Question about Sony Grand WEGA KDP-57XBR2 57" Rear Projection Television
Trouble code 6 blinks
The tv just went out during operation. Unable to turn on. Trouble code 6 blinks. Research tells me "6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture." Is there any online schematics? I am OK at reading schematics and can work a multimeter. Just need to located the +5 line. Or better yet is there a common circuit board that i can just remove and replace?
  • cakley Sep 29, 2007
    Is there a common fix to this 6 blink issue? Such as a fuse or replace a board?
  • 363 Answers
Try going to http://getmanual.com/index.php?nav=cat_brands and type KDP-57XBR2 in the search catalogue box. There are three service documents for you there. They take PayPal or credit card. I have used them before and the documents can usually be downloded within a day if not immediately. Hope this helps.
Posted on Sep 29, 2007
  • Martin B
    Martin B Oct 19, 2007
    Did you obtain the schematics and is there anything else I can help with?
SOURCE:
Tv turns off red light blinks 9 times
Sony tv led and blinking codes
  • 0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty.
  • 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
  • 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
  • 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
  • 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
  • 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
  • 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
  • 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
  • 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
I hope this will be of some help to you
Mar 22, 2012 | Sony Televison & Video
Will only turn on for about 3 second with no picture and then turns off. Standby light blinks 6 times
For the KV30HS420, 6 blinks, pause, 6 blinks, etc. means "LOW +B OCP/OVP (overcurrent/overvoltage)" and the probable cause locations listed are as follows:
1. +5 line is overloaded (A, B, M boards)
2. +5 line is shorted (A, B, M boards)
3. IC504 is faulty (A board)
hope this helps John
Jan 11, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Cutting off
Try the following to see what exactly the 6 light blinks mean.
To see the diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power.
This brings up a screen with a list of the problems and number of times they have occurred. This will tell you what is happening and see if it's worth fixing.
Also, have you tried unplugging the TV for a few minutes? if it's some kind of computer error, unplugging it will allow the error to clear and possibly allow the TV to work again. Just an idea to try in case the error code doesn't tell you.what is wrong.
May 22, 2010 | Sony KP-57WS500 57" Rear Projection...
Sony KP-51WS500 turns red ,shuts off, led blinks 8 times
Here are the fault codes for your tv and what components are affected:
I have seen the tube divider pack cause this too, Take the front speaker grill off remove the 4 screws and the panel comes off. There is a pack with 2 red 2 green and 2 blue adjustments, Try turning the BOTTOM red one down 1/32 a turn and see if the symptoms change
Apr 03, 2010 | Sony KP-51WS500 51" Rear Projection...
Sony kp65wv700 tv blinks 7 times - Horizontal deflection issue is what manual is telling me. My question is what transistor/chips I need to replace and if anyone has done that to fix this problem...
Feb 26, 2010 | Sony KP-51WS500 51" Rear Projection...
I was watching my kp61v80 and the screen went black-can you give me the trouble codes for the flashing standby light
Diagnosis item
TIMER/STANDBY
Indicater
Number of blinks
Supposed malfunction Condition
Self-diagnosis
screen display,
Diagnosis item: Results
•Power not ON 0
[Standby Power Supply System]
F601 open.
R607 open.
Q601 short circuit
[Main Power Supply System]
IC601 and R612 are broken.
VDR601 short-circuit
Cannot turn on the power.
LED doesn't blink.
+B OCP detection 2times Short circuit of power supply system in each circuit.
Goes to the standby mode
Short circuit of +B line
2 : +B OCP 000
+B OVP detection 3 times
T603 pin 78 open.
R672 open.
Malfunction of power supply circuit
3 : +B OVP 000
Vertical deflection stop 4 times
IC1509(V out) is broken.
Q1505(V Pulse Buffer) is broken.
Raster goes to one line horizontally, Aand then video
signal is muted.
4 : V Stop 000
Video out abnormality detection 5 times
Video out, Q705, 732, 761 and others in C board
circuit.
Q218, 219, 220 (A board)
TIMER/STANDBY LED blinks approx. 30 seconds,
and then blinks for the self diagnosis.
5 : AKB 000
Horizontal deflection stop 6 times
C515, 516 open.
IC206(YC Jungle) is broken.
Raster doesn't appear. 6 : H Stop 000
Audio abnormality detection 8 times
IC406(Audio amp.) is broken.
PS401, 402 open.
The sound is not out.
8 : Audio 000
Jun 17, 2009 | Televison & Video
No picture.red light blinks 6 times
I would need the model number in order to help you with the error code . Please respond to this same post. thanks
Jun 28, 2008 | Televison & Video
Kdf-55wf655 power led light blinking six times
Most Sony 6-blink codes for projection TVs follow this pattern:
Jun 13, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
SONY KDP 65WS550
are you sure it 10?
these are the codes i have
· 0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty.
· 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
· 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
· 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
· 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
· 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
· 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
· 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
· 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
Hopefully, the descriptions of the blinking lights and the symptoms and problems will point you in the right direction to tell the problem with you Sony Projection Screen Television. If it is not enough, do not worry -- in the coming few posts I will talk about entering the Diagnosis and Service modes for your television set!
Mar 13, 2008 | Televison & Video
Tv just shut off and red light is flashing
Mar 07, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDP-57XBR2 57" Rear Projection Television Logo
104 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
