Question about O'Neil Printers MicroFlash 3 Label
Where to buy
Where can I buy more oniel microflash 3 mod# 200060-000
Re: where to buy - O'Neil Printers MicroFlash 3 Label Printers & Copiers
Posted on Jan 07, 2008
0 characters
3 Points
Why does it say add paper in cassette 1 but cassette is full
sorry man we had the same problem theres a black tab on the back of the tray that pushes the paper back so it dosnt go over the back remove it or buy the mod kit for it we simple removed it
Jul 29, 2014 | Kyocera Ecosys FS-2100DN Laser Printer -...
How do you do a factory or hard reset?
Sounds like a faulty bluetooth card or main board.
May 22, 2014 | Datamax-ONeil microFlash 4te Direct...
Epson P50 does not respond. Blinking lights and stuck cartridges.
This is a standard "Service required" issue where the waste pads (or nappies) in the printer are considered full by the printer and it wants them changing.
An Epson service centre can replace the pads and reset the waste counter for a considerable amount of money although most it seems either tell you it's dead and recommend you buy a new one, or they reset the counter, ignore the pads and leave you to flood your printer.
The more cost effective option is to locate one of a number of reset utilities such as the AdjProg utility for the T50 (it's compatible with the P50) and an external waste ink kit (like the Printer Potty).
The latter is easy enough to fit on a P50 thanks to the access hatch located in the rear left quadrant of the printer.
More information and instructions are available here:
Jun 29, 2012 | Epson P50 Inkjet Printer
Hi i refilled my toner cartridges for the Samsung CLP 315 and it wont print! Do I need to reset or something??
The toner cartridge also needs to replace chip on cartridge as well. When you get the first warning of low toner, refill the cartridge as and you won't have to do complicated chip modding. You will get about 3 refills per cartridge before the printer figures it out though, then you will need a new cartridge.IF you don't want to have to mod or replace your cartridge chip, simply DON'T let the cartridge get to completely empty. If you do, the chip will activate and tell the printer not to use that cartridge, even if refilled? to full. then there is no other way to replace chip/cartridge.
Hope this helps if so do rate the solution
Good Luck
Jan 03, 2011 | Samsung CLP 315 Laser Printer
In my office we have 5 kyocera copiers Mod. 2050 and we like to install a fax card to use as fax machine, where we can find this cards and how much cost. Thank you, Frank
$1200 each. You can go to Staples and buy 5 stand alone Brother Fax Machines for that amount of money. Those fax systems are hard to find now and they are not a plug in card but a total rework of the copier. Sorry
Jun 17, 2010 | Kyocera Mita Printers & Copiers
Xerox 265 toning problem
The charge assembly is part of the module. It is called the Xerographic module.Ther should be a small orange knob sticking out of the module that you can pull out and in that would clean the charge and possibly help. But replacing it would resolve your issue, I am 99 percent certain. The only other issue would be the developer housing, but if that were the problem the machine should fault out and just not run at all.I honestly am not sure of the number, familarity makes you not pay attention to some things. Those are customer replacable. Look up a place on google called The Parts Drop. Get the number and call, ask for Britt, he will help you with what you need. If you have a maintenance contract, Xerox will provide the xero module free of charge.
Its in a pretty big box. about 2 by 3 feet size.
You take the old one out by moving an orange lever sliding the old one out and putting the new one in, there is also a waste bottle on the left side of the machine you pop in and out.
Jul 20, 2008 | Printers & Copiers
Dell 3100cn Duplex won't feed
I'd suggest it is a sensor issue. Since the error comes up, the printer stops responding - even if everything is okay.
Jul 28, 2007 | Dell 3100cn Laser Printer
Printing Problem
The 8i is a line printer only printer. It does not understand EZ print code. You need to just send a line of ascii text for it to print.
Apr 08, 2007 | O'Neil Printers MicroFlash 8i Matrix
O'Neil Printers MicroFlash 3 Label Logo
Top O'Neil Printers Printers & Copiers Experts
old marine
old marine
Are you an O'Neil Printers Printer and Copier Expert? Answer questions, earn points and help others
