Alright so you need to pull all of the screws out on the bottom of the laptop. The casing will most likely require a little force due to any sealant that the company used if this is the first time opening it. you may also notice a little locktight on the screws that you have pulled out. You just need to run your fingernail or a flatheaded screwdriver around the edge of the panel and pry it off little by little.
Let me know if you need further directions or have other questions and I would be glad to do what I can.
When you open the link just click on the "Brochures and Manuals", All the manuals related to Canon PowerShot A530 Digital Camera will be visible below, Click on respective manual and download it. For your Assistance image is given below
If further assistance required, I am here to help. I hope this solution helps you Thank you for using FixYa
Your circuit board has developed a short. There is only one way to fix it, replace the main circuit board. Buy an A530 camera with a cracked LCD online from someone, to fix it.
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
if u have already checked the adapter then make a power drag trial,
that is use the adapter with any other laptop of same voltage rating
and if the lap works there is no problem with adapter as some
adapters fail to deliver power at the time of consumption and gives
correct multimeter reading.If the problem is with ur laptop surely u
have to open the case,there after chk for dry solder and then chk power
regulator ics ,chk short circuit of components etc
