SOURCE: removing bearing from rear wheel 03 ultra classic
you could use a blind hole bearing remover w/slide hammer these bearing are suppose to be tight and straight.if they are removed and installed wrong you could ruin the hub. Harley switched to sealed wheel bearings in 2000 earlier models were tappered bearings.
SOURCE: 2004 FLHTCUI ULTRA CLASSIC..TRYING TO WIRE UP FOR
chk backwards to your turn signal control unit. The brake lights and rurn signals are routed in a way that would affect each other.Is this a four wire or?Chk fuses 1st. Good Luck- -Ned- A good grd is important.
SOURCE: putting my farrin and headlight
If it's shaped like a "W", it goes in the chrome headlight ring to hold the light in. You might try going to http://www.bikebandit.com . Look up your year model bike or one close to it and they may have an exploded view of the light assembly. I don't know if it'll tell you what you need to know.
Good Luck
steve
SOURCE: tail light wiring on 1990 harley ultra classic trike
I can step you thru it, but, honestly if I did it may take the both of us weekes to find the issue. See on the early to mid Evo baggers, the wiring whent a little crazy, with relays under the headlight instead of the seat, and alot of the wiring for the rear goes thru the front.
Unfortunately, I would say, take it to a reputable shop in your area, and have them diagnose it properly and repair. If I were to guess, I would say a ground is loose somewhere, but, again, on those bikes, its better to take them in and do it there.
Sorry
SOURCE: up grade radio on my electra glide classic
YOU SHOULD LOOK UNDER SEAT SOME BIKES ARE PREWIRED AND MIGHT HAVE THE PLUG FOR THE TOUR PACK ALREADY THERE WITH A WEATHER SEAL PLUG DEADEND HOPE THIS HELPS
