Dell Inspiron 1750 Laptop Logo
A
Anonymous Posted on Oct 25, 2013
New battery, but says plugged in not charging
2answers
Dell n5010 not chargering
Hi Anonymous,
Request you to try following the below steps which might help:
    (1)Check if the AC Adaptor gets detected in BIOS (F2 at startup).
    (2)Check on the status bar for any messages like "Plugged in charging", "Not connected", etc.
    (3)Try using a known good AC Adaptor and check if that helps.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
HP Mini 2140 "Plugged in, charging" but not charging
Hello jorel, most likely its a failure of the system board particularly the charging section, a broken pin or a loose terminal. work will be internal, suggest you do away with the battery. its better to operate it at home, or bring the charger with you. Maybe its time to get a new one.
New battery won't charge
Some inexpensive batteries do not play well with your laptop. Take a look at "Plugged in, not charging" SOLUTION!!!" :http://forums.cnet.com/7723-19681_102-345945/plugged-in-not-charging/
What will happen if the battery in your laptop is not fully charging
That would mean your battery is dying and you need to go buy a new battery for your laptop. You can buy new batterys for around $40
Find a store that sells laptop parts or go online look on amazon or next tag also when you get your new battery plugin your laptop charge your new battery so it has a full charge.Then when it is done charging unplug it and use the battery until it dies, then plug it in again to recharge it never leave it plugged in if it is fully charged for long periods.if you are using your laptop at home you can pull out the battery and use it when its plugged into the wall this will help to extend your battery life just make sure you have a fully charged battery before leaving your house. always unplug your your laptop when its is fully charged this will also extend your battery life for along time
Battery won't charge
So put the old power cord back on since you say it charged the battery normally. Why did you change it if it was charging the battery? It's quite possible that the new power cord is faulty. Just because it is new does not mean it works.
Remove the battery and plug the new power cord in. Does it boot the laptop up? Are you able to function with the new power cord plugged in. If so, then your battery is more than likely dead and needs to be replaced. The battery only has a useful life and once it is completely bad it will not charge.
NEW Battery not properly charging
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
3helpful
2answers
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Pavillion dv4 new battery only charged one time.
How long did you leave the battery for charging?
2answers
New hp laptop battery will not charge w/plugged in AC and turned
You probally have a dead motherboard port that charges the battery.
Sony dsc-s600
1= Use rechargeable battery cells and must be fully charged.
2= Check battery terminals in camera battery compartment. Must be cleaned and shiny.
3= Sony camera DCS-S600 won't charge batteries through USB cable plugged in PC. You need external battery charger to charge battery cells.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
