ZANUSSI WASHING MACHINE
My Zanussi FJDR 1666W Jetsystem 1600 keeps flashing up E20 and I dont know what this means
  • 5 more comments
  • dinos j Dec 02, 2007
    zanussi xc6 keeps displaying e20 code on drying cycle
  • lesles Jan 27, 2008
    My Washing machine Zanussi Jetstream keeps flashing the code E20, and i cant finish the wash,Does anyone know what it means, i cant find the manual
  • Anonymous Jan 29, 2008
    Also having problems with progressing through cycle.Did everything the manual suggests;clean filters etc; Still no joy.Has anyone solved this problem
  • Anonymous Feb 13, 2008
    keeps flashing err20 when i try to wash clothes
  • Anonymous Mar 10, 2008
    err20?
  • Anonymous Mar 11, 2008
    WASHING MACHINE SHOWING E20 FAULT
  • marie88 Sep 09, 2008
    washer flashing e20 half way through cycle and wont empty
Seems to be a problem with the filter. was with mine.. one thing i always forget to clean it regularly.
Be careful when open the little hatch thingie , there will be water coming out . so prepare with a bakingtray and kitchen towels. and open it SLOWLY!!! so the water doesnt totally soak the floor.
then clean clogged up filter. at least that solved the problem in my case, hope it works
Posted on Dec 29, 2007
I found that it displays this message when the outlet to the sink is blocked. It is normally blocked with fibres at the drainage end. hope this helps
Posted on Sep 01, 2008
2 Suggested Answers
SOURCE: ZANUSSI WASHING MACHINE
I have taken out the filter and washed it thoroughly! Also flushed the out pipe to make sure the whole system was clean. This resolved the problem
Posted on Feb 08, 2009
Washing machine keeps stopping
E20 not draining error. Since you checked filter at bottom right corner for blockages, then maybe the drain pump has gone faulty or something jammed in it. You can also check the drain hose for kinks or blockages. You can try blowing out any cloggs in the machine with an air compressor.
Please let me know if you need any further help, otherwise good luck on fixing your problem.
Apr 13, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
May 19, 2010 | Zanussi FJS1225W Front Load Washer
How to clean a Zanussi Jetsystem 1400
on my mums zanussi,, after opening door, machine had not drained and spined, closed door again could not get machine to go,, this time could not get door opened..there is power to machine.
May 19, 2009 | Zanussi Washing Machines
Dec 19, 2008 | Zanussi FJD1666W Front Load Washer
I have a zanussi jetsystem iz16s and it keeps pausing just after its filled up with water and coming up e20 (I think thats the error code) any ideas what the problem might be.
Sep 11, 2008 | Zanussi FJS1225W Front Load Washer
Heating element
hi yes they are different the fc1200w element is 1600 watts (£31 part 150867200-1)the jetsystem zwf1658 1900 watts its always better to use the correct part.
May 03, 2008 | Zanussi FC1200W Front Load Washer
pull the machine out and put the drain hose into a bowl to empty the water out when you have emptied it try cleaning the pump filter and check the drain system for blockages if that is ok then it looks very much like your door interlock is duff good luck and rate me.....
Feb 17, 2008 | Washing Machines
Zanussi jetsystem 1200 wahser dryer problem
You usually turn off your inlet valve after your washing is done. Well, if it keeps filling after u hv turned off, you have a problem with your inlet valve, which you should replace.
Oct 07, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
883 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
