Home | Canon | CanoScan N340P Flatbed Scanner | Unable to use Can...
Canon CanoScan N340P Flatbed Scanner
Problem for Canon CanoScan N340P Flatbed Scanner
Unable to use CanoScan N640P with Acer Notebook
By ymonique on Sep 29, 2007
Unable to use my canon scanner (canoscan N640P) with my ACER Aspire 5552NWXCi notebook as there is no 25 pin slot. There are 3 USB slot. What kind of special cable do I need to buy. Thank you.
Same Problem
May 08, 2009
-   i have same problem. i even installed a parellel port and still can't get it to find my scanner -   Guest
Solution #1
posted on Sep 29, 2007
Somewhat Helpful)
Benimur
Rank: Guru  Canon Expert
Rating: 88%, 3768 votes
Since as you posted, your ACER Aspire 5552NWXCi notebook has no 25 pin Parallel/LPT1 port, what you need is an adapter that will convert your scanner's 25 pin parallel (DB25)to USB. Shown below is such an adapter made by Targus Model# PA096U and commonly called a USB to Parallel Adapter.
Do a google for USB to Parallel adapter or cable.
Hope this be of help/idea. Post back how things turn up or should you need further information.
good luck and kind regards.
Was this helpful?
Yes
No
Solution #2
posted on Jan 04, 2008
Somewhat Helpful)
alexp2
Rank: Apprentice
Rating: 75%, 1 votes
Hi ymonique,
Can you tell us whether this worked? I have the same problem but the system still cannot find the scanner when I use a USB to parallel cable.
Was this helpful?
Yes
No
Popular Solutions for Canon CanoScan N340P Flatbed
Questions and Unsolved Problems for Canon CanoScan N340P Flatbed
Do you recommend Canon CanoScan N340P Flatbed Scanner?
Answer
Answer
I have a canoscan N640p Can I use it with windows vista 32??
Answer
How to install/download my CanoScan N340P to my computer .
Answer
dear, When I start the install of the driver of the canscan n640P it display the follow message: The... (More)
Answer
I need an installation disk for canscan n340p
Answer
I have a NEW laptop computer with Windows XP but without a printer port. I installed a parallel to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon CanoScan N340P Flatbed...:
Top Scanner Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Scanner Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
