Question about Dell Inspiron 2200 Notebook
Cd drive is not recognized
My cd/ r/w /dvd drive has disappeared again - it did this once before -"ran away from home" - went to burn a cd and {{Poof}} "D" drive no onger there - not in my system info -CD ROM - nothing there what up?
  • Bill Butler Oct 02, 2007
    not recognized in device mgr, so can't disable it...
    Brigadier General:
  • 6,966 Answers
Hi, The problem of the CD drive missing (and sometimes the A drive likewise) has been known to come up from time to time when PCs were upgraded to SP2, on some Dell models, the InCD feature of Nero, or those with Roxio CD creator 5. A couple of things you can try: 1. Uninstall references to the CD in your Device Manager, reboot. Windows is suppose to autodetect and auto install such devices; 2. verify that the CD is detected in the CMOS/BIOS, save & exit; 4. download and merge to your registry a quickfix - 5. If installed, uninstall/remove InCD or Roxio CD creator 5. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Posted on Sep 29, 2007
  • Louie  Role
    Louie Role Oct 02, 2007
    Hi again,
    Pls verify that the CD drive is initially recognized by the motherboard in your CMOS/BIOS setup. Further, check the cable and the power connector.
    Cheers.
SOURCE:
My cd drive does not recognise cds
Okay. First of all is it a cd drive in your computer as opposed to a DVD drive? If you put a dvd into a cd drive it cannot recognize the dvd. A dvd drive can recognize a cd, but a cd drive cannot recognise a dvd.
Does your computer actually recognize the drive as being present?
If the drive isn't recognized by the computer try:
power off the laptop
Physically remove the cd or dvd drive
power -up the laptop without the cd/dvd drive
power off the latop and refit the dvd/cd drive
power it up again and see if the drive is
recognized
If the drive IS recognized by the laptop but won't play any disk it's probably the drive itself at fault. You can try gently cleaning the inside of the drive - the optic that reads the disk. However, the usual cause is failure of that optic which read the disk information. It cannot be repaired.
The alternative to fitting a new drive is to buy a portable dvd drive. They connect via a usb cable. Have a look on Ebay
Dec 21, 2014 | Computers & Internet
I have a Pioneer DVR-111 D or DBK or DSV on my PC tower and it's been there for about 2 years. I also had a Sony Burner on the same tower so I could burn from 1 DVD to another. The Sony went out so I...
first make sure that your dvd drive has power. to test just press the eject button. go to device manager, find dvd/cd-rom drives there and expand it. If the pioneer dvr is present and has an exclamation point then just reinstall the driver for that drive. if not there then check in the bios if its there, just got to system information in your bios. If not there then open your tower and unplug and replug the cable connecting your drive to te motherboard. then check again.
Sep 16, 2010 | Pioneer Computers & Internet
I have 2 dvd writer drives that are not being found by software
get on the computer manufacturers website and download the drivers for your dvd on there.
May 24, 2009 | HP DVD1040e DVD-RAM Burner
Will not read my burned dvds
In this case need update the Firmware of DvD/Cd Rome
Apr 10, 2009 | NEC Computers & Internet
CD-Rom drive missing
Go to this webpage and you will be able to solve the problem. http://support.microsoft.com/kb/314060#letmefixit Basicallly, you'll be resetting the registry to recognize your CD ROM again. Be SURE TO FOLLOW STEP BY STEP. Print the instructions first so that you don't lose your place.
Apr 09, 2009 | NEC NR 7900A (NR7900) CD-RW Burner
When i try to burn on hp1040e dvd burner it wont recognize the dr
you may not install the proper drivers of your burner, install it again and use some other burner application like nero cd burner etc.
Feb 10, 2009 | HP DVD1040e DVD-RAM Burner
Toughbook CF-51 Laptop DVD Drive Problem
It could be a software or driver issue. First try updating the drivers for the drive, and try either using different burning software or uninstalling & reloading your current software. I had a cf72 with a DVD/CD combo drive that the DVD reader went out. This could also be the issue, if so you'll need to replace it in order to burn CD's.
Jun 10, 2008 | Panasonic Toughbook CF-51 Notebook
Mi dvd-burner doesnt recognize blank DVDs and doesnt burn them
Sounds like bad media to me. Have you tried a more expensive blank like Memorex?
Geno
Feb 27, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
Lite-on DVD R/W combo LH-20A1L BLO5 Blank discs not recognized
Have you checked device manager to see if you have a yellow checkmark on your DVD./CD drives? if ok, sounds to me like the maker of the LH-20A1l BLO5 either needs to fix your problem or replace it. The Nero 7 should enable it to work correctly.
Feb 14, 2008 | Computers & Internet
Dell Inspiron 2200 Notebook Logo
95 people viewed this question
Ekse
Clive
Clive
