Question about Asko D1776 Built-in Dishwasher
Asko Dishwasher F2 Error Flashing
Out of the blue (the dishwasher wasn't even running), the lights on my Asko Dishwasher D1776 began to all flash in addition to a flashing F2 error message, plus the machine began making a continuous, load noise. I tried holding the dishwasher's buttons down for several seconds to get it to restart, but this does nothing. The only way I've been able to get the noise and flashing to stop is by cutting off the electricity to the circuit that is connected to the dishwasher. Any ideas about what's causing this and how I can fix it? Thanks.
  • 7 more comments
  • tleco Nov 16, 2007
    EXACTLY the same
  • debp Dec 02, 2007
    Our unit started flashing F2 with all the other lights flashing as well. This was half way through our second load today.
  • Anonymous May 26, 2008
    All,
    I too had the very same problem - I have an Asko D1876. While searching for a fix on the net, I found that several others have the exact problem. Seems that the drain from the main tub on Asko's have a leaking problem at the plastic flange. If your cycle begins normally, then defaults to F2 - this is probably your problem (as was mine). There is a face-plate that you can remove just below the door (is held in place with screws - unplug your machine first). This will give you a view of the motor and drip pan below. If there is water in that drip pan, remove that water using a sponge - that should allow the float to go back to its normal position. Then, leaving that face plate off, plug back in your machine - hopefully it has returned to its normal function (if it remains in F2, your float or water leveling sensor may be bad). Run a cycle and look underneath for any leaks. I repaired my leak by removing that plastic flange and using Pummer's Putty ($3.75 at ACE Hardware) around the seal and then screwing the flange back in place. Stopped the leak and now the machine works just fine. Hope this helps, Doug
  • crtimjoy Jun 23, 2008
    same problem. did the same as above to try and fix but it just keeps with the loud noise and does not do cycles. HELP.
  • will Jul 21, 2008
    ours was the same, only once i got the water out of the drain pan, the cycle started working and then it got to one minute left and it won't stop running. like it is stuck on the last minute of the cycle. any one have any answeres?
    thanks
    Will
  • Anonymous Aug 29, 2008
    same as described
  • jonesjk1963 Mar 03, 2009
    How do i get to the drain pan on a asko d 1776
  • MonsElijas Mar 04, 2009
    have a asko 1855 and got the F2 error message when i opend the door approx 5 min in the program to put in some aditional pots and pans. When i closed the door, iguess the error faultcode F2 came up. I didnt notice it at once, but when i did, all the lights where flashing too.
    I am 2 steps away from a raging panikk-attack, so please, what to do??
    ..i have only one glass and two plates left =(
    Dag Erik
  • celticzoo Apr 21, 2009
    My Asko D1976 flashes the "F2" code in the middle of the washing cycle. It will not shut off by holding down the power button. What does this error code indicate? Please advise. Thank you
F2 flashes, and wll not stop runing. No water in pan. help
Posted on Oct 09, 2008
  • 552 Answers
Attached is a link to a Asko Dishwasher repair video.
http://www.appliancerepairlesson.com/shop/dishwasher-videos/asko-dishwasher-f2-error/
Posted on Feb 26, 2011
  • rrrryyyyyy Apr 08, 2011
    Ya, right. Thanks for the link, it costs $2.95! And where's the guarantee it'll help?!
I have the same problem (F2) with my 1776. they said it was a overfill sensor. I pulled to first kick plate off but can't get to the 2nd. any suggestions on how to do this? thanks!
Posted on Jul 29, 2008
I have had this problem twice. It was caused by a piece of food getting stuck in the removable drain and preventing the dishwasher from draining properly resulting in a pool of water in the dishwasher. First, remove the removable drain and clean it out. This time I ran the dishwasher to drain the pool of water. After draining the water it continued to run and had the flashing F2 error message. After turning off the power to the dishwasher I used towels to try to remove as much water as possible from the foam behind the lower panel. Then I left the power off and waited 36 hours. During that time I turned the power back on a couple of times, but the motor churned and it had the flashing F2 error message. After the 36 hours it had apparently dried out sufficiently and worked fine.
Posted on Feb 15, 2009
This was very helpful! Only 2 weeks ago I replace the circulation pump on my Asko 1855. Today, when I turned the power on, the F2 error message appeared. I removed the face plates and discovered there was a lot of water in the drip pan. I found the cause to be a small leakage on one of the hose connections. After removing all the water, the water level switch worked properly.
Posted on Aug 17, 2008
Thanks for info it solved the problem.
I have a Asko D3132, our kitchen drain blocked and subsuquently the washer couldn't empty and unbeknowns put water into the underneath tray. The F2 error displayed and washer kept trying to empty even when I switched the machine off. Took off backplate where the water would have engaged the float causing the problem.
All you need to do is tilt the washer and water will flow out without removing back plate.
Now going well.
Posted on Jun 03, 2010
  • jimbruce_dk Sep 16, 2011
    This worked for me... Just pull the dishwasher out and tilt it so the water in the pan runs out (remember towels!! to dry the water with)... Don't mess with the backplate or anything... my dishwasher (Asko Vølund D3130) works great again!
F2 is caused by water collecting in the sump under the diswasher which triggers a polystrene float to raise to contact a relay. To fix pull the dishwasher out and remove the back plate. However this may require a special screw driver bit - for my Model Asko D3132 I had to use a Torx T15 bit which I had becasue I had a laptop tool kit which came with this. Once the water is removed you can wiggle the polystrene float and hear it release the relay. (optional as the removal of water will aollow float to drop slightly back to its position. Good luck
Posted on Jul 13, 2010
Water accumuates in the drip pan and causes the F2 errors. Remove the kick plate and the plate behind. There was quite a bit of water to be removed. We uses seeral Sham-Wows, then finished wi a blow dryer. The dishwasher work perfectly once the drip pan was free of water.
Posted on Feb 20, 2011
Thanks for all for ther tips.
I have Aske DM 44, same F2 error in display and motor is running contantly. In this model you have to remove the backplate (where the in/out water tubes + power cable are) in oder to see the motor area and bottom plate(sump) for collecting water. In my case lots of water (1-1.5 Liter i guess) accumilated in the sump. So i removed water and dried the area for moisture. Powered up and no more F2 error and machine is back to normal.
The mistary is how so much water got collected in sump in the first palce.
Posted on May 23, 2010
    New Friend:
I had an f2 error code. Took the two lower front kick panels to expose the lower sump tray. This was filled with water and the sump water level switch was tripped, causing the f2 error code. I sucked the water out with a shop vac and the appliance resumed normal operation. NOTE: my particular problem was caused by a garbage disposal that was installed that did not have the dishwasher connection plug knocked out. ( a rookie mistake)
Posted on Mar 26, 2016
Could be that water has leaked under the unit and caused the unit to cut out. Pull the unit out and check for water in the pan. Then identify the source of leak
Posted on Sep 29, 2007
    New Friend:
It seems that the valve that supplies water to dishwasher can fail and allow water to enter the dishwasher even when its not on and of course overfills causing the F2 error. Replacing the valve isn't easy and too expensive. Solution: replace the dishwasher
Posted on Feb 11, 2014
  • Andrew G
    Andrew G Feb 11, 2014
Asko advisory center
Try these... -Clean out the drain pump inside and below.
- Pull the suction boot off the drain pump, clean out any gookus.
- Blow through the drain hose starting from the connection at the pump.
make sure it is not clogged follow the line from under the sink and disonnect it from under the sink and make sure it is clear
- If all else checks out, replace the pump.
The Duet hides the pump/filter access behind the lower panel. Most LG, Miele and ASKO washers have it right up front for easy access. I guess keeping such a base element out of view helps sales.
Long Drain error code.
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
Press, PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the "F2 error code" will be displayed.
Potential Causes:(1) Check the drain hose and make sure it is not plugged or kinked.
(2) Check the electrical connections at the pump and make sure the pump is running.
(3) Check the drain pump filter for foreign objects.
If the above does not correct the problem replace the pump
Mar 07, 2018 | Asko D1776 Stainless Steel Built-in...
Dishwasher runs part way thru cycle then f2 cumes up all lights come on and draim pumps runs all the time even with door open
F2 signifies high water level. Check the drain pump and drain hose, make sure they are not clogged. Check the operation of the water inlet valve.
Feb 23, 2011 | Asko D1776 Built-in Dishwasher
F2 flash and I have drain the bottom twice and still f2
Hi- Check to see if your Air Gap at the sink is clogged, this will absolutely cause drain issues and is easier to remedy than the pump. Best regards.
Sep 24, 2010 | Asko D1776 Built-in Dishwasher
Won't drain and unit will not shut off
water will not go into my dishwasher any solutions
Nov 16, 2009 | Asko D1776 Stainless Steel Built-in...
Asko D1996 lights flashing washer won't start
I'm having the same issues. What did you do to solve yours? My start button never lights up! Thanks for your help!
Oct 01, 2009 | Asko D1776 Stainless Steel Built-in...
ASKO Dishwasher F2 light flashing
Hold the Rinse button for 5 seconds to reset.
Jan 19, 2009 | Asko D1776 Built-in Dishwasher
ASKO dishwasher
F2 fault water in the base remove dishwasher from under the bench and tip back water will run out,then it will restart.remove rear lower panel and run the dishwasher you may find a leak,also check that the inlet valve is shutting off and not filling the dishwasher up overnight.hope this helps.
Mar 27, 2008 | Asko D1776 Stainless Steel Built-in...
F2 Error Message on my Asko D1776
F2 error message means that you have a high water level problem that could be caused: - A plugged or bed water pump - A defective water inlet valve (stay open) Good luck !
May 21, 2007 | Asko D1776 Stainless Steel Built-in...
Asko D1776 Built-in Dishwasher Logo
28,148 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Jose Pino
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
