Question about Canon PIXMA MP160 All-In-One InkJet Printer
E3 (paper jam) error. I cleared everything and pressed the reset button but the e3 stays on.
  • 4 more comments
  • Anonymous Nov 02, 2007
    Tried the suggested method to resolve the E3 issue, however had no success. Any other suggestions? I've just replaced the black ink cartridge, but that had no effect.
  • jake23fj Nov 15, 2007
    i have the same problem.. i tried unplugging the unit then put it on again after several minutes.. still doesnt work
  • Anonymous Feb 27, 2008
    I am running into the same problem. I tried everything.. switching off.. cleaning the printer ..everything. No luck.
    No paper Jam.. but the LED keep flashing E 3.
  • maxx81 Apr 01, 2008
    HI ,
    I have this problem of MP160 E3 error without any reason or paper jam.I followed few advices already on board.I tried to print some how and finally i realised that it does try to print but something always blocks the paper and it always gets stuck without going inside.
    Does anybody know if the porblem might be genuine and there might be a thing inside.If yes then how do i remove it what should i do becuase i can only go as far as i could inside the printer.
    Do i need to open it and see what inside.
    Please help.
  • wiplashprab Aug 24, 2008
    I have the same problem of E3..I bought two cartridges for black and color and replaced em...but still doesnt work....i have tried numorous time turning off and turning it back on...when i turn it on, the roller rolls for few seconds...then the E3 gets displayed...it doesnt even pull the paper in....and has no paper inside the printer...please help....thankx
  • Anonymous Mar 17, 2014
    I had a paper jam. Removed paper. Pressed blinking yellow light/button, but not resolved.
    Scholar:
  • 29 Answers
Don't know if it's the same problem i had but its maybe worth a try. E 3 was the error code i had flashing. Paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Yesterday someone replied to my problem, i tried it this morning and its fixed 1st time.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push/ram it through! and hey presto it worked for me, everything printing fine now
Posted on Mar 02, 2008
  • 64 Answers
Try removing your paper from the feed then opening all doors/panels, swithc it off and leave for 2 mins then close all panels/doors and switch back on. it shold now go through the normal startup procedure up to a [point where it will ask for the paper. insert the paper and it should have cleared the error. Hope this helps Cops [email protected]
Posted on Oct 08, 2007
I was supposed to bring my mp160 to canon service center (around 60 miles). I had the same E 3 for quite sometime now and tried every solution that came out here at fixya. Then yesterday, fixya emailed me. It was a solution that Garty proposes.. Hey man it worked the first time I tried it. It save me the time, the effort and the money.. You are a God send!, keep it up.. please send my thanks to the one you gave you the solution.. Thanks Fixya!
Posted on Mar 04, 2008
    New Friend:
  • 3 Answers
The problem was in broken axis of the pick-up roller, which cannot deliver normally paper to the sensor. For my luck, broken piece was inside in the printer, and after gluing on place, i drilled a hole on it and glued piece of metal wire to be stronger. For now is working :)
Posted on Nov 29, 2011
    Problem Solver:
  • 24 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ptttq5
Posted on Sep 05, 2009
SOURCE:
Canon MP198 error E3
Issue: ERROR LED: E, 3 Solution: Remove paper jam then press Black or Color button (MP150) If paper is jammed, remove the paper jam then press <Black> or <Color> to clear the error.If paper is jammed in the auto sheet feeder or paper output slot, paper will not feed through the printer. Please follow the instructions for Clearing paper jams from the auto sheet feeder (ASF) or paper output slot.If Credit Card sized or 4" x 6" paper is set in landscape orientation, it will jam. Please follow the instructions below for Clearing credit card-sized or 4" x 6" paper jammed inside the printer.Clearing credit card-sized or 4" x 6" paper jammed inside the printer:Power the printer off.Load the same paper type as the jammed paper in the portrait orientation. Power the printer on. (The printer feeds the paper, resulting in ejecting the jammed paper.) Load paper properly in the portrait orientation to resume printing.TOP Clearing paper jams from the auto sheet feeder (ASF) or paper output slot:Power the printer off.Pull out the paper gently.If torn paper remains within the printer, open the scanning unit (printer cover) to remove it.Caution: To prevent injury or damage to the unit avoid touching inner parts.Power the printer on and confirm that the Alarm lamp is off.Note: Any jammed paper that remains within the printer may be ejected automatically.Load paper properly to resume printing. Issue: ERROR LED: E, 3 Solution: 2 Press ON/OFF switch to reset the multifunction device Reset the device when it is not functioning properly.If the device is not functioning properly or to clear memory, reset it.Important: If resetting the printer's power does not clear the error or return the machine to a functioning state, it may be necessary to attempt a service reset. Click here for instructions to attempt a service reset.On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.Wait approximately ten seconds and then press the <ON/OFF> button again.Wait until the device has completed its cycling process before submitting another job request.Service Reset:On the operator panel, press and hold the <ON/OFF> button for one second to power off the printer. (The display will go blank.)Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.Confirm the printer is not on and then unplug the power cord from the back of the printer.If the power cord was disconnected (as stated in step 1) in order to shut off the printer, go to step 3.Press the <ON/OFF> button repeatedly five times.Re-connect the power cord.Press the <ON/OFF> button to power the printer back on.Wait until the device has completed its cycling process before submitting another job request.Important:This procedure will not resolve a physical hardware issue.For example, a paper clip is wedged between the paper feed rollers or gears; or, the scanner assembly is detached from the inside housing. This procedure will not resolve all service errors or LCD related anomalies.Service errors appear as four characters (a combination of alpha and numeric codes).
Oct 13, 2011 | Canon PIXMA MP150 All-In-One InkJet...
E3 error
E-3
Cause: If the Paper Output Tray is closed or not opened fully, open it fully. The machine resumes printing.
Solution: If opening the Paper Output Tray fully does not resolve the problem, the paper may be jammed. Remove the jammed paper, reload paper properly in the machine, and then press the Black or Color button.
If it is still having a problem follow these steps to reset the device.
Solution: Press ON/OFF switch to reset the multifunction device
1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
2. Wait approximately ten seconds and then press the <ON/OFF> button again.
3. Wait until the device has completed its cycling process before submitting another job request.
>>If it still is not fixed after that your printer will have to be serviced.
Dec 11, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Error code E3 with no paper jam
it is problem your printer can not feed paper properly or problem paper feed sensor please try to resum button press when occard this E3 signal or clean sensor or claugth
Nov 21, 2009 | Computers & Internet
E3 flashing wat does it mean
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD over current error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button
3 times for Orange EEPROM reset.
Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
3 times Orange EEPROM reset
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Keeps blinking E3
Hi. Canon says this
E, 3
Paper jam.
If paper has jammed in the machine, clear the jam, reload the paper in the machine correctly and then press the Black or Color button.
There is another step to fix this, also from canon.
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
Apr 21, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Canon PIXMA MP150 with E3 Flashing.
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
E35 15 USB Host VBUD overcurrent error - USB
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
button pressing
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
Thanks, Joe
Feb 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
E3 error message
Dude,
E3 refers to Paper Jam :)
this may come in handy:
Service mode operation procedures -
button pressing
procedures below.
procedures below.
îäíàêî, äëÿ ôóíêöèé 4 è äàëåå åñòü ïðèìå÷àíèå : òîëüêî äëÿ àçèè.
à âîò â îïèñàíèè ôóíêöèè 3 åñòü : Reset except for the
followings:
- USB serial number
- Destination setting
- Waste ink counter ...
Turn it upside down and than check.....same error code or diff.
Any help, can buzz me nytime ...
Thnks.
Jan 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Paper jam problem in pixma mp145. E3 error.
I have trying resseting and the error message does not clear. I have checked the printer througly and there is no paper jam.
Nov 25, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printer Error E3
E3 error -
If paper has jammed in the machine, clear the jam, reload the paper in the machine correctly and then press [Black] or [Color].
The above is direct from the user manual.
If there is no paper jam - look for any small pieces of paper that could be located near the roller sensor.
Oct 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
4,368 people viewed this question
Clive
Clive
old marine
old marine
Ekse
