Question about Microsoft Xbox 360 Console
No display but sound
When i switch on the console there is no display but sound can be heard
    Problem Solver:
  • 7 Answers
Did you check to make sure the TV - HDTV switch on the AV cord was in the right position?
Posted on Oct 01, 2007
F2 code
Hi, F2 code on the Kenmore indicates a problem with either of the control board and the user interface board. Run the console and indicators diagnostic test mode to find out.
Console and Indicators Diagnostic Test Mode Activation
  1. While in standby mode press the following button sequence within four seconds: SOIL LEVEL>WASH RINSE TEMP>SOIL LEVEL>WASH RINSE TEMP
  2. Press START within five seconds when "dt" shows on the display. All indicators in display are lit and "88" is displayed.
  3. Press START again. The two-digit display and the status indicators turn off while all other indicators remain lit.
  4. Press START again. The two-digit display and the status indicators turn on while all other indicators remain lit.
  5. Rotate the WASH CYCLE selector back and forth. The indicators will switch on an off.
  6. Press the buttons to check the functions. The indicators switch on and off and a beeping sound will be heard when a button is pressed.
  7. Press STOP or POWER button to exit diagnostic test mode.
  8. If no indicators light up or if no beeping sound is heard when a button is pressed or if some buttons do not light up indicators when pressed, check the control board, the user interface board, and the connection between them.
  • Unplug the machine.
  • Remove the three screws on the back of the console.
  • Lift the console off the cabinet.
  • The control board is located on the right side of the console viewed from the front of the machine. Disconnect the middle wiring harness connector on the right side of the control board near the pressure transducer hose.
  • Clean the connector and the terminals thoroughly with brush and alcohol.
  • Reconnect and disconnect the connector several times.
  • Reinstall the console and reconnect power.
  • If the problem is not resolved, replace the user interface board.
  • If the problem is still not resolved with the replacement of the user interface board, replace the control board. You may also replace both board at the same time and keep the old good board as a spare.
Take care
Jun 20, 2010 | Kenmore Oasis 27042 Top Load Washer
Tip
Display problems while playing Virtual Console games
If you are experiencing display issues (dim, blank or half-blank screen, ghosted image, etc.) with a Virtual Console game while using the Component Video Cable, please read the following:
Some Virtual Console games default to displaying 240 lines of video. Some HD TV's are unable to display a signal with only 240 lines. Try the steps below to set the Wii to output 480 lines of video, which may solve the problem:
  1. While on the Wii Channel Menu (main screen of the Wii), connect a Nunchuk to Wii Remote.
  2. Select the Virtual Console game from the Wii menu, then select "Start" to begin the game.
  3. When the game starts, press the Home button on the Wii Remote. (In many games, the music can be heard when the game starts.)
  4. Select "Operations Manual" from the Home menu.
  5. Press the Z + A + 2 Button simultaneously (the Z Button is on the Nunchuk). A sound will be heard if the button combination has been entered correctly.
  6. Close the Home menu. The game should now display correctly. Note: You will not have to do this the next time you play, as the Wii console will remember these settings.
If the Virtual Console game is still not displaying properly, but all other games work fine, please call 1-800-255-3700 so that we may assist you further.
on Mar 04, 2010 | Video Game Consoles & Games
I have a kenmore Oasis that powers up but wont start
Activate the Console and Indicators Diagnostic Test Mode to check the functionality of the .
  1. While in standby mode, press the following button sequence within four seconds: SOIL LEVEL>WASH RINSE TEMP>SOIL LEVEL>WASH RINSE TEMP
  2. Press the START button within five seconds of "dt" showing on the display. All indicators should turn on and "88" is displayed.
  6. Press the buttons to check the function. The indicators will switch on or off and a beeping sound will be heard when a button is pressed.
  8. If no indicators light up or if no beeping sound is heard when a button is pressed or if some buttons do not light up indicators when pressed, check the user interface board and its connection to the main/control board.
  • Clean the connector thoroughly to ensure a good connection.
  • Run the diagnostic test once again.
  • Replace the user interface board if it fails the test once more.
Refer to the next post if no problem is found on the user interface.
Jan 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My playstation switch on but nothing is seen sound
Try manual video reset first.
While the PS3 if off (RED LED SOLID)
Hold down the power button until you hear the second beep, quickly release.
Display should be back. Let me know if it's not.
Nov 20, 2009 | Sony Playstation 3 (PS3) Console
Av cable displays no video but only sound
Use your ps3 warranty and get Sony to replace that one with a new one.
Aug 06, 2009 | Sony Playstation 3 (PS3) Console
My ps3 works with a hdmi cable but it will not display to any tv.
hold your finger on the restart button(the button next to disc eject button) for 5 sec to reset the settings
Jun 05, 2009 | Sony Playstation 3 (PS3) Console
How do you change the output setting from hdmi to the rca cable setings? I have no picture screen on my crt tv.
you have to reset the ps3 because you have it with hdmi before and the ps3 is looking for an hdmi connection is very easy and there is nothing wrong with your ps3 ok so do the follow
turn the power switch off on the back of the unit then put your finger in the on/off switch now turn the main switch on the back of the unit you will heard a first bip sound this is when your ps3 turns on ok keep your finger there in the on/off switch until you heard another bip sound now remove your finger from the on/off switch and bingo this will reset your video settings now you can see picture again using regular av and every time you use hdmi you have to do this again
Jun 05, 2009 | Sony PlayStation® 3 (80GB) Console
Xbox runs although no display; already checked connection and cab
Well if you dont have a warranty on the console, then open the console and check the graphics card. You cant miss it bc it looks like a big fan and usually says the makers' name on it. However if you currently hold a warranty on the console, it is highly recommended that you send the console along with any accessories that may cause problems back to Microsoft. Information can be found at their website at http://www.xbox.com/support/warranties.
Apr 28, 2009 | Microsoft Xbox 360 Console
I have no sound with any movies on my blu-ray player
go to sound settings and make sure you got the settings correctly there is a lot of different settings if somebody move the settings accidentally then they have to be reset how well here is how turn the main power switch off now put your finger in the on/off switch in front of the console now turn the main power switch on keep your finger in the on switch you will heard a bip this bip is when the system turns on keep your finger there until you heard a second bip then take your finger off now your video and audio settings have been reset
Apr 24, 2009 | Sony Playstation 3 (PS3) Console
Xbox 1, switches self off
sounds like a power supply problem try taking it apart .it will be the long slim board that the power cord plugs into.. make sure to unplug it from the wall first.look for burnt places on the board..if you find a problem ask around and find a broken xbox that comes on and displays an error message. that meens power supply is good and there is some other problem just replace your power supply with that one... good as new
Nov 16, 2008 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
32 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
