Question about Humax DRT400 TiVo 40-Hours Video Recorder
Replace Hard Drive Humax DRT 400
How do I do I replace the hard drive? I'm far from a techy!! What product should I use to replace? How do I retain my lifetime subscription after hard drive replacement? Thx!!!!!
  • Anonymous Apr 13, 2009
    i have lost my remote control
    Genius:
  • 1,139 Answers
Here is a link that will help you: http://tech.yahoo.com/gd/adding-a-new-hard-drive-to-your-tivo/2625
Posted on Oct 01, 2007
SOURCE:
The hard drive on my humax HDR1000S keeps losing recordings. Later they come back. Please help
Sadly this fault is common on this model.
See: https://myhumax.org/forum/topic/hard-drive-issues
Your best option is probably an exchange box from Humax, but you will lose your recordings.
Aug 30, 2017 | Humax Televison & Video
Humax pvr 1950T stuck in standby, can't get into menu
did you reinstall operating soft ware when you replaced hard drive?
Aug 19, 2014 | Computers & Internet
Replace hard drive motherboard
Before you start replacing drive you need to ask yourself if you are trying to replace a bad hard drive and just want to start with a clean install of the O.S. OR are you replacing your hard drive with a bigger one and wish to keep your installed programs, data and documents. If you want to keep your data and documents you need to know how to save the Files and folders on your computer to a CD, DVD or a USB hard drive. Just replacing the hardware involves unplugging all cables from computer after shutting it down. Then opening the case and unplugging the cables from the hard drive and then remove the screw(s) retaining the hard drive. Remove the old hard drive from the case and replace it with the new one, replace screws and plug cables back up watching that that the connectors are correctly aligned with the key(s) on the hard drive's sockets. Replacing the Hard drive also involves installing the O.S. and all your programs and applications on the new hard drive. You can find a lot of information in the internet about this.
Oct 21, 2013 | Gateway SX2855 Case
Permanent deleting on humax box
Hard drive fault. replace the hard drive and it should be fine
Sep 01, 2013 | Televison & Video
How do I replace the internal hard drive
well before that why not run a disk optimizer and see if that helps
click here for a neat utility
Jun 17, 2012 | Fantom Drives MicroNet Platinum 160 GB...
I cant format my laptop . when i run xp cd after
Sorry, it sounds like your hard drive failed. It is either that, or your XP install CD has an error. If it is the hard drive, it is easy to replace. Take it to your local PC techie and he/she will put a new hard drive in for a lot less than a new PC. Check out eBay as the cheapest place to buy a replacement hard drive; there are two types of hard drives for laptops - SATA and IDE. Got to buy the "right" one.
Oct 26, 2010 | Microsoft Windows XP Professional
Need to find a Hitachi Serial ATA 400 in stock
Odds of finding that drive new are slim to none but you can use ANY hard drive of at least same capacity to replace it. In fact as a data recovery specialist I always recommend my customers use several different brand/model drives in their arrays and simply elect to use the smallest one as the size for RAID on the others as this greatly minimizes the chance you will ever have multiple mechanical failures in a short timeframe.
Feel free to replace it with anything 400 or bigger and your raid should be able to assign an appropriate sized partition to the drive while it rebuilds itself.
Hope this helps FixYa,
Chris
Apr 19, 2009 | Hitachi ( 0A30229-20pk) 400 GB Hard Drive
Hard drive
These instructions should help.
Toshiba® Satellite 100, 105, 110, 115, 200, 205, 210, 400, 405, 410, 420, 430 Series
Hard Drive Installation Instructions
  1. Turn notebook upside-down.
  2. Remove the battery compartment cover.
  3. Remove the battery pack.
  4. Remove the 2 Phillips screws that mount the hard drive down.
  5. Slide the hard drive away from its connector and gently lift it out of the notebook.
  6. Remove the tray from the old hard drive and assemble it onto the new hard drive.
  7. Slide the new hard drive into its connector inside the notebook.
  8. Replace the 2 Phillips screws used to mount the hard drive into place.
  9. Replace the battery pack.
  10. Replace the battery compartment cover.
Jul 28, 2008 | Toshiba Satellite A100-S8111TD Notebook
UltraMax 650GB
I would remove the drive from the case and plug it in to my computer directly. Image it, and replace it. All data will be retained.
Aug 17, 2007 | Iomega ULTRAMAX 1TB TRIPLE INTERFACE...
Humax DRT400 TiVo 40-Hours Video Recorder Logo
721 people viewed this question
Top Humax Televison & Video Experts
 Grubhead
Grubhead
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
