Question about Lexmark Z735 InkJet Printer
Paper not feeding through on right hand side
When i prees print the paper is only feeding through on the left but not feeding on the right, the paper is then scrunching up. can any one help, my 12 month warrenty has just expired!!
I had the exact same problem.  I disconnected the printer and then when I flipped it upside down, I heard something drop out of it.  Low and behold was my missing letter opener.   I then tested the printer to see if it works, and sure enough it feeds properly.  Try cheecking to see if any objects may have accidentally fallen into it.
Posted on Oct 23, 2007
SOURCE:
My cannon pixma mx360 won't print. The paper gets jammed and it won't print.
Look for a fragment of paper or other foreign object in the paper path. Often feeding a sheet of thin card back through the paper path will push any offending object out. May include insects, paper clips, leaves, rubber bands (the worst), pens and pencils, and of course torn or scrunched paper.
Jan 30, 2017 | Canon PIXMA Office Equipment & Supplies
Paper will not feed
Check inside the machine at both ends of the cartridge carriage path i.e. far left and far right. Check for scrunched up paper and note, if it is there, it will likely be black with ink. If found please remove. Next take the back off the machine (there is usually a removable plate there to get to paper jams) and remove anything you find there. Also look right through towards the front and see if the little drop down paper feed sensor arms are all visible and swing freely. If not, fix them as you can. Once you have done these things, put everything back together and leave the printer powered off for 30sec. Power it up and see what happens. If you are still no go, either take it to a service tech or check to see if your insurance covers printers being beaten to death with a 4 pound hammer.
May 14, 2015 | HP Office Equipment & Supplies
Lexmark s605 paper jamming
Sounds like an obstruction on the right hand side of the feed mechanism. All-in-ones are a pig to find these - I've had one HP almost completely stripped before I found a chad of plastic stuck in a corner. Nine times out of ten it's a torn corner of the first bit of paper to get chewed jammed in the feed slot.
Apr 06, 2012 | Lexmark Interact S605 All-in-One Color...
LEXMARK x 2650 -- PAPER WILL NOT FEED INTO PRINTER CORRECTLY- WILL STOP AND SCRUNCH UP ON THE LEFT SIDE OF PRINTER FEEDER
Look very carefully inside where it scrunches up. you'll probably see another small piece of paper from a previous jam... remove it
Jan 23, 2011 | Lexmark Office Equipment & Supplies
Whenever I try to print a file, the paper gets scrunched up on the right side (facing the printer), and cannot print anything
a foreign object may be lodged in the paper feed path. Please specify what brand and model printer you are refering to.
Dec 09, 2010 | Office Equipment & Supplies
The paper feed tends to pull to the left scrunching up the paper and jamming when trying to print or fax ?
Seek hardware service for the maching.
Add make and model information to your request.
May 06, 2009 | Office Equipment & Supplies
Paper jams sideways and gets munched up - will not print
Check the paper path way , and also leds that directing paper.
hope that help you
thanks
Hamedo
Oct 25, 2008 | Dell 922 All-In-One InkJet Printer
Printer screen tells me that there is a paper jam - no paper left in printer
Check rear door, it comes off, and also look to left and right sides of carriage paper gets scrunched into sides by head.
Dec 25, 2007 | Brother MFC 240C All-In-One InkJet Printer
Lexmark Z735 InkJet Printer Logo
126 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
