Zanussi IZ141W Front Load Washer
Problem for Zanussi IZ141W Front Load Washer
Problems with machine resetting itself
By willywonka on Sep 29, 2007
ello there my machine washes normaly but when it goes 2 drain it reset the timer back 2 3 mins any help please
Same Problem
Dec 01, 2009
-   We have a new Zanussi washing machine. The cycle starts normally with time etc showing countdown during wash. However, after 15 mins or so, it resets itself back to beginning. The start/pause button flashes repeatedly but when you press this it does not restart. I had to forward cycle onto drain to empty machine. The drain would only empty for 2-3 seconds then had to repeat drain mode. Does anyone have any ideas to suggest. Thanks-   LittleNoel
Solution #1
posted on Sep 29, 2007
Not Rated)
barnsleymick
Rank: Guru
Rating: 87%, 385 votes
this sounds like it could be a pump problem as you said the machine works fine till it starts to drain the water out, check the pump for open circuit electrically, if that is fine then check for blockages from the drum to pump pipe and any filters it has, also check the waste outlet pipes etc
start from there and see how you go,
if i have helped please rate me
Was this helpful?
Yes
No
Popular Solutions for Zanussi IZ141W Front Load
Questions and Unsolved Problems for Zanussi IZ141W Front Load
Do you recommend Zanussi IZ141W Front Load Washer?
Answer
Answer
Need to change the drain hose on a Maytag Neptune MAH3000 - there is a metal plate over the end of... (More)
Answer
need service repair manual for model 10.28882790
Answer
would you need to replace the entire drum of a Zanussi IZ141 when the bearings are going
Answer
After each wash the conditioner is still in the conditioner compartment
Answer
Hi My Zanussi IZ141S has all the programme lights on however when you press the start button it just... (More)
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in Newport, KY
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
