Question about Uniden BC246T Handheld Scanner
Question about setting up a scan
I'm confused. I just received my unit. Ok, when you hit "MENU" then "SEARCH FOR.." then "SERVICE SEARCH" then for instance, "CB RADIO" a frequency shows up along with "channel 1". When I turn the scroll button it changes to different channels manually. How do I get it to scan those cb channels automatically? If I hit the "scan" button it just reverts to other stuff and doesn't scan. Thanks.
When you get to CB or whatever bank you want to search you must press the E/YES and then it should search. Also check your squelch. Hope this helps you out.
Posted on Oct 08, 2007
SOURCE:
I just bought a 32bv701b. When doing auto scan no digital channels appear. My previous TV received them all fine. Help!
Do a retune to this TV.
Press MENU button on the remote control and select
Install and Retune by using Left or Right button.
Press OK button and the following menu screen
will be displayed
Select Automatic Channel Scan (Retune) by using
Up or Down button and press OK button. Automatic
Channel Scan options will be displayed. You can select
options by using Up or Down and OK buttons.
Auto Channel Scan Menu Operation
Digital: Searches and stores aerial DVB stations.
Analogue: Searches and stores analogue stations.
Full: Searches and stores both analogue and aerial
DVB stations.
Whenever you select an automatic search type and
press OK button, a confi rmation screen will appear
on the screen. To start installation process, select
Yes, to cancel select No by using Left or Right
and OK button.
After auto channel scan type is set and selected
and confi rmed, installation process will start and
progress bar will move along. Press MENU button
to cancel process. In such a case, located channels
are not stored. The television will start to search for
all available stations. You must allow the television
to complete the search.
Jun 13, 2012 | Panasonic Televison & Video
Code ck sr tuner no sound
Hello
So many improper commands send to the unit may make its system and memmory to be confused, and will not operate properly. Just reset the unit to factory settings, and try.
To reset the unit to factory default settings, so the following
[1] Press STANDBY/ON on the front panel to set this unit to standby mode.
[2] Press and hold TONE CONTROL and then press STANDBY/ON to turn on this unit. The advanced setup menu appears, in the front panel display.
[3] Press PROGRAM buttons to select PRESET.
[4] Press STRAIGHT repeatedly to select RESET.
[5] Press STANDBY/ON to confirm your selection and set this unit to the standby mode.
This procedure completely resets all parameters of this unit including SET MENU parameters. However the advanced setup menu parameters will not be effected. The intial factory paramenters will be activated next time when you turn on this unit. To cancel initilization procedure at any time without making any changes, press STRAIGHT repetedely ot select CANCEL and then press STANDBY/ON.OK.
Apr 03, 2011 | Yamaha RX-V463 Receiver
My Canon Pixma MP130 tells me my Waste Ink Absorber is nearly full. Manual tells me not to touch but how do I replace or empty?
This is a safety function that Canon ans Epson built into theyr machines. Normaly this problem can be solved by replacing the absorber pads (or cleaning them) however you will need a service mode tool to reset the ink count in the eprom. Search google for the specific tool for your printer.
Good Luck
Dec 09, 2010 | Office Equipment & Supplies
My printer is displaying waste ink tank near full press ok key. When I then press the ok key it does not respond. How do I reset it. Many Thanks
Do the following
)Printer on, press Additional Functions, Scan, Copy, Scan
Now you should be in service mode from there for waste ink tank reset it is simalar to what has already been posted
2)Select Test mode which is like the last avalabe selection
3)Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other option this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button
The menu will now say EEPRON Clear
Select Ink count which is option (0) and press set
Then press Stop/Reset Followed by the power button and then wait for it to restart.
May 01, 2010 | Canon MultiPASS MP360 All-In-One InkJet...
What do I do when it says that ....The Waste Ink absorber is almost full?
1)Enter SERVICE MODE by pressing MENU-SCAN-COPY-SCAN
2)Enter NVRAM by pressing < or> then OK
3)Set ABS-M to 0
4)OK
Feb 12, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Waste Ink Absorber is almost full
You don't have to change the waste ink absorber. There are two in the MP130 and they cost about $15 each. I have found though that you can just reset the counter and let the printer run without any problems. I have done this with three now with no problems. Reset procedure is:
1. Start Printer
2. Press button MENU, then SCAN, COPY and again SCAN – the printer will go into the service menu.
3. select NVRAM ACCESS and further BY OK.
4. select SET Abs- m level and reduce to zero.
5. select SET Abs- r level (if there is) and reduce to zero.
6. Turn off printer by button POWER.
Jan 05, 2010 | Canon PIXMA MP130 All-In-One InkJet...
PRINTER PixmaMP 130
HI
You can try.
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
  1. You will include printer.
  2. press button MENU, then SCAN, COPY and again SCAN - they entered into the service regime.
  4. select SET Abs- m level and advance value equal to zero.
  5. select SET Abs- r level (if there is) and also you will establish into zero.
  6. you will turn off printer by button POWER.
All best
Dec 30, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink absorber nearly full. Canon pixma mp130/110. How do I empty it?
Canon MP110, MP130
1. Include the printer.
2. Press the button "Menu" , then "Scan" , "Copy" and once again "Scan" (all - fell into service mode).
3. The Arrow to choose "Counter access" , press "OK" .
4. The Arrow to choose "ABC-M DOT Count" (or "ABC-P DOT Count" - depends on that, evidences what from counter = 100 ) and press "Copy" .
5. The Button "-" throw the counter before "0" , and press "OK" .
6. For leaving from service mode to press "Resume" .Good luck! Cheat that you dispose of problems!
Sep 28, 2009 | Canon PIXMA MP130 All-In-One InkJet...
On-screen menu works but channel search yields no channels.
if you can access tv menu go to settings that show source(antenna/cable)highlight cable setting and hit search/program ;tv should go through all the channels and scan them into memory. it just might be that it is still under antenna setting .try solution ,it might be what's wrong.
Apr 02, 2009 | Televison & Video
The ink wate absorber is full
You may find the instructions here if you search through the forum.
http://www.fixyourownprinter.com/forums/inkjet
there is usually someone who has had the same problem.
Cheers
May 09, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Uniden BC246T Handheld Scanner Logo
Top Uniden Radio Communications Experts
Jason
Robert McClure
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
