Question about Maytag MFD2561HE Stainless Steel Bottom Freezer French Door Refrigerator
Maytag mfd2561 water dispencer and ice maker issues
Posted by Texasguy on Sep 29, 2007Report abuse Hi all. I have MaytagMFD2561HES french door and water dispencer doesn't work. I replaced the filter(was year old) but it didn't work. I hear the motor running and when I replaced the filter water was running from the bottom of the freezer. But it was stopped after few mins. My ice dispencer doens't work, door alarm doesn't work and water filter and replace indicator doesn't work. Both freezer and refregerator works fine. Display shows correct temp, vacation mode, and other funtions work. I didn't use the fridge for year (used it for 8 months only) and any help would be appreciated.
  • 1 more comment
  • Texasguy Sep 29, 2007
    Hi the dr
    Thank you much for your quick response. Could you please explian how I could take the back cover and directions on how to reinstall control board etc?
    I forgot to tell you when I tried to use the water dispencer it leaked lots of water(crack on water filter). I left filter compartment open without installing blue cap for two weeks. Once I intalled the new water filter some water spilled out but then it stopped. I hear water dispencer moter trying and ice dispencer trying to make ice. I turned on speedy ice feature and freezer got really cold but didn't make any ice(at least I heard it was trying). Your input is appreciated.
  • Anonymous Apr 04, 2008
    My water dispenser just stopped working. It filled up a glass went back
    a few minutes later & it would not dispense. This has happened
    before I never did find out what was wrong then all of a sudden it
    started working again. What is going on!
  • Anonymous Mar 30, 2014
    The ice despencer is not working properly. The lid stay open.Is there a replacement part for the lid? Or should I replace the whole dispencer.
  • 447 Answers
Most likely it is the High Voltage Control board located in the unit compartment (take off the back cover where the water lines are) i have had lots of them failing and doing all kinds of odd things, so far it has been that computer. Part number 12002608
Posted on Sep 29, 2007
SOURCE:
MaytagMFD2561HES french door slams open
theoabear,  Seems I ran into this before,  check out the following post the cat here posted.....Catriver
http://www.fixya.com/support/t129304-maytag_fridge_french_door_hinge
Oct 19, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Ice maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
cbn,c,bm
Jun 14, 2010 | Maytag MFI2568AE Side by Side French Door...
Ice maker in Maytag French Door not working
replace the ice maker if the reset button has not done any good
Sep 16, 2009 | Maytag 25 Cu. Ft. French Door Bottom...
Water dispenser not working in my Maytag Model #MFD2561 HES
Hi. Do an Internet search for Maytag recalls. Your fridg. may be on their list. If this solution has assisted you, please rate it. ricardok45.
Dec 27, 2008 | Maytag MFD2561HE Stainless Steel Bottom...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
ther first refrig id have to see for better idea of problem but hte second with the flaps open and closing is going to need a high voltage board part num(12920710)---thats the part number i get wehn i look it up with the model MFI2568AEW. dont know where you got 12002608(that to is a h.v. board. which ever itssan easy enough repair to do yourself, its mounted on the rear of refrig and comes with programming instructions in the box
Mar 12, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Refrigerator
it has a bad main control board call maytag they will most likely repair it in warranty for you
Dec 09, 2007 | Maytag MFD2560HES Bottom Freezer French...
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Maytag MFD2561HE Stainless Steel Bottom Freezer French Door Refrigerator Logo
342 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
