Question about Ahead Software Nero 6.0 (60045) for PC
Loading software caused hanging on startup
I use windows 98 and had a CD Writer installed. After installation of the Nero software everything loads but I cannot get into "start"!
  • 167 Answers
Re: Loading software caused hanging on startup
May be your windows 98 is damaged and need to be re-installed. Even if you reinstall windows 98, there are more chances of your getting your documents back. I meant to say that just reinstall and to not format. you may get your windows running again. You should have your windows 98 installed with DirectX 9.0C and internet explorer 6.
Posted on Oct 04, 2007
0 characters
3 Points
Reinstallation of nero 12 in same pc
Try this-
run msconfig.exe.
In the services tab, check the box to hide all Microsoft services, then, check the box to disable all services.
Under the Startup tab, check the box to disable all startup items. Reboot.
Right click on the .exe file for installation and select "run as administrator". Try the installation.
Whether it works or not, go back to msconfig.exe and restore everything back to normal and reboot, as soon as possible.
Nov 11, 2013 | Nero Software NERO Download - Nero 12...
Nero express will not load on windows 7 T4300 Packard Bel on trying to install . The computer will not read the properties to open the disc to get the .exe file So I cannot list the file to install via...
The Disc must be full of scratches so there must be Problem reading CD. Borrow Nero 6 CD from your friend and then install. Nero 6 sometimes also comes in Motherboard Drivers CD, try to find it.
May 18, 2011 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Hi can u pls. help me bec. i can't install my realtek ac'97 audio controller. error code 10. thanks ryan
Hi Ryan,
Thanks for using Fixya.
Here's a link to Microsoft's error code chart.
Although MS recommends re-installing driver, that does not always work. Error code can also be caused by a device (IRQ) conflict. Have you added any PCI cards to your PC?
First step is to install chipset and mobo drivers as recommended by nobus. If no help, follow oldgreyguy's recommendations.
a BIOS update should not be required.
I had exactly the same problem whilst trying to install a TV CARD with Nero 6 over Realtek AC97 on board sound card. I resolved by uninstalling Nero, sound card drivers and the TV card hardware, down loading the latest drivers for the sound card and TV card and loading in order, first sound card then TV card then Nero 6. Hope this helps. This took me a week to resolve so best of luck.
- Hotratchet
Nov 03, 2009 | Computer Utilities & Maintenance
I have the same DVD Writer and sames DVD+R DL from Memorex and its not working with ImgBurn, CloneCD or Nero. LG DVD Writer isnt compatible with memorex
Sorry you should install drivers for Memorex.OR
Try Magic ISO and open the drive and write it
Convert the CD or DVD Image into hard disk it will work surely
Jul 07, 2009 | Ahead Software Ahead Nero 6.3 Suite 1...
Computer locks up when I install NERO 7 essentials. I had a 1 yr. old version when I built the computer and it worked great. I bought a new lite-on burner and received this new software. Installed it...
well ok the reason it locks up is this see you hade nero on you computer once before although you removed it from add remove programs you still dint remome all of it see heres what to do dont install nero 7 yet go to c drive and look for the comon folder open it and you see everything that you removed you can clear this folder it want hurt the pc and if windows want remove some files in it well there is a wat tiy do that you have to go past windows if you can remove it fine if you cant download revo uninstaller aand ues the auto run part you see all the programs the auto run in it get rid of the old nero in it and as mug of the programd that you are not using any more then resart you computer check how much hard drive free space tioy have if the drive is full it will lock up to so after you restart you have to use a registry cleaner for the things you removed use comodo registry clearner you have to down load it from the comodo site no after you done all this and removed all the orphened files restart you computer it will say finalize click yes and windows will continue loading and thin try to load nero 7 again it shoul load and the computer shouyld not lock up
May 04, 2009 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Help !! no nero plugin ,can not burn dvd's
hmm, this might be a stupid sugestion, but, did you chose your DVD burner, or did you chose Write an image file?
in one step, it says you got to chose ur burner, or your image writer...
check that...
Jan 17, 2009 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Nero express
Maybe you have some other writing software installed that stops nero seeing your drives. Uninstall that software and reinstall nero.
Aug 02, 2008 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Installation of Nero7 failed
Hi !
hereVisit the nero support site and use the nero cleaning tool to make sure all traces of it are removed before a fresh install.
have a nice day
Mar 03, 2008 | Computer Utilities & Maintenance
Nero burn CD with different speeds.
Your burner can only achieve high speeds towards the end of the burning progress as the data burned reaches the outer areas of the disc. Burning starts at the center of the disc - the more the laser moves towards the outer end, the faster the burning speed gets. I have a 20x burner and 18x discs, and every burn starts at about 6-7x and then gets progressively faster, until the last 20secs of the burn it actually burns at 18x.
Feb 19, 2008 | Ahead Software Nero 6.0 (60045) for PC
Nero Express Cd Writer
Open contents of CD, look for INSTALL icon. Double click on same
Oct 31, 2007 | Ahead Software Nero 5.5 (NERO5.5) for PC
Ahead Software Nero 6.0 (60045) for PC Logo
366 people viewed this question
Top Ahead Software Computer Utilities & Maintenance Experts
Gareth Cockram
Gareth Cockram
Barbat Nae
Barbat Nae
Are you an Ahead Software Computer Utility and Maintenance Expert? Answer questions, earn points and help others
