I just put a new motor on my dryer. It runs fine when I first turn it on. Then when I open the door the dryer stops, but the heating element is still on. I close the door and hit the start button again. The drum does not turn. The heating element continues to burn. If I turn it to the off position, the heating element goes off. Please help!
-   Similar: Have a Kenmore 10 year old dryer. After starting and then opening door to add an item, the dryer stops and cannot be reset for 1-2 hours. After stopping, when the electronic start button is pressed, a rubbing sound is heard. This happens often when others use the dryer and it ties up the dryer for a long time. After about 2 hours it starts to work again. Please help.
Nikki-   dakotanorth
if the dryer worked fine before with the element not staying on when you open the door, etc, then what you have done is a very common mistake to make, you must have dislodged a wire off, or maybe placed one back in the wrong place, its a very easy error to make, which is why when removing parts for repair on any appliance you must make very detailed notes, better still take digital photographs with a digital camera
double check any wires etc, don't worry i am a retired appliance engineer and even we can make this mistake
I have a Maytag Performa Dryer. It is spinning but there is no heat. I have checked the circuit...
(More)
I have a Maytag Performa Dryer. It is spinning but there is no heat. I have checked the circuit breaker it is on. I have cleaned the vent pipes and they are clean. How do I get the dryer to get heat and dry the cloths
