Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio Exilim zoom Lens Error
When I switch it on the lens comes out crunching and grinding. Never manages to focus, and I can't get it to zoom any further. Is this repairable by me, or shall I take it to a shop, or just get another?
    Genius:
  • 2,985 Answers
Get the next one is probably the best bet. The motor mechanism is either damaged or dirt has got in. Parts can be a problem and the hour rate just to look is a good chunk of the replacement price. Check out Casio website first - support but I think you will go for the new one once you see a repair price
Posted on Sep 29, 2007
SOURCE:
I own a casio exilim ex-z850. it has been showing a lens error, every time i try to take switch it on. the memory card is fine, i view the pictures. but the lens wont open up or anything. please reply...
This error indicate that focusing ring got stuck or jammed due sand, dust, may be due to external shock caused by dropping the device.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
  • If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move onces or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Sep 11, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
Les Error, cannot get in focus when in auto focus. I when itry and use the zoom I get a lens error and retry power on
the lens unit was not extend properly and cause of turning off once you turing on and zoom out.If you can open the camera and get the lens unit. Try to open the lens unit and clean it and try to rotate to the maximun position but dont put too much force. if you cannot do that bring it to service center
thank you
Jun 17, 2010 | Casio Exilim EX-S500 Digital Camera
My Casio Exilim EX-Z80 wont turn on
The lens barrels are jamming someplace. wen the camera moves the lens out immediately pop out the battery so that it stays and then turn the zoom from the outer most barrel in the direction it comes out side. Do not force it too much. If that works fine other wise take it to the service center
May 01, 2010 | Casio Exilim EX-Z57 Digital Camera
Exilim EX s600 lens grinding on extension
I had the same problem and I left it on the charger over night and in the morning I turned it on and the lens extended smoothly with no noise and is now focusing
Nov 14, 2008 | Casio Exilim EX-S600 Digital Camera
Casio Exilim EX-Z70 lens error
yes I can help you lens zoom motor is out or the gears are stripped. goto www.digitalcamrepair.com for more help.
Jun 12, 2008 | Casio Exilim EX-Z750 Digital Camera
Casio EXILIM camera lens will not extend fully!!!
Try plugging the PC interface cord into the external connector. No need to hook it up to your computer, just plug it in and out a few times. Then try to power up the camera.
Good luck.
Zductive
Jun 02, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
It's the focus lens gears. The often times get knocked out of alignment by an impact, or debris gets in there. This can be fixed, but Casio won't help. Hint...google my username. ;)
Jan 21, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
My Casio EX-600 makes clicking noises when the lens comesout.
Lens error. send into casio repairs and they will fix it for you.
Sep 09, 2007 | Casio Exilim EX-S600 Digital Camera
Lens does not come out anymore- crunching sound!
Sounds like there might be some kind of lens damage. If you call Casio repair center they may be able to give you a ballpark figure on what it would cost to send it in and have it fixed. The way you described it sounds like what they call a "lens error". Give them a call at 800-706-2534 and then keep choosing option 1.
Jul 24, 2007 | Casio Exilim EX-S500 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
130 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
