Magnavox projection tv hookup to external speakers
Need help hooking up my Magnavox projection TV to my external speakers. I tryed the external (audio out) connectors. no sound. the external speaker connections were tested using a radio. I tryed to find an applicable setting on the on screen menu system but nothing seemed to apply or work.I'm hooked to a digital cable system through a vcr.any help would be appreciated. thanks
    Top Expert:
  • Televison & ... Master
  • 40,402 Answers
The external (audio out) connectors are intended for use with an external amp, not direct speaker connection.
Posted on Sep 02, 2017
  • 1153 Answers
SOURCE: No Audio Out to Stereo Reciever
First have you went in menu and check audio to see if you are on the variable audio or external output? Check to see if this makes a different with audio jack hookedup correctly of course!
Posted on Sep 11, 2007
SOURCE: variable audio out has no output
I turned off the internal speakers in the TV and the external speakers then worked.
Posted on Feb 26, 2008
SOURCE: How to hook up additional speakers to the TV
If you have a surround sound system, (amplifier and speakers), run the DVD speakers out wires to the amplifier IN. Thi way, you don't even need the TV speakers.
Posted on Aug 17, 2008
  • 33 Answers
SOURCE: Magnavox rj8510 ak03 out of focus?
in my 51MP392H Magnavox you take the back off there is a small black box hanging downf( Focus/ screen control block? as the previous person calls it) it has 3 color controls and focus knobs on it., the whole thing is the size of a door knob and the knob larger pencil erasers with hard to see labels in stamped plastic.
are you sure its blurry and not the colors all mismatched slightly?
Possible you need to clean the lenses on the inside they may be caked with dust causeing a blur?
good luck, it might help,
Posted on Nov 03, 2008
  • 124 Answers
SOURCE: need to turn external speakers on (ilo tv)
What is the model of the DVD player and the Television.
Posted on Nov 12, 2008
What do I have to do to hookup a headphone to my 60 in vizio TV?
Without opening set, easiest thing you can do is hook up a small receiver to the audio outputs of tv and then plug your headphones into the headphone output of receiver. And when not using the headphones you can always hook up some external speakers to the receiver - they will always sound better that the speakers that come with the tv.
Feb 23, 2017 | Vizio Televison & Video
I have an old magnavox tv and am trying to hook up a magnavox dvd player but there are no hookups in the back. It is a model #RR254oA 102, Ser# 13610889 purchased in 1992. Can you help me? Sincerely,...
are there any places for av cable to be plugged in? We have an older tv that only plugs in the front. I have a 20" magnavox tv too, about a 1993-94 model And it has the colored (red, yello, white) av plug ins in the back. Yours doesnt have this? Please reply.
Sep 03, 2008 | Televison & Video
No sound
Sounds like a loose connection that has finally failed in the audio out circuit
Jun 04, 2008 | Hitachi 61HDX98B 61" Rear Projection...
Mitsubishi rear projection tv, model WS-48311 - Lost audio after moving tv and re-hooking up cables. How do I get it back?
It sounds like this TV is being used only for the PS3. We'll need to troubleshoot this through a process of elimination.
If you're using Component Input 1 and audio, try using Component Input 2 and audio instead. If this set of inputs provides working audio and video - you can stop. Or, try going back to Input 1 once more. If Input 1 now works - you may have simply made a better connection. If it doesn't - then there's probably an issue with input 1 on the TV.
If moving to Input 2 above still didn't solve the problem, you should try using a different set of audio cables between the HDFury and the TV. If it now works, the original audio cables are faulty.
You can check the HDfury setup on another HDTV with component inputs with it connected to an HDMI cable. if the HDFury wors, you know the device and all the cables work. If you do this test and it works with your PS3, then you know that the PS3 is providing good video and audio signals via HDMI. If the problem follows the PS3 - then it's the PS3 at fault. If everything works perfectly on the second TV, then there is some issue with the audio amplifier / inputs / speakers of the Mitsu TV. You could get a cheapo stereo amp and speakers - or a set of computer speakers for audio - it all depends on how much you want to spend for sound.
Good lcuk!
May 07, 2015 | Mitsubishi Televison & Video
Lg soundbar nb2020a setup
If you are currently using your sound system shown for your television sound then you need to use that with you sound bar plugged into it. You can hook it directly to your TV if you have an audio out but your tv has to produce enough output to run the sound bar. If your tv does have an audio out then there is a good chance you need to make those jacks active in the sound set up menu for external speakers. Some sound bars are powered and will require being plugged in as well.
Apr 27, 2013 | Audio Players & Recorders
My tv volume is on 100, however, you still can't hear it
first is turn it down to a lower level:
look to see if sound with a DVD connected to a rear input.
look in menu to see if speakers are switched to OFF.
look also if set has external speaker hookup set not set to external.
failing you have a audio circuit problem in the TV.
Nov 06, 2012 | Magnavox 26" LCD TV with Built-in DVD...
No sound on monitor tv. Does it have internal speakers or does it need external speakers hooked up to it? Also, i need help configuring it so it will play audio
Set indicated here has speakers and may have a slide switch on rear to select internal or external speakers.
Also in menu look to see if speakers are switched off.
Apr 03, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Can't get TV sound hooked up through sterio?
Hi ,
have you tried using a HDMI cable to hookup to your stereo?
that would be a better option.
May 25, 2011 | Samsung 46 in. Flat-Panel LCD HDTV
I hooked up my stereo amp to my external speakers that were also still hooked up to my tv. now I don't get any audio from my tv just a high pitch sound. Is this an easy fix?
Hi, I can help. It sounds like the TV internal speakers were turned off so that the only speakers to have sound were the external ones. Go to your menu and find the sound area. There you can tell the TV to send sound to the internal speakers once again and not to external.
Jun 21, 2009 | Televison & Video
Need a diagram to hook my Bose CinemaT speakers. When I hook it directly to the tv no problem but can't figure out how to hookup my reciever and CD player to work also? Help Please
You'd be better off hooking the speakers to the RECEIVER'S speaker outputs, THEN hooking your TV audio output to an unused receiver input, such as AUX. The signals from your receiver cannot reach the TV; thus your CD player and radio will not play through the speakers if the speakers are hooked to the TV. All receiver INPUTS are designed to accept the same signal level; thus, you can use any input for your TV audio, such as Aux, DVD, CD, etc. Just remember which input you're using for the TV audio, and everything should work fine. Almost all receivers have an AUX input; hopefully yours also has a dedicated CD input to avoid confusion. The you simply select the AUX input to hear your TV through the speakers.
Dec 26, 2008 | Bose Cinemate Digital Home Theater System...
Televison & Video Logo
203 people viewed this question
Top Televison & Video Experts
