Question about ASUS P5S800-VM Motherboard
Installing multi functionfront mounted panel
Connections required for 6CH audio interface 2)Are there any connections internally to plug in IEEE1394 port supplied with front mounted panel
  • 196 Answers
The manual is here: I don't see an internal Firewire connector, but you can buy a card for one.
Posted on Sep 29, 2007
How easy is it to change a heater core in a2003 Kia sedona
It is in no way easy. But if you want to try, here are the instructions....
3.5L Engine
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Drain the cooling system.
  3. Disconnect the negative battery cable.
  4. Remove the heater hoses.
  5. Remove the driver air bag module.
  6. Remove the steering wheel.
  7. Remove the turn signal assembly.
  8. Remove the upper and lower steering column covers.
  9. Remove the A-pillar upper trim.
  10. Remove the instrument cluster trim.
  11. Remove the instrument cluster.
  12. Remove the A-pillar lower trim.
  13. Remove the hood release handle.
  14. Remove the left lower trim panel.
  15. Remove the multi box.
  16. Remove the audio panel.
  17. Remove the ventilation control panel.
  18. Remove the radio.
  19. Remove the glove box.
  20. Remove the center console.
  21. Remove the audio system speakers and mounting bolts from the top of the instrument panel.
  22. Remove the side covers.
  23. Remove the T-bar mounting bolts.
  24. Remove the bottom mounting bolts.
  25. Remove the instrument panel wiring harness connectors.
  26. Remove the instrument panel.
  27. Remove the heater unit.
26096060-nraukxomtaildozoxjjbr22p-1-0.gif 26096060-nraukxomtaildozoxjjbr22p-1-1.gif
To install:
  1. Install the heater unit.
  2. Install the instrument panel.
  3. Connect the instrument panel wiring harness connectors.
  4. Install the bottom mounting bolts.
  5. Install the T-bar mounting bolts.
  6. Install the side covers.
  7. Install the upper mounting bolts and audio system speakers.
  8. Install the center console.
  9. Install the glove box.
  10. Install the radio.
  11. Install the ventilation control panel.
  12. Install the audio panel.
  13. Install the multi box.
  14. Install the left lower trim panel.
  15. Install the hood release handle.
  16. Install the A-pillar lower trim.
  17. Install the instrument cluster.
  18. Install the instrument cluster trim.
  19. Install the A-pillar upper trim.
  20. Install the upper and lower steering column covers.
  21. Install the turn signal assembly.
  22. Install the steering wheel.
  23. Install the driver air bag module.
  24. Install the heater hoses.
  25. Connect the negative battery cable.
  26. Fill the cooling system.
  27. Start the engine and check for leaks and proper heater operation.
Feb 15, 2016 | Kia Cars & Trucks
Vw golf VII radio wiring diagram
Hi. There should be a multi plug diagram on a sticker on the radio itself.
Jul 13, 2014 | 2014 Volkswagen GTI
What is the best way to run the mic on desktop
Your condensor mic requires special electrical handling usually reserved for proffesional audio equipment, not a PC. You will need two pieces of equipment, a short XLR cable and an adapter cable.
1) Behringer PS400 Ultra-Compact Phantom Power Supply.
This will supply the mic with necessary Phantom Power.
2) Rapco Horizon ISOBLOX Transformer Isolation 1:1 BLOX Device
This will isolate the Phantom Power from your computer, allowing it to work as necessary.
The adaptor connector cable you need will be a female XLR (with pins 1 and 3 shorted, pin 2 hot), through a cable connect to a 1/8" mini plug. They connect in that order with a short XLR cable between 1) and 2). .
Aug 23, 2012 | CAD Microphones GXL2200 Professional...
I have connected the audio from 3 devices into the 3 optical inputs on my Denon AVR-3300. Audio for each device plays perfectly through main speakers but not through the multi-room output (which goes to...
the unit is ok. User manual on page 42 says that the digital sources can not be output trough multisource output.
Try to use VCR-1 VCR-2 audio output jacks instead.
Sep 24, 2011 | Denon AVR-3300 Receiver
I have just bought an m-audio fast track guitar interface, i have tried it on both of my windows xp pc but i get no sound can you give me step by step instructions as i am missing something
Good Day,
First, check connection of all peripherals and the PL / XLR plugs that you maybe using. If all seems to be connected, you may try to re-install the software by following these steps:
If you are running on windows XP:
first Unplug the Usb connection with the PC to the M-audio interface. place the CD that came with the interface, and start the installation utility, and install. Just click Next, and it will continue. If you see a message stating that driver has not passed Windows Logo Testing just click continue anyway. This may appear several times. After installation, Reboot. After rebooting, plug in the M-audio interface, a window will pop-up and just select "Install automatically" then next, and now let it finish copying the rest of the needed files. Be sure though, to still have the CD in your drive. After that you may start the program as usual, you may also check the control panel if the settings for the audio interface suits you needs. Go to Control panel, Open "Sounds and Devices" and under Playback and Record, select Fast Track USB. Then click apply.
Hope this helps. Thank you for using Fixya.
Jul 10, 2011 | Computers & Internet
Old 6Ch Audio output speaker sys. Cant connect it to my new lcd
I don't understand. Standard RCA cables are Male at both ends, in/outputs on standard devices are always Female. What's the problemo? One pair is all that is needed.
Nov 08, 2009 | Kenwood VR-705 Receiver
I lost my driver of sound card how can i install it again my soun card model is CMI8738-6CH
Make sure your audio drivers are uninstall (if you can but, not required), and install Driver Max software. Do a google search and install the driver max software. This software automatically detects all the hardware components in your computer2.gif and help you install the relevant drivers This works real good for emachines.
Oct 10, 2009 | E-Machines eMachines Refurbished EMA...
Sound card problem Dell
download from this link
select sound card driver
select creative
select your model name and model no
Jun 29, 2009 | Creative Labs Sound Blaster Live! 5.1...
My computer restarts before installation completes
Jan 27, 2009 | Abit AX8 NVIDIA VIA K8T890 + 8237 Chipset...
Hi raul27
You can download the entire manual for the mobo here
Thanks for using fixya, any dramas working it out, please get back to me here
May 05, 2008 | VIA P4MA Motherboard
ASUS P5S800-VM Motherboard Logo
127 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
