Question about HP Compaq dc7600 PC Desktop
Dc7600 creat high speed fan problem - HP Compaq dc7600 PC Desktop
Dell inspiron 2020 all in one fan problems
I have found that if the room temperature near the computer is too high creates a problem. If the processor is being used at a high rate that will influence the temp sensors and cause the fan to run at the "speed" you hear. (It is on all the time, just different speeds). Other heat producers may not have clean fans or fins, for example display adaptor or power supply. or but unlikely, the
cpu fan interface is not well seated or no heat transfer grease. You didn't change the processor did you?
Apr 05, 2015 | Dell Inspiron One 2020 Desktop Intel Core...
Fan speed switch
the problem will be in the fan resistor a small unit normally screwed into the heater case behind the glove box. The resistors that create the lower speeds will be burnt out leaving only the direct circuit for high fan
Dec 28, 2013 | Toyota Cars & Trucks
Heat makes a screaming sound - only comes on when on high, air does not come on at all - A little advice and help needed. THANKS
The screaming sound is the blower motor bearing. the fan speed switch controls the grounding side of fan motor once on high it grounds the high speed fan relay. so lower speeds goes through blower motor resistor. this may be burnt out do to bearing is screaming tight to shaft creating a larger ampere draw that burnt it out.
Nov 13, 2013 | 1997 Chevrolet K1500
What size case fan for HP Compaq dc7600?
What size case fan? Dunno.
1) How to measure the fan? Across the fan's shroud. (Surrounding Cage) Fan stood up, measure the Height, and Width.
2) Look at the label on the fan's center hub. Write the number down.
Now which of these CHASSIS fan numbers match?
http://www.sparepartswarehouse.com/HP-Compaq,Business-Desktop-dc7100-dc7600-dc7700,Computer,Fans.aspx
A) 3777791-001
Chassis Fan - 70mm x 70mm x 15mm.
70mm x 70mm is the height and width of the fan's shroud. (Surrounding cage) [ Chassis fan stood up ]
15mm is the Thickness of the fan shroud.
Nope, not that one.
B) 451144-001 Chassis Fan - 92mm x 25mm
Could be.
C) 455310-001 Chassis Fan - 92mm x 25mm.
Could be.
Regards,
joecoolvette
Jun 11, 2012 | HP Compaq dc7600 Small Form Factor PC...
My dc7600,s fan makes noise when cpu usage reaches upto50
Open the case and try tightening the screws that hold the fan. Also make sure no cable or wires are touching the fan blades causing the noise.
May 24, 2012 | HP Compaq dc7600 Small Form Factor PC...
My HP DC7600 - get noisey when starting to plau games
http://almico.com/speedfan452.exe
Download and install and run this. You may want to go to the settings tab in the program and change it from metric. Then you can see the temperatures of everything in your computer. You can then launch the game and see what the temps do. It is common for fans to speed up when the computer senses large demand on the processor and graphics cards.
Dec 11, 2017 | HP dc7600 Convertible Minitower PC Desktop
A/c is cold but the fan is not working to blow it into the car stopped working on high first now will not blow at all
Check your blower motor resistor. It is commonly the part that the blower motor power connector plugs into. It sounds like the high speed element went first and you lost the high fan speed. If the remaining resistor element is broken, the fan will stop working. The resistor only have 2 elements; if they're both broken, it creates an open circuit to the blower.
Jun 24, 2011 | 1996 Mercury Mystique
I have a HP dc7600 SFF. Tried to Install 2 graphics cards no vid
The dc7600 SFF only comes equipped with a 240 watt power supply. I think this may be causing your problems.
I am currently looking for a graphics card for the same comp with the HIS ATI HD 4350 in mind, but the website states that a 300 watt power supply is recommended.
Jan 01, 2010 | HP Compaq Business dc7600 PC Desktop
Noisy fan or motor?
HI. The most common issue here will be with a loose motor shaft. This is the part that the fan blades are mounted on. When this occurs, the looseness will cause the motor, and shaft to wobble, thus, causing this noise you here at high speeds. The wobble is less violent during the slower speeds, so it is not loud, in this case.
The second issue will be a warped fan blade. This will cause the fan to rub against the shroud, thus, creating the noise, as well.
If the shaft is loose, or bent, the entire motor will need to be replaced. Now, if the fan blade is warped, you can, simply, unscrew the blade from the shaft, and replace it(on most model)
Dec 11, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
HP Compaq dc7600 PC Desktop Logo
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
