Question about Panasonic FP-7735 Black and White Copier
Turns on lights up, warms up, then nothing
Ok - i got one of these photocopiers cheap, plugged it all in except the sorter unit, turn it on, it warms up, gets ready, the green light on the print button lights up, but when i press the print button -NOTHING- what the heck?
  • hiaber Sep 29, 2007
    there are no error codes present at all, and yes, seller told me it worked fine, but - such is life. as far as i can tell every thing is locked closed, etc.
  • Anonymous Nov 08, 2007
    Machine was attached to a power strip, the power went off after it came back on the machine would say that it would warm up then print but never would print....................I unpluged it from the electric source for a couple of days....did not help.........left it off for days ....does not help..........checked to make sure all doors were closed all paper was cleared and all cartriges are in firm............what do I do now?
    Sergeant:
  • 274 Answers
Look in the manual under "trouble shooting guide". Start there first. What do the self tests say? What error codes are you getting? Are all the door locks engaged? There can be a whole range of reasons from something simple to something very complex and expensive. You got it cheap? Maybe you discovered the reason why. It probably needs a component that costs a lot of money and the previous owner didn't want to spend the money on. The ink pack alone cost $250 to replace. Don't give up there are several websites that have the parts and supplies for this copier. But you may need to have a service repair man fix for you initially.
Posted on Sep 29, 2007
  • Jerry Hess Sep 29, 2007
    Here's some links I found for you. Maybe there is something that will give you more information on how to solve your problem.
    Panasonic FP-7735 Parts Manual in English FP-7718/FP-7722/FP-7728/FP-7735/FA-S280/FA-A505/FA-S575/FA-S615 PPC OED9610349C1 file:\\Panasonic\NoTest\7
    Panasonic FP-7735 Parts Manual in English FP-7718/7722/7728/7735 OFD9610349C1 file:\\Panasonic\ALL\FP-7718_par.pdf
    Panasonic FP-7735 User Manual in English FP-7718, FT-7722, FT-7728, FT-7735 FFPTD0757 file:\\Panasonic\ALL\FP-7718_eum.PDF
    Panasonic FP-7735MX User Manual in English FP-7735MX/7742/7750 FFPTD0846B file:\\Panasonic\ALL\FP-7735MX_eum.PDF
    But if you had a service tech come out and set it all up for you you will have three things.
    1.) You'll know what the problem is (was),
    2.) You'll know how much it will cost to fix
    it and it's condition.
    3.) It will be working.
Model SF2530 photocopy Erroe F1 how to reset
F1 00 Content Sorter communication trouble Detail Communication line test error occurs when power is turned on or after the exit of a simulation mode. Improper communication with sorter Cause Improper connection or broken wire of connector or harness between copier and sorter Sorter control PWB defective Control PWB (PCU) defective Malfunction due to noise Check and remedy Clear by turning the power supply OFF/ON. Check communication line connector and harness. Replace sorter control PWB or PCU PWB. F1 02 Content Sorter transport motor error Detail Transport motor drive trouble Cause Motor lock Check and remedy Check transport motor operation with SIM3-3. F1 03 Content Sorter guide bar rocking motor trouble Detail Sorter guide bar rocking motor drive error Cause Motor lock Motor speed error Overcurrent to motor Sorter control PWB defective Check and remedy Check guide bar motor operation with SIM3-10. F1 04 Content Sorter indexer lower limit detected Detail Indexer has exceeded lower limit. Cause Sensor defective Sorter control PWB defective Check and remedy Check sensor with SIM3-2. F1 05 Content Sorter indexer upper limit detected Detail Indexer has exceeded upper limit Cause Sensor defective Sorter control PWB defective Check and remedy Check sensor with SIM3-2. F1 06 Content Sorter bin shift motor error Detail 1) Bin shift is not completed within 2.5 seconds after bin shift request Cause Motor lock Improper motor speed Overcurrent to motor Sorter control PWB defective Check and remedy Check bin shift motor operation with SIM3-4.
Jan 11, 2010 | Sharp AR-5316 Advanced Digital Imager...
I have a RICOH FT 4022 Copier and when I switch it displays U 6
Ricoh 4022, 4027 Код ошибки Описание C1 Front door open C2 Exit door C3 Cassette cover C4 LCT cover C5 Sorter open or not latched to machine, or fuse 304 on DC power board C6 ADF cover C7 Right side cover E101 Exposure lamp too long E103 Frequency problem E120, 121 Scan home problem E124 Scan drive problem E140 Lens home, or fuse 303 on DC board E141-143 Lens home sensor, fuse 303 on DC board E144, 145 Mirror sensor, fuse 303 on DC board E191 Image density sensor error E302 Charge roller problem or HVT problem E346 Bias loss E351 Image density sensor problem E352 TD sensor error E353 Vsp problem. Dirty or bad image density sensor E354 Vsg problem. Same as E353 E355 Toner density sensor problem E356 Same as 355 E405 Transfer belt or charge roller drive E440 Main drive E442 Drum charge thermistor E501 Upper lift motor E502 Lower lift motor E503 1st tray motor E504 2nd tray motor E505 3rd tray motor E506 Tray main motor drive problem E507 LCTl lift motor E522-525 Jogger sensor E541 Fuser thermistor E542 Fuser temperature too low E543 Fuser temperature too high E544 Fuser temperature too high E547 Fuser lamp won't shut off E548 Fuser temperature too high or too low E620 Communication problem between main board and ARDF E621 Communication problem between main board and sorter E623 Communication problem between main board and paper trays E720 Sorter stapler timing roller sensor E721 Sorter stapler bin lift sensor E722 Sorter stapler jogger sensor E723 Sorter stapler grip sensor E724 Sorter stapler error E900, 901 Copy counter U2 Key counter U6 Fuser unit not installed properly U7 Duplex unit
Aug 24, 2009 | Office Equipment & Supplies
Minolta EP4320 - How to clear the "Cd" error code
A "CD" code means some thing is not closed correctly or attached correctly. It has been a very long time scine I worked on one, but I believe that when you added the duplex unit there is a bottom part of the duplex unit that is held on with two screws at the bottom and one shoulder screw at the top. From what I remember is that if the bottom part of the duplex unit is not flush withe copier stand and the top part of the duplex unit the joggers will not move and there is a sensor flag that get stuck in the bottom part of the duplex unit. Also, di you connect all of the connector for the unit that goes inside the copier it's self. You are dealing with a copier that is over 10 to 15 years old. Good Luck
Feb 16, 2009 | Minolta CF1501 Copier
AKAI LCT3201AD
Find and replace the following caps, Ec18, 19, 20 / 1000uf/16v,
Ec9, 10 / 1000uf/35v, Ec14, 25 / 470uf/35v should resolve the problem. You can get the caps at almost any electronics supply.
This is a common problem in this unit.
Good Luck!
Happy Thanksgiving!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Nov 27, 2008 | Akai LCT2715 27 in. LCD Television
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Only turns on but does not boot
check for the cmos battery!! see if it still on 3 volts
Feb 28, 2008 | ASUS P4VP-MX Motherboard
Toshiba 3550 Document Feeder
1- you've already established that the jamming is coming from the sorter, since you said they jam as they exit the copier into the sorter bin.
2- check to see if the sorter is aligned, is one side higher than the other? is it crooked? are the wheels of the sorter turning as the paper exits the copier, is it plugged into the copier? does it show "connect sorter" when detached from copier?
if not the sorter board may be bad.It may need to be aligned ( not easy if not used to doing.)
Nov 25, 2007 | Office Equipment & Supplies
Durabrand Television
cold sorters that means needs to sorter it again
Nov 13, 2007 | Durabrand DWT2405 24" TV
Panasonic FP-7735 Black and White Copier Logo
143 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
mahesh y.h
mahesh y.h
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
