Question about Panasonic RR-US360 Digital Voice Recorder
Computer face removal
I have a compaq presario SR1810NX computer with spring loaded doors (to the closed position) for accessing the cd/dvd players. one of the doors has lost its tiny spring. I can see it, but cannot reach it. How can I remove the rectangular face without going inside the computer itself? Also, is there a repair/schematic manual available for this computer? If so, how can I acquire one for future use and how much is the cost? Your assistance is appreciated
    Brigadier General:
  • 6,966 Answers
Hi, In order to be able to remove the front panel cover, you must remove both side cover of the computer (remove rear screw and slide back). To remove the front panel: 1. Depress and hold the top square button (left side, top front) of the panel cover; 2. Depress the lower left tab; 3. Press on the right tab; 4. Front panel may then be removed. This is better explained in the service manual. It is available on line from the Compaq site/Product Information/Manual file name c00311113.pdf All other information and manuals on the same page with no charge. Hope this be of some help/idea. post back how things turned up or should you need further information. Good luck and kind regards.
Posted on Sep 29, 2007
  • Louie  Role
    Louie Role Sep 29, 2007
    Hi again, Looks like add was truncated by fixya.
    copy/paste to your browser pls.
Why does my compaq presario SR1810NX turn off immediately after turning it on ?
Beep sounds indicate a hardware problem, check you RAMs, remove them and air blow the RAM + its trays on the motherboard then try to boot up again.
Feb 20, 2012 | HP Compaq Presario SR1810NX PC Desktop
How to get the recovery discs
Hp/Compaq gives the option and reccommends that you make recovery cd/dvd's but you're only allowed one set per computer.. once you make the original's that's it.. you can't make numerous copies for use on other computers.. If you need them why not use the ones the tech made?
Jan 19, 2011 | Compaq Presario SR1810NX Sempron 3200+ 1.8...
Dvd door keeps opening. Won't load dvd. Won't stay closed.Compaq laptop. Bought at Wal Mart this summer. Problem started a few weeks ago. Aaaaargh.
Check and make sure a disk is not stuck in the disk drive. If a disk is not stuck try closing the door and hold the door close, shut down the computer. Start the computer and hold the the door while the computer reboots. Hope this fixes it.
Nov 08, 2009 | HP Compaq Presario R4000 Notebook
I have a compaq presario cq 60 laptop with Vista - i don't understand how to access the CD-ROM drive - I would normally expect it to appear as an additional drive using the Explore function, but I can't...
Normally it would show up in "my Computer" as a drive, if it is not, then the computer is acting like it is not installed or not enabled. Go to the device manager and look for the dvd drive there and see what the properties say. Put the computer on its back and with a small phillips screwdriver, remove the screw that holds the drive to the motherboard. Now flip the laptop back on its feet and insert an open paperclip into the small hole in the door of the dvd drive bezel, this willphysically trip the door to open. Pull the door and tray out and keep pulling and the rest of the drive will follow. Power up your laptop with the drive missing and access "My Computer" and see if anything changes. Now,power down the laptop, remove the battery....wait 30 seconds and slide the drive in and make sure it seats all the way in, replace the hold down screw, replace the battery and power it up. Let windows recognize the drive and load drivers for it. If it does not read the drive, there may be an issue with either the interface on the drive or the socket on the motherboard.
Oct 04, 2009 | Compaq Presario CQ60-220US PC Laptop
Replacement for the spring loaded door on my tower
No solution for this. All cd players are non repairable or at least not cost effective to repair. My advice is to just purchase another one. Cost for these is now in the $40.00 range - cheaper then getting this one fixed
Dec 30, 2008 | Compaq Presario SR1050NX (DW257A) PC...
Door ejecting
If you have a decorative bezel or door over your drives, that may be the problem. Sometimes the door presses on the drive release switch. Decorative bezels, meanwhile, have a spring-loaded extension button that goes through the extra case material to press the drive's actual release mechanism. I've seen a faulty spring on this type of arm cause a drive tray to go in and out at random, come out part-way and go back in, etc. — all without anyone touching the button itself. The effect is almost as if the drive is possessed. Kind of spooky when it happens, but fixing it is usually a simple matter of adjusting the spring or just removing the bezel completely (since it's only decorative). Alternatively, you may have a trojan on your machine that either fools with the drive automatically, or gives remote access to the drive so that someone else can toy with your machine over your network connection. "OfficePoltergeist" is a program that pranksters love to use to do this. NetBUS is another example of a remote tool from many years ago that could play with your CDROM trays. Your antivirus or spyware scans should be able to detect this, though... It is possible you have a new trojan of this sort that is not yet detected by antivirus software...
Oct 08, 2008 | Compaq Presario SR1810NX Sempron 3200+ 1.8...
Compaq presario # SR1810NX model
Please try to uninstall the memory and fixed back then start the computer.
i same problems; Back up your important files and then provide windowsxp bootable disk and boot to cd/DVD rom and install the new windows.
Jan 04, 2008 | Compaq Presario 5BW284 (202493-003) PC...
Panasonic RR-US360 Digital Voice Recorder Logo
131 people viewed this question
Top Panasonic Audio Players & Recorders Experts
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
