Question about Dell Latitude C400 Notebook
Dell latitude C400 will not boot from hard drive.
Whenever I turn on my dell c400 it wont boot from the hard drive. it says it cant find a bootable drive in bay 0 or something. this happened suddenly. one day it was working, the next, it wouldn't boot.
  • am_trojan Jul 18, 2008
    i cant start the windows cause have blank screen and cannot connect to the driver.... i dont no how to do it.....
    Brigadier General:
  • 6,966 Answers
Hi, This sounds like a dead hard drive. Still, you may want to try: 1. Enter your CMOS/BIOS and verify that your laptop can detect the hard drive. Further check if it is configured to boot first from the HD; 2. Slip in your XP or Recovery CD and boot from that. It may be that the boot section/files of your HD got messed up. When prompted, instruct the CD to repair; 3. Remove your laptop's HD and connect it to a 2nd PC as an external/removable drive using a 2.5 enclusore with USB attachment. Thereafter proceed to diagnose, check and hopefully recover your important files; 4. If confirmed of a defective HD, replace and reinstall your OS. Hope this be of some help/idea. Post back how things turned up or should you need further information. Good luck and kind regards.
Posted on Sep 29, 2007
I have the same problem, I am thinking it might be my low battery, at startup sometimes my dell c400 forgets to start spinning HD. this is only sometimes, usually when i leave my computer connected to the wall when the computer is off. after a few start ups it remebers it has a hard drive and works again.
Posted on Oct 24, 2007
6ya staff
SOURCE:
I cant format my C400 with a pen drive
If you're tryng to format the HDD on a Dell latitude C400 (or install an OS), this thing will not boot to any USB devices (flash drives, pen drives, external USB cd-rom drives, etc.) - just ain't gonna happen since the BIOS doesn't support such boot devices. The only thing it'll boot to is (1) docking station, and (2) a Media Bay optical drive.
Sep 01, 2011 | Dell Latitude C400 Notebook
My neighbor has a Dell Latitude CPt ppx that's about 6 years old. It won't open up to Windows now. Whenever it is turned on we see the big blue "Dell" start up screen. Then it says,...
Usually Dell has a partition that contain all the information to restore the factory setting of your Latitude,If it has not been damaged or erased, You can activate it in the Dell booting option on opening of the Dell computer press Ctrl + F11 to accesss the restauration menu
Hope this answers all your questions Please remember to Rate/vote for any solution that helps you out. Leave a comment if you need more help. Thanks for using Fixya
Aug 16, 2011 | Dell Latitude C400 Notebook
My dell latitude c400 will not boot from external cd rom or the brand new hard drive i need to put windows xp on it but it will not boot from anything can you helpnow i have found i have no drivers...
try other known good windows installer. if it boot, then the problem is in xp installer, if it not. try other external cd-rom drive. also be sure the disc rom drive are dvd rom drive because a cd rom drive cannot read dvd disc but a dvd rom drive can read cd rom disc installer
Feb 15, 2011 | Dell Latitude C400 Notebook
I have a Dell C400. All of a sudden it won't boot. Can't even access BIOS. Display has nothing. Battery light keeps flashing from green to amber.
Remove the battery and the hard drive , use the charger and try to boot to BIOS. If it fails then the laptop is dead.
Jan 17, 2010 | Dell Lattitude D600 Notebook
My laptop has trouble booting. it takes me up to
Sounds like a failing hard drive. Try replacing with a different HD (preferably a known working one that doens't have important data on it) and try installing the OS to it.
-=/ Daft Tech /=-
Oct 22, 2009 | Dell Computers & Internet
DELL C400 LAPTOP
you may need a separate hard drive, you could try to boot off of that
Oct 24, 2008 | Dell Latitude C400 Notebook
Cant install xp to dell c400 with external cd-rom
This is how I did it, you may or may not have the ability. A basic knowledge of Dos is necessary 1) I used another laptop but you could use an adapter to use the hard drive in a regular computer. 2)boot with a windows 98 boot disk, fdisk it to a fat32 partition, make the hard drive a system boot disk (format /s c:) 3) copy the i386 folder and all its contents from a full or full oem (not branded) disk to the laptop drive, also copy smartdrv and highmem.sys from the floppy (speeds thing up dramatically) and create a config.sys file with device=highmem.sys 4)physically install the hard drive back into the C400, boot to dos run smartdrv.exe, then go to the i386 folder and type winnt.exe (enter) wooo should work. MusslaChooda Pakichooda Nathuram Godse
Oct 22, 2008 | Dell Latitude C400 Notebook
Won't boot from new hard drive
simple prombelm of this is this computer wasn't made to start from xp ,it need start from a ealier system like windows 95/98 see the 386 file is prombally missing that why it wont boot up. lala linda
Oct 15, 2008 | Dell Latitude C400 Notebook
Dell Latitude C400 Notebook Logo
304 people viewed this question
Ekse
Clive
Clive
Alun Cox
