Question about Sanyo VWM-900 VHS VCR
Picture is snowy and isn't clear
Sound is great. Tried a head cleaner. Eats tapes once in a while now to.
  • 275 Answers
If you are using the RF out to connect to the VCR to your TV, perhaps the connecting Cable is faulty? And if you are connecting the VCR using the Audio Out / Video Out Cables, try replacing only the Video Out cable. In 95% of the cases, it is only the connecting cables which go faulty. If the above solution does not solve the problem, then we consider options. How old is the machine? if it is more than 5-6 years old, you need to get a service done. For chewing of tapes, 99% of the time it is a bad Pinch Roller(it is big (approx. 1 inch high. on the right side of the mechanism assy.)replace, and your chewing problem will go away.
Posted on Oct 01, 2007
No picture on my TV/vcr combo when playing VHS tape.
I suspect either the playback head is very dirty and needs cleaning, or it's malfunctioning and needs to be replaced.
Aug 20, 2016 | Toshiba MV20FK3 20 in. TV/VCR Combo
Snowy picture
Clean the video heads. You can get a head cleaning tape. But the best solution is to take the top cover off and spray the Video Head with Servisol Video 40. Use cotton buds to clean any bad dirt off. Clean all the surfaces the tape touches. Allow to dry before putting a tape in. You might have to do it more than once. It will also take longer to clean if someone in the house is a smoker.
Sep 15, 2013 | Sony Televison & Video
EWC19T5 problem and solutions'
You need to clean the video head. Though you can buy a tape head cleaner tape, it's much better to take the top cover off and spray the head with Servisol Video 40. Make certain it's dry before putting a tape in.
Jul 14, 2013 | Televison & Video
I have a couple VHS-C tapes that drag
This may be caused by a faulty adapter. 1. try playing in the camera. 2. try a different tape. 3. try a different adapter.99% this is a problem with the adapter or the tape. It really sounds like the tape isn't turning freely, which can be caused by a brake sticking, or spindle in the tape or adapter.
Mar 16, 2012 | Televison & Video
Our Hitachi MX818E VCR is suddenly not playing videos. We can hear the sound however. We do not have the user manual anymore. Thank you, Ann
a common problem is rental videos that have been damaged in the first few feet of the tape by some other vcr's defective drive mechanism that "eats"the tape..What happens is the particles of the damaged tape clog the video heads in your machine,which have gaps in the millionths of an inch.Put a brand new tape in the machine and let it play for a half hour or so and it will usually clear itself.If that does not do it,insert a head clening tape and a couple drops of cleaning fluid and run it through.The newer machines will show a blue screen if there is no video information present.However,if you put it on forward search,it overrides that feature and you will see a snowy picture from a good tape,if one video head is clogged and the other is working.There are 2 video heads on a rotating spins at 1800rpm and that is the whirring sound you hear when play is pressed.If both heads are clogged,you will see a snowy screen and no picture at all.A 4 head machine has 2 heads for slp or 2 hour speed and the other 2 heads are used for lp and slp.A hifi vcr has 2 more heads,which are used for the hifi audio,a total of 6 heads.The stationary playback head has a control signal for tape speed,and regular audio,mono or stereo.
Jan 03, 2011 | Hitachi Televison & Video
Snowy picture, are heads dirty if so will head cleaner work, could there be another problem other than dirty heads?
if it is your heads, a head cleaner tape slowly grinds down your heads. Abrasion bad. Take to shop and have them clean heads with solvent and soft cloth or Q-tips. Might not be your heads, much electronics, but sounds like might be.
May 07, 2009 | Video Cameras
Sound but no picture
first you will need to take a tooth pic and lightly clean the creases in the head , then use a cotton tip with cleaning fluid on it and wipe the head down , then if it gets to where you can see it again you may also have to adjust the tape pull pins for the tracking
if those don't work then the head is bad or there is a bad component
Nov 26, 2008 | Samsung VR5559 VHS VCR
NEC VH-605 VCR - Very Snowy Picture
Video head needs thorough cleaning. If no head cleaner, then run a few long tapes through it in the fast scan mode since the tape itself is abrasive and will over time remove debris from the heads. If that does not do it, try a chemical cleaner to dissolve the material.
Sep 01, 2017 | NEC Audio Players & Recorders
Emerson ewc1302 13 in. tv/vcr combo problem
We had that same problem. Try a VHS head cleaner. Worked for us.
Oct 24, 2007 | Emerson EWC1303 13 in. TV/VCR Combo
Sanyo VWM-900 VHS VCR Logo
55 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
