Ricoh Model Aficio 1013F Toner
I replaced the toner and it does not accept the new one. It is the correct toner model. I can hear it tr7ying to load but nothng happens.
  • 24 Answers
Is the old catridge was empty at the time of toner changing? Check the old catridge.If it is not empty it is the problem with the Drum unit.The gears in the drum unit may be damaged.confirm it and change the unit.
Posted on Sep 29, 2007
  • Swaroop js Sep 29, 2007
    You can try one more thing.take out the new toner catridge and remove the white cap also from it.Put it back.Do this by keeping the machine 'ON' condition.
No loading toner my ricoh aficio 3025
you need to replce the PCU - unit order code is
  • B205-0153
  • that depends on the counter number.
  • or the cap from the other toner is still inside the the toner holder.
  • check the old toner bottle does have a cap on it.
  • how ever for i need the print counter to see if the PCU is for replacement.
  • write the print counter, and see do the old toner bottle have ca p on it or is just a open hole.
  • please write some additional info.
  • Best Reagrds
Oct 16, 2016 | Ricoh Aficio 3025 All-In-One Laser Printer
How to reset ricoh aficio error toner cartridge is almost empty , even if toner is new
please give your model no.
mostelly u can do this; remove inside cape of yor toner bottel and refit htis will solve yor problem
Dec 08, 2014 | Ricoh Office Equipment & Supplies
Toner will not loan
Either toner transport pipe cloged or toner pump gone. Only new pump will solve it, but first I would check the rubber pipe that transports the toner. That is most likely
Apr 18, 2014 | Ricoh AFICIO MPC3500 1-SD YLD BLACK TONER...
I have a Ricoh Aficio 1013F that has a about 65000 copy count. I replaced the drum/imaging unit a few months ago. recently, we stupidly let the machine run a week or so while it was calling for a toner...
I think you will have to reset it ..and the procedure to follow is this..
take it slow and be sure it is the correct one ..If it seam not to work try again ..
Press "clear mode" key then enter107 then press and hold down "clear/stop" key, touch on screen for "copy" then press 5992 hit enter, touch 0 to print out the standard setting list, turn off the copier when you finish.
Aug 13, 2011 | Ricoh Aficio 1013F Copier
The blak toner cartrige is new i still get toner empty mesage is ther a sensor or switch ive shaken reloaded still faults out
look my friend check that toner motor rolling or no ok and then but prorgram toner 2207 it will be disappeared
Jan 05, 2011 | Ricoh Aficio 1013F Copier
On my Ricoh aficio super G3 the toner wont load after replacing, the cartridge rotates but wont load
FYI "super G3" is the type of fax that is in your copier, not the Model of the Ricoh. Did you remove the steip after you put the toner in?
Aug 20, 2010 | Ricoh Office Equipment & Supplies
Ricoh Aficio 1232c REFILL
You can't use any other brand of color toner to refill the AF1232, you'll have all kinds of issues. They do have compatible toners (generic) for that model but highly recommend OEM.
Mar 31, 2010 | Ricoh Aficio 1232C Color Copier
Won't always print the job
Yes, that is correct, the 1013f is in the same series as the 120.
You can install it as you were trying, or get the latest driver here: http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/x12_13/x12_13en.htm#Microsoft%20Windows%20Vista
Apr 17, 2008 | Ricoh Aficio 1013F Copier
148 people viewed this question
k24674
Marvin
Marvin
