Question about Wave Industries OLY-OL3000 Globe Phone
Noisy My OLY-OL3000 Globe is very noisy. sounds like bad bearings in the motor. Ron
I had the same problem with mine. The only solution we could come up with was to place a small towel/washrag underneath it, and wedge it into something if you can. This solved our problem.
Posted on May 14, 2008
SOURCE:
Motor is very noisy
Noisy motor indicates bearings on the shaft are going bad. This happens when you have a shaft seal leak and the leaking water is getting to the bearings. Sounds like you need to replace shaft seal and set of shaft bearings. Easy fix is to replace the motor only for about $150.00 for motor replacement. Around $40.00 for seal and bearings and some of your time.
May 31, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
Caller ID does not work
try going to your phone settings and go to calling settings you should be able to disable and enable it there.
Jul 28, 2009 | Wave Industries OLY-OL3000 Globe Phone
I need an instruction manual for the info globe
This should help out.  You need adobe acrobat to view it.
http://www.smarthome.com/manuals/5109.pdf
Jan 19, 2009 | Wave Industries OLY-OL3000 Globe Phone
Need Repair for OL-3000
All programing functions are controlled on the main (stationary) board. All display functions are controlled on the Rotor (spinning board.) Here are some steps to take if you are having display problems. Remove the three mounting screws that hold the rotor to the motor shaft. The LED display board is attached perpendicular to the rotor board and is soldered to the rotor board. Over time, the connections break due to the centrifugal force of the spinning rotor. CAREFULLY, with a low amp solder iron and a fine tip, re-heat the board to the display. That should solve the problem. If you were a bit sloppy with the solder, remove the solder with a fine wick and try again!
Sep 16, 2008 | Wave Industries OLY-OL3000 Globe Phone
Globe caller id
If you're into punishment, it looks like Sharper Image has one for $50.
You might want to call first (317) 574-9250
Carl
Sep 01, 2008 | Wave Industries OLY-OL3000 Globe Phone
Manuel/instruction for info globe with caller id and scrolling features
check amazon.com olympia OL3000 scroll down to product product details
click product manual pdf can print from there g l
Jul 18, 2008 | Wave Industries OLY-OL3000 Globe Phone
Will not power up, need replacement wall plug
Radio Shack can hook you up. Take your old transformer to them and they will help you out.
Jul 09, 2008 | Wave Industries OLY-OL3000 Globe Phone
Wave Industries OLY-OL3000 Globe Phone Logo
120 people viewed this question
Top Wave Industries Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Wave Industries Lands Phone Expert? Answer questions, earn points and help others
