Question about Panasonic PT-53WX54 53" Rear Projection HDTV
Problem with color
I have a panisonic pt-56wx53. the tv works fine exceopt for the green. the lamps all woork but the green seems to lift off of the other colors at the top and bottom of the screen. i tried convergence but didn't work. right now i turned down the green color marking factory setting. the other colors are converged but are off because green is turned down. there is no one around where i live to fix tv's anymore. i am ceertified in electrical and electronics in automotive but never touched a television set. can anyone tell me what i can do to fix this. the tv is only 3 years old and i work 10 hour days so it don't get a whole lot of use
    Genius:
  • 1,694 Answers
Replace convergence STK IC's,then realign to factory spec using service literature fo info.
Posted on Sep 29, 2007
SOURCE:
I HAVE A PANISONIC HDTV1808I PROJECTION TV MODEL PT-51HX42F ITS A 2003 YEAR IT WAS WORKING THEN WENT TO TURN IT ON AND NOTHING ITS POWER RED LIGHT BLINKS 5 TIMES THEN PAUSES AND STARTS BLINKING THE SAME...
You need to replace the "Lamp" check Google Shopping for pricing. Enter your TV model # and add the word "Lamp" Make sure you get a Phillips or Panasonic lamp don't get a Chinese knockoff. They don't last!. Hopr this helps.
Jul 02, 2011 | Panasonic Televison & Video
We have a Panasonic PT-56wx53 projection TV that has a double image problem. We have tried to fix the issue with the convergence feature, but the blue color will not line up, red and yellow working fine. ...
Does this problem happen all the time ? What I mean is , if your watching the local news thru your cable/sat box does ot happen, or just when using aux imput. Either way, double image, or shadowing, is usually caused by a defective wire. Troubleshoot each unit, unplug everything and start from scratch.
Mar 06, 2011 | Panasonic PT-56WX53 53" Rear Projection...
PT50LC14 Color problem with color too much yellow and green no white or blues can not correct is this the lamp again im on why does it seem that I end up replacing the lamp every year (on number 3 now)....
ok,,your problem is not on the lamp itself.,the problem is on your screen controller.the controller is connected on the plyback you can adjust the screen intensity of the red,green,blue cathode..on your screen adjustment.
May 17, 2010 | Panasonic PT-50LC14 50" Rear Projection...
I have a panasonic pt-60dl54, the sound works but green picture
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens.You will need to replace the DMD board. Have a blessed one!
Apr 13, 2010 | Panasonic PT-50DL54 50" Rear Projection...
I have a blury picture and lost the color green.
sounds like a blowen bulb
doctor i think it's time to open her up and look inside from the back
open rear cover and turn it on look to see if all the bulbs are working
if a bulb is dead then you figured it out and with a little work can save some cash on a repair guy
Aug 03, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Panasonic PT-56WX33/red light blinks 3 times ovr-n-ovr
It's one of two things, a bad chipset, or bad lamp. 200-250 repair. Hope this helps
Jul 07, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Red tube out!!!!
Your TV is not DLP it is projection it has 3 tubes RED /GREEN /BLUE cost of new tube $500.00 used if you can find one maybe $100.00
Feb 28, 2009 | Panasonic PT-53WX42 53" Rear Projection...
The color looks off
most likely one of your component cables is loose or unplugged. this will stop one of the colors from coming through, thus throwning off your color. you need to check your red, blue, and green cables.
Jan 02, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Picture quality on PT-50LC14
clean out the housing (where the lamp is) the go through your menu and check the tv settings ie...color temp, picture, contrast, ect...try resetting it back to the default and go from there
Nov 09, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Colors double
You appear to be having the same problem that I am having. I just found this solution and have ordered the parts, but not repaired yet. I think this link may help.
http://www.fixya.com/support/t921322-double_image
Jun 19, 2008 | Panasonic PT-56WX53 53" Rear Projection...
Panasonic PT-53WX54 53" Rear Projection HDTV Logo
69 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
