SOURCE: Battery light stays on even after comp is turned off or the battery charger is unplugged
hi, sounds like you need to replace your hard drive, blue screen of death means 2 things bad memory or hard drive regards
SOURCE: Panasonic cf 48
Try hitting F8 right when Windows starts up. You will get a text menu with options. Try "last known good configuration" and see if that helps. If it doesn't you may be able to get it working by reinstalling XP and choosing "Repair",which will try and replace all your windows files with the original ones.
If that doesnt work then you will have to reload XP from scratch. If you have to do that then install service pack 2 before any other software or drivers.
SOURCE: no power
Most times when this occurrs, there is a problem with the power supply inside the unit. It is possible that the motherboard is not telling the power supply to turn on. Any time the computer is plugged in, the power supply provides 5V as a standby voltage. Pressing the power button sends a signal for the remainder of the power supply to start up. If the 5V supply is not present, no action will occur. Try replacing the power supply.
Dan
SOURCE: keyboard not responding
Solution. My wireles keyboard stopped working except for the F-Lock key, the Media key and the sleep key. It wasn't batteries, even though I tried, communication was there because the above keys were working. Remove the batteries from your keyboard and let it sit for about 10 minutes. Press the red connect button a few times and other various keys every few minutes during that time. This may be the whole "capacitor discharge" trick, but I tired that with someone elses instructions and my keyboard did not work after 2 minutes of key pressing. I think it just needed more time to clear out the secure settings. Good luck, I was about to trash this keyboard until I tried again
SOURCE: Dell Dimension 3000
Not sure I understand your question. If you want to replace the CMOS battery, here is a link that shows location and procedure: http://support.dell.com/support/edocs/systems/dim3000/en/SM/parts.htm#wp1076111
You can also run diagnostics located on a Dell CD that you should have received with your computer. Look for one that has “Diagnostics and utilities” listed under the “Contents”. You will have to boot from that CD disk. To do this, power on your computer and tap the <F12> key to bring you to the “One time boot menu”. Insert the CD into the top CD/DVD drive and then select “Boot from CD/DVD” and hit <Enter> key. Select the “Run the 32 Bit Dell Diagnostics”.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
