Question about Toshiba 57H83 57" Rear Projection HDTV
Picture The TV works great and all functions work; however the picture has no color, just black and white???
  • gooser Dec 26, 2007
    please provide color ic part number.
    President:
  • 4,402 Answers
Color IC bad
Posted on Dec 05, 2007
SOURCE:
Color comes and goes. Why ?
Do we know a brand and model number of the TV?
Aug 27, 2012 | Televison & Video
Have picture in black & white no color. audio
Hi,it definetely sounds like the color wheel.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Found your color wheel here: http://www.discount-merchant.com/MITSUBISHI-00-L3603-002-p/1162430.htm Have a bless one!
Mar 29, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I lost my color on my tv
If the cable was an SVideo, it's possible you might have a broken pin. Losing one of the 4 pins would still give you a picture but it would be in Black and White. Check both ends of the cable and if one is missing, get another SVideo cable.
May 26, 2009 | Samsung DynaFlat TX-P2764 27" TV
No color picture on Toshiba CF36G40
You need to go to the menu screen where the contrass, color etc are located. Scroll each option and one of them will add the color, one of them is probably at 0 so you need to ensure that it's added
Feb 15, 2009 | Toshiba CF36G40 36" TV
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
When I input s-video cable into RCA tv, the screen shows just black & white color, not full color that used to show. I tried to connect my laptop and dvd player with new s-video cable, but it didn't...
Take a flashlight and magnifying glass and look at the S-Video connector on the back of the TV. Check to see that there aren't any pins or other debris stuck in the four holes.
One pair of holes is for the brightness (luma) signal, which gives you the black and white picture, and the other pair of holes is for the color (chroma) signal, which seems to not be functioning.
If there's nothing in the holes, then the internal connection may be flakey. Try gently wiggling the plug on the TV side and see if color returns, even briefly.
Does your TV have other inputs like component YPbPr?
May 08, 2008 | Televison & Video
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
NO Picture in Color except for PIP
have a tech check your tv the color circuit needs to be looked upon.good luck
Apr 29, 2007 | Akai PT5492S 54" Rear Projection...
Black and white picture on the JVC TH-505
If you hold the VFP button while a movie is on, you will get a small box on the corner that shows your color. My default color also turned black and white. I just moved over to a user1 color setting (push the right arrow on your remote), and it allows to the change the colors. You might be able to put the colors to come out through here. Hope this helps.
Jan 28, 2007 | JVC TH-M505 System
Toshiba 57H83 57" Rear Projection HDTV Logo
62 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
