Went to heat some leftovers, unit runs about 23 seconds then stops, does not beep when it stops. Does not heat at all. Unplugged for 2 minutes, reset clock, tried to heat again, shuts off 23 seconds. No beep when it shuts off. It will keep the correct time. It will not go into child lock mode.
Most likely cause, worth fixing or not?
Comments:
Sep 29, 2007
- Since I am in no way a repairman for microwaves, ballpark figure on the cost of taking this to a service center for repair?
-   I have the same problem too. Runs for approx 30 seconds and then just stops and produces no heat.
I'm thinking about replacing it with a toaster oven.-   Guest
Feb 10, 2008
-   Mine does the same thing. Is it worth pulling apart to fix? What price might parts be? (I have had a quick look inside but there was nothing obviously blown/damaged.)
Thanks
Simon.-   ManADE
Nov 16, 2007
-   it is the magnetron. to fix mine, it cost about $55 for labor plus $5 for shipping for a total of $60. the part was still covered under the 5yr warranty.-   Guest
because of high voltage circuit thats happend ,please check highvoltage circuit may be short circuit or any companent burntout. check magnetron and high voltage diodes etc.
Does anyone have experience with a Bravetti Professional Convection & Microwave Oven ...
(More)
Does anyone have experience with a Bravetti Professional Convection & Microwave Oven Model: K5345. We are thinking of getting one for our RV.
Is there a microwave with these measurements to fit above my range 36" width x 12" deep x...
(More)
Is there a microwave with these measurements to fit above my range 36" width x 12" deep x 11" height?
when you select the warming time you press start, the light inside comes on but it does not turn or...
(More)
when you select the warming time you press start, the light inside comes on but it does not turn or warming the food.
