Question about Samsung ML 1210 Laser Printer
Can't print using USB connection
My ML-1210 prints fine using IEEE1284 cable but not the USB cable. Recently, i upgraded my computer and it doesn't have IEEE1284 connection anymore, so i have connect it thru the USB port. I have downloaded the driver and when I turn on the printer the computer recognizes the printer but when I go to print, nothing happens. The computer sends the printing signal over but the printer doesn't acknowledge it. I get an error that the printer failed. Does anyone have problems with the USB port for this model?
  • 3 more comments
  • mel777 Feb 08, 2008
    the vista states the model is not in list and provide disk.
    do not have disk but download drives with .exe--the vista
    seems to only except a .inf type file. having problems getting
    vista to try downloader programs
    thanks
    mel
  • cnp2216 Mar 11, 2008
    Same results but I use a Mac with OS X 10.5.2
    The drive worked on an older Mac OS X but not on the newer version of OS X
    Samsung no long supports Mac computers.
  • Baba U May 29, 2008
    send to print using usb cable and I get an error message and nothing prints
  • Anonymous Jun 25, 2008
    my system is not detecting the printer
  • Anonymous Mar 25, 2014
    Dell laptop won't get any connection & it
    has been downloaded with a disc
Unplug printer and un install software. Delete printer in printers folder. Restart pc. Install software first and then connect printer. Also make sure your usb drivers is correct.
Posted on Sep 29, 2007
Hi, i have some problems with my ML-2010R, it doesn't respond to anything from the computer. when i press ON it makes the usual noises,eating and preparing for printing , but when i try to send a file...
try to use a new USB cable maybe the problem is on the cable this transfers the data from your PC to the Printer this is a common issue for printers. Or update your printer driver.
Sep 02, 2011 | Samsung ML 2010 Laser Printer
Keeps printing same doc. how do I clear it?????
you need to unplug your data cable which is connected from computer to printer, which is USB cable,
try this to clear all the print,
step 1. turn off your printer,
step 2. unplug the USB cable from your computer,
step 3. you can see at the taskbar near clock, printer image right click on that and and click stop printing,
and wait till clear all the prints from your computer then plug back your USB cable which is data cable and start using your printer again
Thank you for using Fixya.
Regards
Manish
Jun 11, 2010 | HP PSC 1210 All-In-One InkJet Printer
I successfully installed my ml-1210 on a new computer using the driver download, but it won't print the sample page, nor will it print the demo page when I push that little 2 second button on the printer. ...
did you do do a test print once you completed the install,go to printers and faxes in control panel right click on the printer select properties select print test page.if this print,close this right click on the printer again select use as default,this should take care of your printing problem.
Good luck
Aug 30, 2009 | Samsung ML 1210 Laser Printer
I have a Samsung ML-2010 mono laser not printing
Yes, you can make a self print test from the printer even if the printer is not connected to the computer. This means that the unit is in good working condition. Possibly your printer doesn't communicate with your computer. try this, hit start key>control panel>fax and printers>select your printer>right click to properties>click ports tab>check if the port is matched to the port you are using.also, make sure it is your default printer.
Jul 08, 2009 | Samsung ML-2510 Laser Printer
My printer is not receiving print commants
try this it should help uninstall everything to do with the printer. when you do to install the printer again let vista install it for you. vista has drivers for just about evreything included in it.
Jan 22, 2009 | Samsung ML 1210 Laser Printer
Randomly missing print spots just off center of page
this happens to myne all the time try cleaning all of the rolers and try a different brand of paper
Jan 07, 2009 | Samsung ML 1210 Laser Printer
Samsung ML-4500 with IEEE 1284 to usb cable not working
Windows XP/VISTA (do not install the CD)
1) Plug the cable into the USB port on your computer.
2) A prompt that says "Found New Hardware" will appear. Windows will then install the USB printing support driver automatically. You do not need to install the driver from the CD.
3) Plug the cable into the printer.
4) If your printer is already installed, click on Start, then Printers & Faxes. Right click on the printer you are connecting to and click on Properties. Click on the Ports tab and check the ‘Virtual printer port for USB’ port. Click OK.
5) You should now be able to print.
With XP, the biggest clue is to FIRST plug the cable into the usb slot, THEN the other end of the cable into the printer.
May 14, 2008 | Computers & Internet
HP PSC 1210 does not print at all
i dought dust would cause that, reboot pc and unplug printer
plug printer back in then turn computer back on, if still doesnt work try a different usb port
Jan 15, 2008 | HP PSC 1210 All-In-One InkJet Printer
Unable to print
If both printers are connected through a parallel switch, be advised that changes on the switch do not take effect until the computer is restarted. Those boxes worked fine under DOS, but Windows does not support them. Connect the Samsung printer to the USB port and make sure you use a good quality cable and not those thin and cheap cables.
Aug 30, 2007 | Samsung ML 1210 Laser Printer
Samsung ML 1210 Laser Printer Logo
374 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
