Question about Sony PlayStation Portable (PSP) Console
Psp doesn't want to turn on
One day that i forgot my charger in my cousins home, and my psp was dead, i try to charge it with other kind of charger, i worked for a minute but then i accidently press i a button in that charge that got like this symbols (+ 0 -)i press and it change to (- 0 +) my psp turned off and since that day it doesnt wanna turn on again plz help me.
  • 6 more comments
  • avenger31 Oct 05, 2007
    its not bricked it cant even turn on
  • Anonymous Dec 23, 2007
    The battery is fully charged and it will not turn on the screen stay black
  • Anonymous Apr 08, 2008
    when i set mine down and put it on hold then a copule of minutes later i tried to turn it on and nothing happend help :(
  • Anonymous Jul 27, 2008
    i got Psp i turn of it and on next day it don't turn on i charge it and
    it steel don't turn on i need help
  • nekrus2 Jul 27, 2008
    i got psp and it wont turn on i charge it and steel it don't turn on
    and try put out and in battery and it steel dont turn on pls HELP my!!!!!
  • srshain98 Aug 30, 2008
    My green light on my psp goes on and it wont go on
  • libra297 Oct 14, 2008
    my psp doesnt wants to turn on or charge.
  • ilanaharon Jan 18, 2009
    Today i try to upgrade my PSP. but when it just start to upgrade my Battery fell down. then i triad to turn it on back again but the PSP dose nt turn on. i can see the Green light is on. but after a 15 sec its off again. there is no screen show its like dead.
    what can i do? can any one tell me if i can fix that problem?
    The battery is not the problem.
    What can i do?
I have a psp , and i wanted to play a game so i took out the memory card cuz it wouldnt take my memory . Then it said down loading , and i didnt want it to down load and i took out the game and everything then it froze and i tryed turning it offf and it didnt work so then i took out the battery and it turned off , and i tryed ma cuzins battery and it didnt work either . Its shows the light of the power button but the screeen doesnt show anythin .
Posted on Apr 23, 2008
It is not the charger. if you connet the (+) and (-) the psp wouldn't work anymore because electricity from the charger you use ran threw the whole psp system.
Posted on Mar 07, 2008
  • 709 Answers
The polarity of the charger you used is wrong or the wrong voltage, and has messed up the programming n the battery.  You may be lucky if you get a new battery and use the Right charger, It might fix it.  Sony put a battery in the PSP that has a memory chip in it, and I think it will automatically disconnect if the wrong vooltage hits it, or wrong polarity. be warned that I have seen where someone got a new battery and it did not solve the problem. If this happens to you Contact Sony at the following number.
SCEA Consumer Services
1-800-345-SONY (7669)
Monday - Saturday 6:00 AM - 8:00 PM PST
Sunday 7:00 - AM 6:30 PM PST
Posted on Oct 15, 2007
I play my psp regualy then i quit using it and when i went to turn it on it would never turn on and it want charge.
Posted on Sep 17, 2008
How to charge a psp with usb cable while it's dead
no you should use a computer an dplug it in to it and then an orange light should come on then just leave it there for a few hours untill the light turns green
May 24, 2012 | Sony PlayStation Portable (PSP) Console
I was using my psp while it was charging and the charging light turned off, so i naturally assumed that it was fully charged. But a few minutes later the battery died and it wont charge when i plug it in....
Have you tried to remove the battery and put it back in and try to turn it on. Try removing the battery and putting the charger in and starting the PSP. If it starts, it might be the battery. If it doesn't, it's either the plugin for the charger or the PSP is just dead. If it does start with the charger, try putting the battery back in, if it charges awesome. If it doesn't the battery might be dead.
Sep 27, 2011 | Sony PlayStation Portable (PSP) Console
I hi have my psp and it dont want to charge i take the battery out and put it in my cousin's psp and it charges in his and when it's fully charges it works in mine..... so its not the battery, i...
You did a good job in isolating the problem. It does seem that your Power charger port is the culprit. I had the same problem with my unit. What I initially did was I applied slight pressure using my finger pushing the adapter plug in the direction of the start button. Apparently, there was a slight gap between connector inside the PSP charger port and the outside part of the adapter plug. Eventually, I added a small layer of solder to one side of the upper part of the charger plug ( near the top part which is colored yellow ). Dont put too much solder, doing so will cause the adapter plug to not fit inside the port. That fixed the problem for me. !!!As a reminder, please do this if you are experienced in using soldering tools !!!!
If your unit is still under warranty, I suggest you let the Sony Technicians fix it for you.
I hope everything works out. All the best to you.
Jul 20, 2011 | Sony PSP-3000 Black Console
More that likely your battery that came with the system is dead(meaning it has reched it;s life span) An easy way to tell if your battery is dead, take it out and plug the charger into the psp. Turn it on and see what happens. If it still doesn't work, your psp has power problems and there isn't much you can do about that. You might have to send it in for repairs or get a new one Thank you for your time. Good luck and I hope it works.
Jun 05, 2011 | Sony PlayStation Portable (PSP) Console
Just bought a usb cord charger for my nikon coolpix s203 and its been dead fir a couple of days and I wont turn on
You left your camera on for a couple of days? I'd think your batteries are completely drained. The S203 doesn't charge batteries via the USB port. Try charging the batteries overnight using the supplied MH-63 charger.
If that doesn't do it, please reply to this post and we'll go on from there.
May 13, 2011 | Nikon Cameras
My original ac adapter for my psp burnt out I bought another adapter (universal) and after a couple minutes that one burnt too.Whats up?
its because your not suppose to use universal!!! my cousin has a universal and it takes for ever to Charge the charger was probably to weak for example the psp's charge is suppose to be 5 volts and the charger was probably 3 volts so the poor charger coulnt handle it and burned... try getting a new batterie. and a good charger
Apr 10, 2010 | Sony PSP (Piano Black)
Psp won't turn on or charge
There is a lot of things that might be rong 1 it might be the psp slot where the charger goes it might be damaged in the inside and the more u put the charger in the worse i might get. 2 it could just be the charger something might be rong with it from the wire to the top where it goes into the psp slot . 3 There might be something rong with ur psp battery it might just be damaged . Hope i helped . Go 2 a shop and ask them 2 check it for u. L8a
Aug 25, 2009 | Sony PlayStation Portable (PSP) Console
My psp is dead plz help
Try buying a new battery, that may be the problem
Oct 31, 2007 | Sony PlayStation Portable (PSP) Console
How to save your dead battery: Please note using below method at your own risk, and you have been told. Take out you dead battery (PDA battery,PSP battery,Phone battery etc), wape it around by using a big piece of dry newspaper. Then put the newspaper waped battery into the freezer at below zero temperture for 4 days. After days, take the whole thing out and put in room termperture for one day. Recharge the battery and use it.
May 25, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
706 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
