Question about Brother MFC 420CN All-In-One InkJet Printer
Won't print Color
Hi, I have a MFC-420CN printer which will not print in color. It prints black ink fine. A couple of the cartridges were near empty so I replaced all 3 color cartidges & still no luck. I even uninstalled & reinstalled the software. I went through the ink/test print & got the same thing. There are no error codes or problems, it just won't print any of the colors.
    New Friend:
  • 39 Answers
Have you check on your printer's color preference? It may only be a simple problem with your gray scale.Change the color preference on your printer icon's menu. You can also clean up your electronic connectors that comes in contact with the cartridges with a cotton dipped in alcohol. See <a rel='nofollow' href="">troubleshooting</a> procedures here.
Posted on Dec 13, 2012
  • 832 Answers
Old Dad, this is a common prob of the brother printer. It has nothing to do with the software and depends on the cartridges being used (are they thirdparty ones?) and in some cases air bubbles within the capillarysystem, or a defective valve within the printhead. I guess before you have changed the carts everything was working quite normal. So, this in mind, try the following procedure: Check cartridges if positioned well. Press them into position again, so that there is a good, open contact for ink to run into the capillaries! Power on printer. Press menu then start mono (b/w) then 4x arrow-up-button. Machine will be in maintainance mode and beeps. Press 7 then 6. Machine displays Cleaning_all. Press 3. Power_p all will be displayed. Press start mono (b/w). Machine starts a power cleaning cycle. Wait until machine displays maintanance again. Press 0 (zero) then 9. Machine starts printing ink/test printsheet. If it is OK press 9 then 9 to quit the maintanance mode. If it is not OK press 7, 6 then 4 (init_all), then start mono (b/w). Machine will initialize the cartridges and clean the head. When finished press 0 , 9 again for test printing. If you dont see any success after both procedures, your printhead may be clogged or dryed out.
Posted on Sep 29, 2007
I have a brother MFC-490CW and replaced the black ink, and my color ink has run out. It will not let me print as it says ink is low, so it won't even let me use the black? How do I print with only using...
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the empty color cartridge because they are programmed to clean ALL the ink nozzles. The only way to continue printing is to replace the empty ink cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
Jan 21, 2010 | Brother MultiFunction Center MFC-440CN...
Printer wont print
Try remove all cartridges then put back it one by one.Make sure the color cartridges are not empty too.The printer need all cartridges not empty to initialized and working.
Nov 25, 2009 | Brother MFC 490cw Color Inkjet...
MFC-420CN refuses to recognize or use black ink
The print head is clogged.Try powerful cleaning:
Press menu, then start black copy, then four times arrow-up quickly after another.Machine will be in maintenance mode
(all lights will flash).
Press 7-6-4 and OK (or start-black-copy).
When finished press 7-6-3 then start black copy,
printer will do a power purge.
Leave maintenance mode by pressing 9-9.
If this not help better think about new printer, because cost of repairing this one is profitable.
Nov 25, 2009 | Brother MFC 420CN All-In-One InkJet...
Printer will not print dut to other color cartige. being empty.
The color cartridges print text that appears black by mixing the three primary colors (cyan, magenta, and yellow) to make composite black. To achieve a realistic black, large quantities of colored ink are used. Because black cartridges use much less ink to create a similar shade of black, they print more pages in black than the color cartridge.
If the color cartridges on the printer are next to empty, you will not be able to get perfect prints at all.
Please have the cartridges replaced to do the printing jobs again.
Sep 10, 2009 | Brother Multi-Function Center MFC-240C...
My brother mfc 420cn printer quit printing...
I'd venture to say that if you haven't used it in a while the ink dried up and clogged the print head. It is probably a job for a service center. Good luck
Aug 05, 2009 | Brother MFC 420CN All-In-One InkJet...
Will no print black color doc if any other color ink is empty
actually, its not. the reason is, there is a small resovoire (sp?) in the ink cartridges. if you continue to print, the nozzles will clog up, and can cause all the nozzles not to work. even when you do just black, the printer has to clean at times all the nozzles and if your nozzles are empty, air will go into the deep and dry up the excess ink.
if you are going to do primarily black prints, you should get a black and white laser for those uses only.
Jun 13, 2009 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-420CN color ink empty but want to print/copy in B&W
brother won't print od do anything is one of the 4 inks are empty so first of all you have to replace whatever is empty, when you remove it it will ask you if you changed it and if it is a new one you will press 1 twice per cartridge, if you put compatible ink in you will clog the ink head up and then be stuffed
Dec 15, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-420CN All-In-One
unplug maqchine from power. take all carts out. wait 5 minutes. connect machine to power. insert carts as demanded. give the right answer if machine asks if the carts are changed. machine will do some cleaning.
do you use generic ink? in that case you might have clogged the printhead with wrong ink. The ph cant be cleaned anymore.
nevertheless try this (carts should be nearly full!):
press menue then start mono (blue copy) then fourtimes arrow up. machine will be in maintenance mode. press 7 then 6 then 4. Machine will display init_all. press start mono. machine will refill tubes and
ph with fresh ink and do some cleaning. after that press 7 then 6 then 3 and start mono. machine will do a powerpurge.
press zero then 9 to do a quality test print. If it cant do the job leave maintenance by pressing 9 then 9. do the test print manually by pressing ink etc.
If you still do not see any colors the ph is clogged and cant be fixed anymore. It has to be replaced.
Dec 03, 2007 | Brother MFC 420CN All-In-One InkJet...
Cannot print
It seems that another cart is empty. Check all cartridges when printer is off. And yes, you do need the color ones to print in bk.
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
88 people viewed this question
James Cagle
James Cagle
Jim Keysor
