Question about Sony KV-32S42 32" TV
Standby No screen,no sound only stay in standby
  • dumdfounded Mar 09, 2008
    pcl541r samsung 54 '' turn on for 1 hour or so then turn off. must wait for next day to turn it on for same result. help!!!
  • mobile3 Jul 19, 2008
    no picture no sound standby light flashing buy new tv not sony
I ALSO HAS THE SAME OF SIMELARLY PROBLEMS. SONY/kv32S42 ONLY STANDBY LED KEPT FLASHING NO HI-VOLTAGE AND I DID CHECK OUT PUT TRANSISTOR OUTPUT AND SOME VOLTAGE --5VOLTAGE AND +5 VOLTAGE LINES IS OK. WHAT OUT NEXT?
EMAIL ME @ [email protected] or [email protected]
thanks
Posted on Sep 08, 2008
THE PROBLEM IS PROBABLY BEING CAUSED BY A SHORTED POWER REGULATOR (MX084 ) OR AN OPEN FUSEABLE RESISTOR IN THE POPWER SUPPLY. USUALLY A JOB FOR A SKILLED SONY TECHNICIAN.
Posted on Apr 28, 2008
    Champion:
  • 225 Answers
Check secondary voltages and horizontal out put section, and check smps and all the voltages and line out put transformer section...
Posted on Sep 29, 2007
3 Suggested Answers
SOURCE:
  • 285 Answers
SOURCE: standby blinking no picture or sound
Ok. I think you'll need an IC or a PSU.
Posted on May 24, 2009
  • 4234 Answers
SOURCE: standby light stays on
When attempting to turn on the set, the standby light should blink for a a while then stop once the picture comes on. If a problem is detected internally, the standby light should blink in a repeated pattern. Please count the number of blinks that are repeating and we should be able to help.
Thanks,
Dan
Posted on Aug 01, 2009
I got a used LCD1932 Lloyd's TV/Monitor. The top has a standby button, turns it on, but u hit same button to turn it off, it has red standby light that stays on, does that mean it's always on standby
It's normal; if the set do not show a screen at this time. The red light indicates that the set is in standby mode, and it will off, when you hit the standby button again, and the scree will get live.
Oct 15, 2014 | Televison & Video
Stays on standby no picture or sound
When a Sony TV has just the STANDBY LED lit and nothing is flashing (An error code) then the TV is in PC standby meaning usually that there is no signal coming in on the PC input (Computer). Turn on the computer that's attached to fix this. If this is incorrect then you will need to use your remote and select the correct tv signal input for your particular setup.
Good Luck!
Rich Lilja
Mar 23, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a 52in ilo flat screen television that just stopped turning on. It stays in standby mode. It use to come on and periotically would stay in standby mode. It is now stuck in standby mode.
Check and replace its main board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 17, 2014 | iLO 3200 32 in. LCD Television
My Denon AVR-75 seems to stay in standby (red standby light is on) and I don'd get surround sound through it. How do I get it out of standby?
if the receiver does not power on from standby there is a problem like bad power supply or even bad macroprocessor. You need to bring it to a service center for diagnosing. 10-years old receiver, maybe better to buy new one.
Nov 23, 2011 | Denon AVR-75
Emerson LC195emx 19 in. TV/PC Problem. Works fine as DTV. In PC (RGB) mode it works fine when power ON before PC boot. After PC enters STANDBY, screen reverts to standby. When PC comes out of standby,...
I've had the same issue with a samsung. It had something to do with the PC not being able to detect the hardware when it came out of standby, and sending the wrong screen resolution to the TV. I ended up finally turning off standby on the PC (control panel-->power options) and just setting a screen saver.
Sometimes when the pc came back up, I could switch the source on the TV (to maybe an HDMI) then switch it back to the PC connector and it would find it. But, on mine it was inconsistent.
Oct 03, 2017 | Computers & Internet
Polaroid 26inch lcd tvred standby light on but power wont turn on. I've unplugged the tv, changed the batteries in the remote. The tv stays with the red standby light only.
You need to open it up and checking the voltages in the power supply sections, you should have 5v (for logic circuits), 12v for sound, 24v for backlight inverter circuits. Look for bad caps with bulging tops in power supply also.
Jan 12, 2010 | Polaroid FXM-2611C 26 in. LCD Television
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Open Questions:
See all Sony KV-32S42 32" TV Questions
Sony KV-32S42 32" TV Logo
508 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
