Question about RCA DRC8052N DVD Recorder
Recording problem I have owned this recorder for over a year now and have never been able to get it to record correctly. I have had about a dozen successful recordings, but I don't know how I got there. The manual says that in order to do a simple recording you simply press the record button for the show you are watching. When I do this, nothing happens--the screen simply reads "stop". It definitely doesn't do what the manual says for simple recording. I haven't tried other methods. I'm wondering if there is something missing in the manual for basic recording. There have been a ton of shows I have tried to record, but have given up. Every so often it will record, but it won't be the channel I'm on--I simply don't get it--I thought it was supposed to be easy
  • 51 Answers
You need to make shure you get the dvd ready i suggest buy a dvdrw but it in the dvd go to the setup page and in there hit disc it will atomaticaly prepare the dvd cause you cant just put a dvd in and record it needs to prepare (open the disc) also if you are going to watch the recording on another machine after recording you need to finalise the dvd when they ask you to or it will only work on the rca machine
Posted on Jan 08, 2008
Image being Captured/Recorded is in Gray Scale (Black and White)
What game recording are u doing because some games have their own recording systems
Jan 12, 2014 | Pinnacle Computers & Internet
HI! How do I change the message on my phone?
You can record your own greeting message (max 2 mins & 30 secs). If you don't record a greeting mesage, a pre-recorded greeting message is used & asks the caller to leave a message. (Make sure your phone has the correct date, time, year, etc.)
To record a message:
1. Menu (OK) the "Answering Device" (OK), the "Record Greeting" (OK)
2. Then after the handset beeps, speak clearly about 20 cm (8 in) away from the mike.
3. To stop recording, press (OK)
4. (Off)
Mar 30, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
I own a Toshiba DR420KU player/ recorder. I can't make it record premium programs. It says it's a CPRM device and that it will record onetime only broadcast since it's copywright protected. I found on the...
Even if you have the correct disk and the correct setting in the recorder, if the CPRM tag in the broadcasted program is set to deny all recording then your recorder will not record it. Sadly but it's just that simple.
Aug 28, 2010 | Televison & Video
My cd recorder wont read blank cds help me please
Do as it asks, insert blank CD-Audio or CD-Music media.
Discs for recording
For recording, make sure to use special audio discs only.
These discs are marked with “Digital Audio” and the logos shown below.
There are two different types of audio discs for the use on this CD recorder:
– CD-Audio Recordable (CDR) discs
These discs can be recorded on once and
play in all standard CD players and CD
recorders, when they are finalized.
– CD-Audio ReWritable (CDRW) discs
These discs can be recorded on, erased and
re-recorded many times and play in CDRW
compatible CD players and CD recorders,
– All Philips CD players and CD recorders
with the sticker shown here are CDRW
compatible.
To ensure proper working of the set we recommend the use of Philips audio CDR and audio CDRW discs only.
Note: Do not use a computer CDR or CDRW as recording will not work!
Go here and download the manual. You'll need it.
http://www.p4c.philips.com/files/c/cdr602_00s/cdr602_00s_dfu_eng.pdf
Mar 04, 2010 | Philips CDR602 CD Recorder
DVD recorder isn't recording onto a blank disk in DVD format.
You just may have an issue with your DVD recorder. Happens.
Mar 29, 2017 | Televison & Video
Intermintant in recording
Hi,not shure if this is your problem but if you are recording shows from tv & you are in av2 of output you will have no recording even though it shows that the recording has begun,all tv recordings must be in the av1 output mode to record from tv I have learned that few times thinking that all is working but to find out that I was in the av2 output mode which was really not recording the whole time,before I begin any recordings I from now on check that I am in the av1 mode then I know the recording will be working,take care ECK
Nov 11, 2008 | Panasonic DMREZ27 DVD Recorder
SE2200A "wind" noises during recording
Its very descriptive and is quite a common problem with less expensive condenser mics. It's due to dirt or contamination on the capsule insulator or front end circuitry of the electronics. SE should be able to fix it for not much money.
Aug 26, 2008 | SE Electronics SE2200A Professional...
Panasonic DMR-E55 Won't Let me Record my own VHS
Hi
This is probably caused by an irregular magnetic encoding pattern being generated by the tape itself. If the DVD recorder does not fully recognise the code, it may incorrectly interpret it as copy protected. If there is any tape flutter or there are tape edits, these can contribute to the problem. In addition to this magnetic imprinting can occur on old tapes that have been stored for a number of years without being spooled. basically wrong bits of the tape get magnetised. You can sometimes hear an echo on old tape recordings caused by imprinting.
You could try the following:
1) If available, try using a different video machine to play back and record from.
2) Whatever video machine you use, put your tape in, fully fast forward and rewind a couple of times, then try your recording again. This is particularly important if you haven't used the tape for some time.
3) If it fails again, check to see if it always fails at the same point.
4) If it does, try winding forward a little and then try to resume recording.
5) If you can record it means that a short section of tape is giving a spurious code to your dvd recorder and confusing it.
6) Use a re-recordable dvdrw to make a master. You won't keep wasting discs if the recording stops. You will also be able to produce another dvd from your master and edit it if your recording ends up in a number of segments.
7) Always use the highest quality setting possible when producing a master.
8) If all else fails, if you have a friend with another dvd recorder, maybe try that.
Have fun....
Jan 21, 2008 | Panasonic DMR-E55 DVD Recorder
I dont get sound in movie recording, what do i do?
its simple this camera don't have audio recording That all.
Oct 28, 2007 | Casio QV-R61 Digital Camera
Recording over copyright
One way would be to hook your video up to a computer and record it this way.
Oct 24, 2007 | Panasonic DMR-ES10 DVD Recorder
RCA DRC8052N DVD Recorder Logo
77 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
