenser is dripping, no ice
water dispenser -Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
ice maker - If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Sep 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana refigator
If the dual water valve(you'll see it in the back of the fridge where the water line goes in)is leaking this water freezes up inside the filling tube for the ice maker and when it calls for water it can't go through.Or could be this valve doesn't work, in both cases it needs to be replaced.
Aug 09, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana SBD21VE No water to ice maker
your water line to the fridge is most likely leaking. You should turn it off right away. The line turn off is either behind the fridge or under sink. sometimes its in basement. The line is very easy to replace. You can get the plastic ones at home centers for under 5 bucks.
Jun 08, 2009 | Amana ASD2326HE Side by Side Refrigerator
Ice maker will not make ice, water dispenser is working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
oypyiooiyp
May 27, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Change Kenmore fridge water filter due to slow water dispenser
what you want to look for on the filter is an arrow turn the arrow left and then pull down
Dec 09, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Whirlpool Side by Side Refrigerator
hi- there might be a switch inside freezer to turn the ice maker on and off- it will be located on the upper left corner-
Nov 22, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
414 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
