Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
No ice cubes with my one year old french-door Maytag #MF12568AE Refrigerator . I have confirmed the water supply and pressure, but am unable to remove the dispenser unit itself to check further. I'm afraid to pull any harder for fear of breaking something expensive! Is there a fastener securing this unit? All I see is a plastic cog on a white flexible tab coming out of the left side. Thanks for your kind help.
  • chevy guy Dec 15, 2007
    water freezes where it comes out of the top of fridge and goes into the little tray. then it keeps on freezing and jam's everything up.the only way to get it apart is heat from a hair dryer . once it thoughs enouth you can then get it apart and though it out. Any help.
  • Milo38372 Dec 16, 2007
    I have the same problem, no ice... water is fine. Have removed tray and replace, still not making ice. Any suggestions on what to check or fix?
    Thanks, Kathy
  • 447 Answers
Perhaps there is ice holding it in because that tab is all that holds it.
Posted on Sep 29, 2007
6ya staff
SOURCE:
Maytag MFI2568AES- ice maker making ice but cannot harvest
Sounds like the thermostat inside the ice maker that allows the heater to come on during harvest cycle is bad. You will need to replace the ice maker.
Ice Maker Kit For Maytag Refrigerator Model Number MFI2568AES
Sep 24, 2015 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag model MFI2568AES not making ice
8869f6a5-d8bf-4729-a06a-b1440ff441bc.jpgThe water dispenser control is only part of the dual water control valve. If water did not refill the empty ice maker tray after dropping ice into the ice bin the=> 67006322 Water Inlet Valve will need to be replaced. Let me know should you have questions, Thanks Sea Breeze
May 25, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
Why are the ice cubes from the ice maker hollowed out in the middle?
in the ice maker there is a series of small pipes about an inch long emersed in a tray of water,the gas flows throught these pipes frezzing the water making the ice and thats why its hollow in the middle
Aug 26, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2568aes:none of the keypad controls work. Is it the control board that is no good?
Check the harness up at the top of the door. Remove the cover and be sure everything is plugged in correctly. Sometimes the harness will work loose do to door movement.
Aug 18, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag refrigerator stainless steel french door bottom freezer...lights flashing and ice maker opening and closing/making sound
Im thinking maybe a power surge was felt by the refrigerator.
Try unplugging from wall for a couple minutes and then plugging it in again.
Hope this resets it...
Jul 23, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Our frig ice cube door chute keeps slaming and the lights are going crazy on the push button board. model MFI2568AES SER 10967637JR
Your control board is bad. Unplug refrigerator and replace it, follow instructions on board to reprogram and you should be good. It's on the back outside of refrigerator under panel. Or, call a repairman to do it for 400.00 plus. Hope this helps,
Oct 24, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag refrigerator
IF BOTH WATER AND ICE MAKER ARE NOT WORKING YOU MAIN NEED THE MAIN BOARD. THERE IS NO FUSE.
Apr 24, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Front door dispenser
Low water pressure will cause this symptom. Make sure you have a minimum of 35 pounds pressure supplying the refrigerator with water.
Apr 04, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Not getting ice
sounds as if the icemaker is getting too much water and causing the unit to flood out. aside from replacing the icemaker you may be able to adj the amount of water going into the icemaker. there is a screw that holds the front cover of the icemaker inplace. remove the cover and you should see a screw  with a + and - sign on it. try turning the screw 1/4 turn then wait for the icemaker to cycle and see if it improves. keep making theses adjustments until your problem is solved thx peyton
Jan 27, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Mfi2568aes ice maker
it is under warranty call for service
Jun 20, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
431 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
