Question about Ecoquest Fresh Air Air Purifier
Ecoquest air purifier uv lamp replacement
I recently replaced the uv lamp in my ecoquest air purifier, but when I turned the unit back on the lamp doesn't work! I have gone through all of the steps three times with the same result. The lamp appears to be intact. so, my question is, what else could be effecting the uv lamp operation? I think it may be a short somewhere, but don't know where to look. Any suggestions?
  • Anonymous Dec 15, 2007
    I just replaced the lamp and starter but I still get the replace lamp message. What else is there to do to this thing to make it work. [email protected]
  • jagjag Dec 15, 2007
    I just replaced the lamp and starter but I still get the replace lamp message. What else is there to do to this to get it work.
    Problem Solver:
  • 7 Answers
Check starter ballast little push in and turn like in the old style lights.
Can be found on ebay relatively cheap. Also contacts on either side of the ceramic plate corrode and they lose contact. At that time it will inform you on the front to change the plate. It is the corrosion. You can remove the contacts and clean them purchase some red battery terminal spray and spray them lightly after reinstall. Reinstall the same plate. You are welcome. MIke Wilhite
Posted on Jul 27, 2012
If you haven't done so, try replacing the lamp starter.
Posted on Oct 08, 2007
Changed my purification plate and when I started the unit back up it just would start the fan and then shut down in about 7 seconds. It will restart the same process, but will not stay running. The fuse looks good, and it is making the filter switch can anyone suggest the next idea
Posted on Dec 22, 2007
SOURCE:
Where can I find wiring diagram for Ecoquest air purifier. Replaced UV lamp and disconnected wires and cannot remember how to place them.
Try checking the contacts to the ozone plate. Or a wire may be loose--check the contacts and sometimes they need to be cleaned with alcohol.
Apr 19, 2012 | Ecoquest Fresh Air Air Purifier
Fresh Air Maachine by Ecoquest
I've read from some other posts on here that Ecoquest is good about returning the items and replacing them.
Jul 12, 2008 | Ecoquest Fresh Air Air Purifier
How to replace your uv light in your fresh air ecoquest air purifier?
1. Unplug the purifier
2. Remove the two screws on the back cover and remove the cover.
3. Remove the two screws on the the top that hold the lint screen and remove the screen.
4. Remove the purification plate by sliding it out.
5. Remove the RCI target plate by sliding it out.
6. Disconnect the purification plate contact lead wires from the purifier plate cage.
7. Remove the two screws at the bottom of the plate cage.
8. Slide the cage forward, lift and remove the cage.
9. Rotate the uv bulb a quarter of a turn and lift it out of the unit.
10. Install the new uv bulb and rotate it a quarter of a turn to lock it.
Perform steps 1-9 in reverse order to reassemble the purifier.
Dec 06, 2010 | Ecoquest Fresh Air Air Purifier
Hi i have a Ecoquest Breeze AT Living Air
that ligth its uv lamp you can replace it your self get parts from ecoquest for the rigth model
Apr 02, 2010 | Ecoquest Breeze AT Living Air Purifier
The blue light of my EcoQuest Fresh Air Purifier flashes
The UV light is a Flourescent like bulb. It has a starter. The starter and bulb can be bought on Ebay for about $20. It is easy to replace.
Mar 31, 2010 | Ecoquest Fresh Air Air Purifier
I have a "fresh air" and I'm receiving a message saying synair- G4 replace lamp. Does this mean only to replace UV lamp
This means that the UV lamp has stopped working. Since you need a good starter to make the lamp work, it make sense to replace both at the same time.
Feb 04, 2010 | Ecoquest Fresh Air Air Purifier
I need replacement parts for my FreshAir. Lamp
E mail to [email protected] List the parts you need and the serial number. They'll be glad to help you!
Mar 31, 2009 | Ecoquest Fresh Air Air Purifier
Lamp replacement???
Make sure the lamp is seated properly. Take it out, put it back in, turning it back and forth until it clicks. DO NOT TOUCH with your bare fingers.
May also need to replace the starter (the aluminum can at the rear of the unit).
Jan 20, 2008 | Ecoquest Fresh Air Air Purifier
Pure ion uv light does not turn on
Where can I get a replacement ultraviolet germicidal lamp? I have been to Brookstone store and on line without help. My unit is a Pure Ion.
Thank you.
Dec 25, 2007 | Brookstone Pure-Ion UV Air Purifier
Replacing uv lamp in Ecoquest air purifier
Hi FCfogl, Here's you answer. Go to the URl below for detailed instructions with pictures. http://www.airpurifierrepair.com/PageInfo.aspx?page=ReplaceUV Hope this helps
Sep 25, 2007 | Ecoquest Fresh Air Air Purifier
Ecoquest Fresh Air Air Purifier Logo
2,592 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
