Question about InFocus X1 Multimedia Projector
Infocus x1 image issue
I'm projecting a powerpoint presentation using the x1 and the entire image is not projecting onto the screen. the top and right hand side of the slide is cut off. how do i center it or make it so the entire slide is projected on the screen? thanks alex
  • 2,239 Answers
The light tunnel has collapsed and needs replacement. it's only about $10 and fairly easy to replace.
Posted on Aug 03, 2009
SOURCE:
My dell d630 laptop wont recognize my infocus lp70+ remote control and I can't advance my powerpoint slides with the remote control
Here's what the User's Manual says:
Using the Remote Control
To advance PowerPoint slides with the projector's remote, you
must connect the USB cable on the projector's computer cable to
the computer. See page 8 for more information.
Point the remote control at the projection screen or at the front or
rear of the projector (not at the computer). The range for optimum
operation is about 30 feet. If you point the remote at the
projection screen, the distance to the screen and back to the projector
must be less than or equal to 30 feet. For best results, point
the remote directly at the projector.
If you are displaying presentations in Microsoft® PowerPoint®,
you can use the remote's Previous and Next buttons to navigate
through your presentation while in Slide Show mode.
Jan 26, 2011 | InFocus LP70+ Multimedia Projector
The bulb works but I can't get an image
is the projecting image black or what??
what is being projected actually??
have you checked the lens section?
Aug 11, 2008 | Apple InFocus X1 Multimedia Projector
Infocus projected image is distorted
check the screen resolution settings in visa it maybe different than the desktop settings.infocus can execpt many resolutions but not all. try 1280x1024
Jan 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
My dell d630 won't recognize the infocus lp70+ remote control and I can't advance my power point slides?
Dark spot issue.
Its an acrylic condensing lens inside the light engine that has melted/warped. You have to pullout the entire light engine then disassemble the optical light tunnel to get too the lens. Then you need a lens-smith to cut a new lens because Infocus won't stand behind this design flaw. Its really a shame on Infocus!
If you need more info contact us here: click here
Sep 19, 2009 | InFocus ScreenPlay 61" Rear Projection...
Black and white specks from InFocus X1 projector
if you can get a menu when you press the menu button, reset the settings to factory default. if you don't get a menu, the color wheel or the dmd chip is bad. either way, you'll have to replace the entire optical engine. and unfortunately, infocus no longer has any more in stock.
Sep 06, 2009 | InFocus X1 Multimedia Projector
Infocus x1 noise problem
the colorwheel motor does burn out after a while (from heat and dust), but as long as it spins at the right speed, you won't see a problem in the image. if it's making noise, it's going to go soon. it does need replacing. however, infocus does not sell individual parts for the x1 optical engine. you will need to replace the entire engine, which costs up to $2000. so, enjoy the last few hours with your machine and look into getting another.
Mar 16, 2009 | InFocus X1 Multimedia Projector
What button do I push on my toshiba to connect to InFocus proje
on the projector, computer. on the computer, it depends on the computer. also, make sure the computer resolution matches what the projector can handle (max 1024x768)
Mar 12, 2009 | InFocus X1 Multimedia Projector
InFocus X1 Multimedia Projector Logo
243 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
martin hogg
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
