Question about Nikon Super Coolscan 8000 ED Film Scanner
Autofocus Operation Failed???
Haven't used the scanner in a month or so and when I recently try to run preview or scan I get 'The autofocus operation has failed' and if I continue running the scan I get a blank white page. Anyone come across this problem?
Yes, I have had the problem before and solved it by re-installing the software.  It has happened again but this time I beleive it is a VISTA related problem.
TexRail
Posted on Oct 18, 2007
I saw the error "an error occurred during preview. if the scanner is being used. please wait for it to complete the task.and then click preview" when iam attempting to preview the scanned pictur how c
If you continue to get this kind of error after restarting the computer, you may need to update the scanner's device drivers or reinstall the included software. You should also make sure only one program or application is attempting to use the scanner by closing all but the one program you are trying use with the scanner. One last note - always either let the program you are scanning to operate the scanner or let the scanner invoke its default application by pressing the scan, fax or copy buttons on the scanner. Do not for instance try and scan an image into a running program that initiates the scanning process itself while also invoking a scan from the scanner's control panel. The two operations will conflict.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Nov 19, 2014 | Office Equipment & Supplies
Nikon Coolscan 5000 ED not scanning
Have you tried resetting the scanner itself?
Jul 09, 2008 | Nikon COOLSCAN 5000 ED Film Scanner
Autofocus malfunction
Nice camera, and I've had similar problems before.
What's more typical than anything else, is the gearing for moving the lens gets misaligned or jammed. This can happen with foreign object getting in, like fine sand particles, or the lens being jarred or bumped during operation.
For a camera like this, I would not recommend trying to fix it yourself, because you can end up doing more harm than good. A trained tech can often clean it out and repair the problem fairly quickly, to get you back to using it.
Attempting to use it in this condition could potentially make the problem worse, depending on the cause.
Feb 14, 2012 | Sony Alpha DSLR-A200 Digital Camera
What digital nikon cam works autofocus in a nikkor micro AF 105mm f/2.8D?
This lens lacks the autofocus motor, so it will only autofocus on cameras with the motor. This lens will autofocus on every Nikon digital SLR except for the D40, D40x, D60, D3000, D3100, D5000, and D5100. It will autofocus with the D1 family, D2 family, D3 family, D50, D70, D70s, D80, D90, D100, D200, D300, D300s, and D700 (I hope I haven't left any out).
Jul 03, 2011 | Nikon Cameras
I recently shot three rolls of color film with my ZX-7 in auto pict mode and all the negatives turned out blank (underexposed). What happened?
The shutter assembly has failed, a common fault with all older autofocus SLR's. it's nothing to do with the autofocus itself, just that AF SLR's usually tend to have fully electronically operated shutters which cannot be serviced and repaired like older models.
The only fix is to replace it, but it's no longer available and even if you do find one the repair is not economically worthwhile.
If you're not too choosy as to the brand, then free similar SLR models complete with lenses are regularly available on FreeCycle and Freegle. It's where I got all of mine.
May 13, 2010 | Pentax ZX-7 35mm SLR Camera
When I preview a document on my V500 Photo scanner, The operation goes to completion, but an image is never displayed. I have upgraded to Windows 7. The program ran fine but has suddenly stopped...
Make sure you didn't change the default settings for the scanned image. Sometimes we fiddle with those settings and create a file size that is either too large or out of bounds for our scanner. also try reducing the scanned image density and see if that helps. Sometimes the image is just too large for your installed memory to handle, I saw a jpg image on a customers PC once that was 8 gigabytes and he complained that it would never load.
Mar 09, 2010 | Computers & Internet
Konica Minolta DiMAGE Scan Dual IV Film Scanner driver in an IMac
DS Dual 4 even works with SnowLeopard on a CoreDuo MBP. But it doesn not support Autofocus when used under USB2. You have to use a USB1.1 Port, if you want to use autofocus function. Every time the software crashes, because you tried e.g. to use autofocus with USB2, you will have to close the application, go to the folder User/Library/Preferences/DS Dual4/... and look whether there is a file name something like "MFSlib...." and pull it to the trash bin. You can start the application again. PS.: Your keyboard USB port is a USB 1.1 port!
Jul 06, 2009 | Konica Minolta Dimage Scan Dual IV Film...
LS5000 ED with slidefeeder sf 210
Hi there I had the same problem with auto focus sf-210.
If tried many things to correct the problem and what I found was that if you you put a small book halfway on the opposite site of the power button then I have maybe 1 or to slides out of focus and the other 35 slides are perfect ! (I used it with HAMA slides other slides I didn't test )
Hope this wil work also for you,
Paul
Dec 15, 2007 | Nikon COOLSCAN 5000 ED Film Scanner
Error Code ox24050010
sounds like a proprietary TWAIN driver from Canon must be installed...try forcing driver from cd under current devices driver...under device manager, look for imaging devices, then right click-properties then driver-update driver...make sure cd is in
May 30, 2007 | Canon CanoScan FB630P Flatbed Scanner
Nikon Super Coolscan 8000 ED Film Scanner Logo
560 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Ric Donato
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
