Question about Pioneer VSX-D511 Receiver
Internal cooling fan not spinning
Hiya I have a pioneer vsx-d511 receiver and have just noticed after 5 years of use that the internal fan never spins up. I have noticed that it has three wires going to it, so I was wondering whether it was temperature or volume controlled. However if it is supposed to spin at all times, can a replacement fan be found? Thanks Sam
  • majinbuu Oct 03, 2007
    Since you didn't post my email solution to this problem, here it is again for others in the same boat.
    The fan is thermally controlled, it will only switch on when the unit becomes extremely hot. Otherwise the built in heatsinks will dissipate the heat. Therefore, unless you use the receiver with high volume levels for extended periods of time the fan may never turn on.
    Again I say that this site is very snobbish. I am sure some of the users here could have answered this question easily, however I had to contact pioneer directly for an answer. Ban me I dont give a crap, this site stinks. I bet I would have gotten an answer if I had paid for the premium service.
    I post this for the benefit of other users who have the same problem.
  • erik51 Nov 10, 2007
    i agree with you. i noticed my receiver gets hot to touch and the fan doesnot turn on can this be fixed? and how?
    Problem Solver:
  • 8 Answers
There should be a thermistor mounted on the heatsink which will trigger the fan. The fan will not likely turn on if you are using your receiver for 2-channel music. Try using all amp channels by playing a DVD in DTS or AC-3 audio mode and crank up the volume - lots of bass will do the job. You can place a piece of tissue paper near the vent so you don't have to use a flashlight to watch and wait until it turns on. My receiver takes about 3 songs from the Eagles DTS DVD at high levels before the fan would turn on. As soon as the temperature is lower than the limit, the fan would turn off.
Posted on Feb 02, 2008
My pioneer vsx-518 has a noisey cooling fan, is that normal?
Before replacing the fan, check for loose mounting hardware and cracked or damaged blades
Feb 09, 2013 | Pioneer VSX-518-K Receiver
My amplifier when i put it at -50 and more it write overload .....pionner vsx-d511
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Apr 27, 2011 | Pioneer VSX-D511 Receiver
Only Left Speakers Work
CHECK THE MENU,,SETTUP ,,NO RECIEVER NEEDEED,,IF NOT CHECK THE RAC JACKS
May 14, 2009 | Pioneer VSX-D511 Receiver
Pioneer vsx-d511 amp error
I've had the same problem for over a month and have yet to find the time to get to it. However, I there may be a fuse on the circuit board that needs to be replace. That's just my guess.
Hope it's the solution.
Sep 08, 2008 | Pioneer VSX-D511 Receiver
PIoneer VSX-D510 power issue! pleas help!
Must be the protection circuits kicking in. One or more amp channels must have blown.
Feb 01, 2008 | Pioneer VSX-D511 Receiver
No sound
I have the same problem. It worked before and now the sound is gone. If I put it on tuner and turn it up all the way I can hear a little bit
Dec 14, 2007 | Pioneer VSX-D511 Receiver
Pioneer vsx-d511
Clark, you MIGHT have a simple problem here. Let's keep our fingers crossed... This problem generally has more to do with the speaker WIRES or their IMPEDENCE than anything else, even though the receiver displays "AMP ERR." (Technically, it IS an amp error, but the source MAY not be the amp!) The very FIRST thing we need to do is check to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. (Pioneer says 6, but that's not necessarily a good recommendation, particularly if you listen LOUD.) Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: Your receiver has internal overload protection systems to prevent permanent damage. On SOME Pioneer models, these can be "reset" but you can't do it yourself. Your dealer or authorized service center must do so.] But, before you take it in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. 1) Visually inspect connections at the receiver AND speakers. You might find something obvious! Look for bare wires touching one another. Again, you must look both at the receiver, AND at the speakers. 2) If everything looks okay, then disconnect ALL of the speakers at the receiver; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the right front, test the system, and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. Hopefully one of these simple fixes will get you up-and-running. Good luck!
Jul 02, 2007 | Pioneer VSX-D511 Receiver
Pioneer VSX-D511 Receiver Logo
250 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
