Question about Compaq Presario 5000 PC Desktop
Error GDI.exe gray box appears stating error GDI.exe has occured n this session will close . If problem repeats itself try restarting your pc
  • 37 Answers
If your using win98 you might have a font problem... you could reinstall your windows to solve this problem or try reinstalling the fonts in DOS mode using your win98 installer 1.reboot your pc make sure to boot from your win98 cd installer or by using a startup disk 2.on comand promt type the following: md c:\windows\fonts attrib +s c:\windows\fonts cd\windows\options\install extract /a win_17.cab *.fon /l c:\windows\fonts extract /a win_19.cab *.ttf /l c:\windows\fonts or if you are using win xp you might have a corrupted driver 1.update your garphic card driver... hope this helps... ^_^
Posted on Sep 29, 2007
    President:
  • 2,961 Answers
You will need to reinstall windows i'm afraid, see the link below for instructions http://support.microsoft.com/kb/146904
Status 0x00000e9
Many of the problems caused by programs lead to the emergence of the messages that come in shape
A fatal exception XX has occurred at XX.
Often occur, because the program on the problem of improper code required Processor Processor you make improper operation. Thus Windows displays this message to tell you so and ask you to tell him what it must do. In fact, these kinds of errors do not escape them and often lead to the closure of the program or you may have to restart the Windows operating system as a whole and therefore you will lose any unsaved data before, and you models for these errors.
He noted that in all the solutions that Snordha here we'll use the letter A to represent the floppy drive and the letter C to represent the hard drive that contains the Windows system device and the letter D to represent the CD-ROM drive, and that all the messages and solutions applicable to Windows XP and Windows Me unless stated one only.
Message:
A fatal exception 00 has occurred at XX
Meaning:
This error occurred because the processor tried dividing the number to zero which is the correct thing is sporty and therefore this letter appeared.
Solution:
Close the message and try to continue to use the program, if you can not close the program and then restart it again, or restart your computer if necessary College.
Message:
A fatal exception 0C has occurred at XX
Meaning:
This error occurred because one of the instructions stored within a certain part of memory called the stack (which parts of memory are reserved for programs to deal with the equipment and devices) tried to use portions of memory outside the specified part
Solution:
Try closing the program and restart your computer.
Message:
A fatal exception 0E has occurred at XX
Meaning:
This error occurred trying to access the data processor located on the Page page of memory RAM or virtual memory Virtual Memory, but discovered the absence of the page, or that the data has been improperly accessed.
Solution:
Close the message and try to continue to use the program, if the program can not switch off and then turn it on again, or restart your computer if necessary College.
Message:
A fatal exception 13 has occurred at XX
Or General Protection Fault
Meaning:
Fault of the same quality as previous mistakes, but did not specify why.
Solution:
Close the message and try to continue to use the program, If you can not do close the program and then restart it again, or restart your computer if necessary College.
All previous mistakes are supposed to occur at intervals spaced opposed, if repeated occurrence tried to determine when those errors occur, if they occur while the program is running, you may be able to solve the problem, remove and then reinstall the software again, or get a version upgrade him.
If you can not link between the error message and a program may be the reason why a file from the Windows system files or one of the device drivers Device Drivers, and test it restart your computer in the security mode Safe Mode, if you do not see the message usually be the cause of one of the players devices Thus you can access the latest version of the drivers in your device through the companies that produce them site on the web, and if the message persists often will be a problem in the Windows system itself, and therefore you will need to re-set the Windows system again.
Message:
System busy and appear on a blue screen
Meaning:
This message appears with the nature of the error usually as stated in previous communications with the program said that the cause of the problem is the system may be Windows itself, and ask you to wait until the system becomes less busier.
Solution:
Restart your computer, and if the error is repeated several times do to deal with him as we have seen in previous communications solutions.
Jun 20, 2013 | Computers & Internet
Tip
Desktop Short Cut Missing
Hello,Some times your Desktop shortcuts or Start Menu Disappeared.It is happening due to Error Occurred in Explorer.exe. You can Clear this Error without Formatting.Just Do Following..
  1. Copy "explorer.exe" from other clean computer (from C:WINDOWS)
  2. And Paste it In your computer go to C:WINDOWS
  3. Show hidden files from (Tools - Folder Options - View - Show hidden files and folders)
  4. Delete existing 'explorer.exe' and any other files start with explorer...
  5. Put the new file (explorer.exe)
  6. Log off / Restart
  7. Log on
OR Just try this Solution.Close all your Opened Windows/Programs(OR Restart PC). Just Run this Dos File.It will Restore your Desktop Surely.. I/we need your valuable Feedback...Keep Using FixYa
Check this Link............. "Unable to Open Theme Corrupted" in Nokia 6300 Click here
on Apr 11, 2010 | Computers & Internet
Hello, i have an acer TravelMate 270. My laptop cannot boot correctly. When ever it gets to the logging on fase to put in a password you see the windows is starting up for a split second and then it turns...
Well u can try to format the drive and load a fresh copy of the operating system. When its using short term memory to dump its boot errors then its never a good sign. Viruses cause this most often but a bad sector on the hard drive itself will also do this. If after you format the drive and still it does this then its time for a new hard drive.
Aug 13, 2010 | Acer TravelMate 270XV Notebook
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
The taskbar disppears. I have it locked so that it should always be on top of everything else but when it goes into hibernation and it restarted it disappears.
I'm had the same problem with my system. if the 'Start' button is still visible, so you can right-click that, select 'Properties' and change the TaskBar settings.select the 'Autohide the Taskbar' and applying that change will result in the Taskbar appearing again (at least when the mouse pointer is positioned by the Taskbar).
if the above one does not work a simple solution that will work:
1. Hit CTRL+ESC to show the Start menu.
2. Right click the menu at the bottom for Properties.
3. Select the Taskbar tab.
4. Check Autohide Taskbar and click the apply button.
5. Uncheck Autohide Taskbar and click the apply button once more.
Your taskbar should reappear when you've completed these 5 steps.
Please give this a try before messing with registry or recovering your machine!
If the taskbar does not show up when you press CTRL+ESC then explorer.exe may not be running. To correct this press CTRL+SHIFT+ESC which will bring up the task manager. Click File, New. Find explorer.exe and open it.
Go into Task Manager. Find explorer.exe and end the process. Restart explorer.exe. If your taskbar magically reappears, you've found the issue. Here are some other symptoms:
After a Windows Vista-based computer has been running for an extended period of time, the desktop screen may stop updating correctly. For example, you may experience any of the following symptoms: • Parts of the screen may go black. • Parts of the screen may become transparent. • The toolbar may disappear. • The toolbar may appear at the top of the screen instead of at the bottom of the screen.
If you add the GDI Objects column for the Explorer.exe process in the Task Manager console, you see that the GDI Objects column has reached the maximal number that is defined in the GDIProcessHandleQuota registry entry.
A hotfix is available from Microsoft: http://support.microsoft.com/kb/932406
Jan 07, 2010 | ASUS Eee Box EBXB202-WHT-E0002 Intel Atom...
SETUP2EXE preventsCD rom running
well it is virus activity
i faced a much problem by this thing
whenever i try to install or update my antivirus
it generate errors and shut down the computer
i know it is very irritating
but you have to format your computer completely
and try to install new operating system
and install the good antivirus.
Dec 12, 2008 | Computers & Internet
Problem when windows XP is starting up. Isass.exe - System Error
To work around this issue, restart your computer in Safe Mode. To restart your computer in Safe Mode, press F8 when the computer starts. Then, when the computer is in Safe Mode, add the System Pages entry to the following registry subkey: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Session Manager\Memory ManagementTo add this registry entry, follow these steps: 1. Log on by using an account that has administrative credentials. 2. Click Start, click Run, type regedit, and then click OK. 3. In Registry Editor, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management 4. On the Edit menu, point to New, and then click DWORD value. 5. Type SystemPages, and then press ENTER. 6. On the Edit menu, click Modify. 7. Click Decimal, type 31000, and then click OK. 8. Quit Registry Editor.
Jun 17, 2008 | Dell OptiPlex GX280 PC Desktop
Legacy
Please try the following:
Click Start >> Run >>
Type the follow command in the Open box.
"net.exe stop wuauserv" (w/o quotes)
Press Ok
Repeat the same for the following commands:
regsvr32.exe wuapi.dll
regsvr32.exe wups.dll
regsvr32.exe wuaueng.dll
regsvr32.exe wucltui.dll
regsvr32.exe MSXML3.dll
regsvr32.exe qmgr.dll
regsvr32.exe qmgrprxy.dll
net.exe start wuauserv
Restart the machine and try again.
May 01, 2008 | Computers & Internet
Compaq Presario 5000 PC Desktop Logo
56 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
