Question about Gem Sound DJ-2100 Turntable
Pitch Control Dear Experts, I have been using m-audio torq which shows the exact pitch change i am having on my turntable. My pitch control on the turntable keeps changing by +/-1% and at -1% the reading gives me a 3.2% and it isn't accurate at all.. could you please help me fix it.. Thanks Dj Pio
  • Pio C Sep 30, 2007
    the problem is not from the mixer.. the problem is from the motor or the pitch controller on the turntable -
    Thanks Anyways
  • tousyman666 Feb 05, 2009
    i have the same problem i bought this gemini cdm 3600 and the pitch gos from 0 to .7 than up by .2 very hard to control
Use tap button your mixer to get exact bpm if you dont havr this , buy a new mixer i suggest pioneer 800
Posted on Sep 30, 2007
SOURCE:
My stanton t50 turntable plays too fast even when the pitch fader is at the slowest speed
You need to calibrate your pitch control. This requires a small precision screwdriver (similar to something you would repair eye glasses with). If you look under the turntable where the pitch control is you will find 2 small holes, 1 marked 33 and 1 marked 45. Turn the turntable on and set the pitch control lever to zero pitch. While the turntable is spinning insert the screw driver into the pitch calibration hole under the turntable and twist the potentiometer back and forth until the turntable pitch is zero (I believe clockwise is faster, counterclockwise is slower as you look up from the bottom of the turntable). This is a fine tune adjustment and will not require much turning to adjust the speed (1 or 2 mm's) either way should start to bring you into zero pitch. The platter speed can be verified by the little dots on the rim of the platter. They should appear stationary in strobe light on the power switch when you are at zero pitch. When you are adjusting the speed you will observe the dots on the platter rim spinning clockwise and then counterclockwise as you adjust the fine tuning. Fine tune the speed until the dots appear stationary and you will be back to zero pitch. You have to adjust the turntable at both speeds 33 and 45 using the correct fine tuning hole under the turntable. My personal experience is it is easiest to do this with 2 people. 1 person to hold the turntable level and running, while the other adjusts the fine tuning. Hope this helps.
Oct 22, 2009 | Stanton T.50 Turntable
One of my technics' 1200 turntable's tone gets too high
You can try adjusting the pitch's gain, which is located on the pitch control circuit board. Only problem is that you'll have to take apart your turntable in order to get to that section (its on the bottom).
If that does not work, your pitch might be bad, or one of the main circuit drive IC's might be bad.
Hope this helps some.
- OPTiC
Master Tech, 1200s.com
Technics Parts : DJ Repair
Aug 27, 2009 | Technics SL-1200MK2 Turntable
Pitch Control issues on Technics 1200 mk2
The pitch pots have been altered.
there located under the platter & cover on the main circuit board.it's a peace of **** to sort them.
if you help e-mail me [email protected]
Jul 20, 2009 | Technics SL-1200MK5 Turntable
Sound wavers (speeds up and slows down)
you need to replace the Pitch controls. I'm presuming it is a sliding pitch control. Use the Red start stop lights that reflect on the rotating wheel. put the pitch in center 0. does one row of the dots on the wheel stay completely still.now just turn it up op down a bit until it starts to move the dots slightly. now watch the dots now while there moving. Do they fluctuate they should be smoothe. do this on both decks to find out which one is fluctuating.
Jul 10, 2009 | Philips gemini XL-500 II Turntable
Turntable spins too fast at both speeds
this is belt driven turntable....have you tried adjusting it via the pitch control or even getting another belt for that turntable....
Apr 12, 2009 | Audio Technica AT-LP2D Turntable
Stiff Pitch Adjustment
What did you open up? The top of what? If you could be specific, I can direct you.
If your pitch is stiff, try spraying some contact cleaner or similar - DO NOT USE WD40. Use an electrical contact cleaning solution, such as CAIG DEOXIT or CAIG FADERLUBE both work very well, and are good for electronic contacts.
If this does not work, then maybe the pitch control knob/shaft is slightly bent? Any physical damage?
Other than that, there isn't a whole lot you can do, unless you replace the pitch control - Technics Pitch Control.
- OPTiC
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Feb 14, 2009 | Technics SL-1210M5G Turntable
Platter changes directions or stops
More than likely either an issue with an IC (integrated circuit) on the main PCBoard such as IC301 (Pitch Control IC) or one of the Regulators like Q2 and Q3. While your at it, you might want to check IC201 (Turntable Control IC), and IC101 (Turntable Drive). Doesn't sound like anything is busted just yet, if it comes and goes. This means something is about to fail, and your just seeing the failure in action.
Good luck.
- OPTiC
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Feb 01, 2009 | Technics SL-1200 Turntable
Broken pitch control
Yep, time to replace the pitch control. You can attempt to do this yourself, however good soldering skills are required (not the time to learn). You will have to desolder the old pitch control, and solder on the new one. Which is why I say, now is not the time to practice soldering on your turntable. You could actually cause more damage.
If after replacing the pitch control, you still have the same issue, then there is something wrong with the drive on the unit. The drive is controlled by various integrated circuits (IC's), and they are known to short out every now and then. The problem is isolating the correct IC. FYI, Technics is starting to discontinue parts, and 1 of the main IC's on this unit is no longer available (IC302 - Nand Gate).
You can order the PITCH CONTROL HERE.
DJ PRO LAB
www.DJPROLAB.com
Apr 06, 2008 | Technics SL-1210 Turntable
PITCH CONTROL PROBLEM
The reset button disables your pitch control and allows the turntable to rotate at TRUE "0" (zero). FYI, these turntables were NOT made for DJing. They were made for radio, studio, and high end home use. They became DJ turntables, because they were perfectly built for the trade. So, the pitch reset button is more of a function best suited for radio stations or a producer who needs to record or play at a true zero speed.
Now, on to your question...
More than likely you just have to calibrate your pitch control. There are various videos on YouTube on how to do this properly. Just do a search CALIBRATING 1200s or similar. FYI, all the Technics SL1200/1210 MK series are the same inside. MK2, MK3, MK5 - so don't worry if you only find videos on calibrating MK2's or MK5s - works the same on all the models.
- TERMiNAL OPTiC
www.DJPROLAB.com
Apr 01, 2008 | Technics SL-1200M3D Turntable
SL1210 mk2 pitch problem
You lack the proper tools to calibrate the pitch. Here are is a tutorial on calibrating your unit: http://www.djproaudio.com/cgi-bin/Help/kb.cgi?do=read&id=18&lang=en Also, that decal on the turntable that measures speed, is not an exact science. It's just an indicator to give you an estimate of the speed your turntable is rotating. It's not to be used as an exact measurement. Over time, pitch controls tend to drift from their original settings. Calibrating it back to factory specs might fix the problem, however, there are various other factors which control the drive of these turntables. So, if this does not work, the problem lies somewhere else - usually within 1 of the 3 IC's.
Sep 06, 2007 | Technics SL-1200MK2 Turntable
Gem Sound DJ-2100 Turntable Logo
104 people viewed this question
Top Gem Sound Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Lawrence Oravetz
Are you a Gem Sound Audio Player and Recorder Expert? Answer questions, earn points and help others
