Question about Sony PlayStation 2 (PS2) Console
Ok, maybe its a problem with the cable
Hi, Thanks for saying that its not a chip problem. Well, then if its a cable problem, how do I check it. And, where can I find the cable??? Thanks mate.
  • 709 Answers
Hi banerjen, I have not actually come up with the exact way to test the buttons. All I can offer is to do an autopsy of the reset/eject buton assembly, but not in a way to kill it. Use a volt meter set to ohms at a value of 20. You can read out the ribbon cable or wire cable, whichever model you have. The traces on the ribbon should read close to 0 ohm from end to end on each trace. If it read OL its bad. The switches I am not sure about. Never had any trouble with them. Ebay has supply of all the parts you will ever need at a great price.
Posted on Sep 29, 2007
Can not get any image
1) Check if lamp is still ok. If no light even after POST replace the lamp.
2) If lamp is ok, check if all black or all white or flickering dots. If you see flickering spots chances are your dmd chip is faulty, replace it or send it to service center to replace the chip which will cost you a fortune as dmd chip are expensive.
3) if POST is ok, check your input signal if correct choice, check cable if ok, check setting if correct.
Oct 21, 2015 | Mitsubishi XD206U-G DLP Projector
Hp Pavilion, Power supply Inactive, HHD savagable, intel Chip Savagable, i was thinking a new motherborad for the chip and the hard drive ????
If your Desktop not start it means not you mother board problem because starting you find your SMPS proper running or not. Because SMPS supply all power in CUP so you check it SMPS on or off position. if SMPS ok then you check it mother board light on or not, if on then ok or not on then you change SMPS supply.
If your display issue then you check it RAM and HDD.
Computer Support
Feb 20, 2014 | HP Pavilion a305w (DM181AR) PC Desktop
Display has black circles lower left corner and upper right corner. were smaller but have grown. Maybe 2 in. each now. Also lines in pink and black across bottom. Everything else works OK. Bought past...
Well your on the right track I would say it's your LCD because your video chip wouldn't make black circles I don't think. The pink and black lines are a symptom of a LCD that has been broken and the circles sound like someone squeezed it to pick it up by the screen maybe. That would be for your venders warranty department to figure out though. If you really want to know you could buy a cable to hoot it up to an external video source if the display is fine, it's defiantly your LCD.
Jul 29, 2011 | Dell Computers & Internet
Hi i have a hp pavillion dv1000 laptop and the problem it has is that i can turn it on (lights turn on, fan runs) but the screen stays black and also the light that is below the screen (between the screen...
all DVxxxx have graphic chip problem. to confirm to say others are OK, remove the RAMs and turn on.
you can here memory beep error.its says others are ok.
now you can repair the main board( re-flow the chip or replace the chip) or if not need to replace the main board.
Dec 06, 2010 | Computers & Internet
My printer doesnt print and it is connected on a serial port it just says printing and nothing happens
Make sure the cable hasn't died, and check to see if the printer is working by printing a test page, usually done on HP's by pressing and realeasing the green go button, or holding down the power button. If the printer responds, and the cable is ok as far as you know, check and maybe reinstall the drivers with the disk that came with it.
Good Luck, Hope this helps!
Nov 28, 2010 | HP LaserJet 1100 Printer
I am about to add a second IDE hard drive to my P.C. and the instructions i have say change the jumper chip to slave! I cannot see any obvious ways to do this physically on the the hard drive. What do i...
All hard drives have a set of jumpers on the end by the power connector. There is also a diagram of the location of these jumpers, for Master or Slave, or maybe Chip Select. On each IDE cable (2 connectors) there will be one Master, one Slave as identified by these jumpers. These jumpers are quite small and easily misplaced, so be careful !!!
Oct 13, 2009 | Computers & Internet
I am not getting any power in my amp even though its connected to the battery in a ford escort 1998
Hi are you tasting the big red cable whit a test light ,if yes you may have problems whit the cable that says remote that should have power to it when your radio is on test it whit a test light
Sep 23, 2009 | 1998 Ford Escort
Model No AL-096 Sahara memory daul channel
2 slots does NOT mean Dual Channel, that just allows for 2 RAM chips
Apr 18, 2009 | Dell Dimension 8300 PC Desktop
Problem with amount of RAM.
maybe your video card uses 128mb shared memory so 128 for video plus 640 reading equals 768.
Apr 10, 2008 | HP Compaq Presario V2000 Notebook
Problems with white screen
Faulty or loose ribbon cable, between mainboard and screen.
damaged internal cable.
graphics chip problem.
poor earth or ground connection.
Mike @ compurepair.
Feb 20, 2008 | Nintendo Game Boy Advance Console
Sony PlayStation 2 (PS2) Console Logo
22 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
